Page 4 of 4 1 2 3 4
Re: Trick Flow 240 users [Re: AndyF] #2634378
03/19/19 11:50 AM
03/19/19 11:50 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
^ agreed !
Re: Trick Flow 240 users [Re: dartman366] #2798280
07/18/20 12:24 PM
07/18/20 12:24 PM
South Florida
GOLD67GTX Offline
GOLD67GTX  Offline
South Florida
Hello all, I’m prepping and tuning my combo with the 240’s. I’ve been watching and I’m ready to jump in for advice. Looks like it’s been a while for any replies here, but I’m keeping with fast68’s idea of making this the TF go to post.
446, TTI 2” primary, 10.9 cr, stock 240’s, solid flat tappet 268/272 @ .050 with .600, M1 untouched, 950 Holley, 4900 stall from Lenny, 4.10, 27x10.5 qtp. 3900# with me....she’s pretty thick, I know. 67 GTX
I’ll update with my new runs. As an FYI, My 2nd run ever on this combo at LVD in NY last October went 11.89 @ 115 (1.77 60) through the mufflers with a lean out condition at about 200 ft or so from the finish. That’s been fixed. Just left her in drive, launched at 1500 and let the trans shift itself at 5900 for mild initial testing.
A simple question to start with: what brand and number plugs are being run, and any recommendations for me?
Re: Trick Flow 240 users [Re: GOLD67GTX] #2798288
07/18/20 12:49 PM
07/18/20 12:49 PM
AndyF Offline
AndyF  Offline
For pump gas I use NGK 6987 plugs. Those are a 6 heat range OEM type plug. I think they are factory on the Jeep 4.7 engines or something. They have a projected tip and a wide gap and they seem to work pretty well in anything I run.
Re: Trick Flow 240 users [Re: AndyF] #2798292
07/18/20 12:55 PM
07/18/20 12:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
10.9cr...... you’re in the NGK 6 and 7 heat range area.
7’s will likely be a tad cold for street duty.
Re: Trick Flow 240 users [Re: fast68plymouth] #2799502
07/21/20 06:33 PM
07/21/20 06:33 PM
South Florida
GOLD67GTX Offline
GOLD67GTX  Offline
South Florida
Thank you very much gents. It’ll be a couple weeks before I can get to the track but I promise to keep this updated with track results.
Page 4 of 4 1 2 3 4
