Number of passes before inspection teardown
#2362257
08/30/17 12:04 PM
08/30/17 12:04 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I got into a little bench racing the other day and the subject came up. I know that the power level and setup will dictate how often that tear downs occur. I was just curious as to how many passes some of you put on an engine before tear down. Jeff
72 Plymouth Roadrunner 11.08@123.25
Re: Number of passes before inspection teardown
[Re: Roughbird72]
#2362288
08/30/17 01:01 PM
08/30/17 01:01 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
On my first ss 440 I pulled it out at 400 passes, on my 500 I pull it 250 + or -. I put new gears in the 8 3/4 before 250 runs. My stuff gets about 1000 per year in street miles also. I used to run both motors to 7000 rpm but only 6500 now, smaller cams.
Have a great day Iowan
"obsolete is neat"
[Re: dthemi]
#2363656
09/01/17 06:27 PM
09/01/17 06:27 PM
crabman173
crabman173
When it slows down is the best indicator.
That is the best advice That every other year teardown is usually not needed on normal bracket engine
[Re: Roughbird72]
#2365861
09/05/17 04:00 PM
09/05/17 04:00 PM
Triple Threat
Renton Washington
Usually every other winter I pull it apart for a check. I make about 200-250 runs a year so somewhere in the 400-500 run range if nothing is wrong.
[Re: Roughbird72]
#2366054
09/05/17 09:36 PM
09/05/17 09:36 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I've always used leak down results or oil pressures changing.
[Re: Roughbird72]
#2367373
09/08/17 10:49 AM
09/08/17 10:49 AM
Challenger 1
Cincinnati, Ohio
We raced a top alcohol dragster for 9 years. When I started we were running a wipple screw blower that made 50 pounds of boost. We would cool and adjust the clutch every run. We would change the 18 qts of oil and replace 16 spark plugs every run. Then every 2-3 runs we would replace 3 clutch disc and 2 floaters and pull the pan and replace the upper rod bearings. After 12-14 runs it got new rods and pistons. Then after 20-24 runs the block came out of the car for new main bearings and we put in our 2nd motor and serviced it the same way. Then we went to a PSI screw blower, one 44 amp mag instead of 2 12 amp mags, brad billet block. The PSI blower made 60 pounds of boost which required us to replace the upper rod bearings every run and replace the clutch every run. The good thing was we were only using 8 plugs per pass now. BFD I tuned the car off the upper rod bearings and spark plugs each pass. There was other stuff that got replaced every run like the CO2 tank and more. I had 6 guys helping me. We replaced 2-4 inner valve springs too every run and a complete new set put in at 12 runs. I had 3 complete motors, still have 2 of them. 449",451",454" low deck hemis. Got to go...
[Re: Roughbird72]
#2367501
09/08/17 03:38 PM
09/08/17 03:38 PM
Posts: 11,661 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
We never put a ton of runs on the car. 100-150/year. System 1 filter got looked at and the car got cleaned and looked at every week, regardless the run count. Plugs, valves, carb, etc., were taken care of regularly. Any abnormal issues that popped up were put on the list of things to keep a closer eye on every week.
It came completely apart every winter. Engine, trans, fuel system, suspension, brakes, everything, and was checked/freshened as needed. Engine got rings, bearings, heads looked at, everything cleaned and inspected. Trans got resealed and anything funky replaced. Ignition parts were changed out, I started the year with everything fresh and didn't run it until it was about to fall apart. If the trans had to come apart mid year to look at to get it to the end of the year in good shape, we did it. We had very few problems with anything failing at the track and were able to work on making the car better from race to race as a result.
