5.7 hemi tick
#2361303
08/28/17 07:34 PM
08/28/17 07:34 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
Okay guys, just replaced the 5.7 in my '13 Ram 1500 with a factory New engine. At 112,124 miles my daughter started the truck and said it started ticking. All the advice I got, including from my regular and reputable mechanic said 'sounds like the hemi tick'. Well... it wasn't.
Maybe at first it was but I saw the failed parts. The Chrysler dealer mechanic showed me the parts from the roller end, a pivot point he called it, I though it was a shaft that the needle bearings rode on, had a flat spot. Retainers broke and the needle bearings came out and then my cam was gone with a crap load of metal in the pan.
Yep, 112,124 miles and Chrysler Care set me up with some good will warranty help but only partial.
So, to the Question of the Day:
What is failing when an engine has the Hemi Tick? Has a Post Mortem been done to actually explain it?
Is the lifter collapsing? It the roller failing? Something else?
TIA
dstryr, since 1986.
Re: 5.7 hemi tick
[Re: dstryr]
#2361323
08/28/17 08:05 PM
08/28/17 08:05 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Roller lifters stop rolling and eat the cam.
I also see the pushrod/rocker interface wear out and start ticking, probably even more common actually. We seen one that was so bad it sounded like a duramax, swapped in rockers and pushrods and now its smooth and quiet.
Re: 5.7 hemi tick
[Re: dstryr]
#2361336
08/28/17 08:31 PM
08/28/17 08:31 PM
dstryr
Wendy, I'm home.
Thanks Dave.
So the pushrod/rocker interface wears and the lifter doesn't take up slack?
I have also read a lot of comments(not on moparts) where owners are going to a 5w30 weight oil and the tick stops and they drive many thousands of more miles without a failure. Do you know what's up with that?
Or, the tick is just 'there' and they continue to drive thousands and tens of thousands more miles without a failure, and its not the exhaust leak tick.
Maybe they're just living on borrowed time?
dstryr, since 1986.
Re: 5.7 hemi tick
[Re: dstryr]
#2361475
08/29/17 12:06 AM
08/29/17 12:06 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
The thinner oil makes its way thru the shafts then rockers down thru the pushrods into the lifters quicker than a thicker oil will.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: 5.7 hemi tick
[Re: dstryr]
#2407736
11/23/17 04:52 AM
11/23/17 04:52 AM
Posts: 6 Knoxville, TN
Rockystock
Knoxville, TN
I bought a 392 Hemi from a 2016 Challenger with only 10,000 miles but I think the rocker assemblies are the same as the 5.7. Did the MDS delete and found that the pushrods were not very straight and were all considerably shorter than their spec. of 6.800" (intake) and 8.100" (exhaust), some by 0.016"! My intake rods averaged about 0.006" short; exhaust rods averaged 0.014" short. In addition, six of the rocker end tips were galled along with the corresponding rockers.
My MDS lifters also looked odd - the push pins were misaligned on all but one of them. I hadn't heard it run before purchasing but can't imagine it sounded well.
So in addition to the non-MDS lifters, this engine is also getting a set of new 3/8" 0.120" wall pushrods (0.145" for the intake because the maker is phasing out 0.120" wall) and new rocker assemblies.
I don't think individual rockers are available, but Mopar has revised their rocker assemblies in a way that appears to increase the duration of oil flow to the pushrods and lifters per cycle. They've added a chamfer to each oil hole to the rockers (see pics below). The rockers also appear to be cast differently, but the overall dimensions appear identical to the old rockers (maybe stronger material?). They are part numbers 53021552AB and 53021553AB.
Re: 5.7 hemi tick
[Re: dstryr]
#2409492
11/27/17 04:00 AM
11/27/17 04:00 AM
Rockystock
Knoxville, TN
The "hemi tick" surely has several possible causes, but aside from trying different oils or additives, changing out the pushrods (and the rockers if there's evidence of tip wear) is probably one of the easier things to try. I think the stock pushrods are just poorly sized and straightened from the manufacturer, and can cause at least some slop in the valvetrain.
OK so I was a bit bored today and took some measurements of the stock pushrods from my engine and compared them to a set of aftermarket rods. The aftermarket rods are a three-piece version and are probably good, but I'll be sending them back for a set of one-piece rods that are advertised to be straight to within 0.001", length to spec within 0.002". Full OCD.
Tip diameter - Didn't bother to plot these, because they were all right at 0.312" (5/16") for both stock and aftermarket.
I refuse to spend around $100 for a pushrod straightness checker stand, so for the total indicated runout, I placed the pushrod ends (with a bit of assembly lube) into two of my old rockers, and clamped the rockers to a workbench. Digital indicator was resting on the workbench. The 1" digital indicator is a Harbor Freight POS, supposedly good to +/- 0.001". It took some patience and finessing with this setup, but I was able to get a repeatable set of measurements. The values shown on the plot are the maximum of three for each rod (one measurement taken at the center and about 1" from each end).
Lengths were measured with an Insize brand dial caliper, 0-12", accuracy +/- 0.001".
Re: 5.7 hemi tick
[Re: dstryr]
#2409495
11/27/17 06:32 AM
11/27/17 06:32 AM
Posts: 80 Australia
aus370
Australia
Good work, Love the runout checker . I was thinking about using a rotary burr to add the chamfers to my older shafts , but maybe not a good idea , it may cause flaking of the surface hardening
Re: 5.7 hemi tick
[Re: dstryr]
#2409741
11/27/17 07:23 PM
11/27/17 07:23 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I built an 04 5.7 thats in my truck by using the later eagle years pistons, because I had a set with 5k miles. To get the compression up, I had .020 taken off the heads. No tick or any valve train noise at all. Used the stock length pushrods. Seems longer pushrods would fix the noise. My 06 magnum, I regret not doing the same when the engine was apart.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 5.7 hemi tick
[Re: Silver70]
#2410000
11/28/17 05:18 AM
11/28/17 05:18 AM
Rockystock
Knoxville, TN
It makes sense that you have less or no excessive valvetrain noise with effectively longer pushrods, since you're probably running with more preload than completely stock. How much, no idea. If your stock pushrods are similarly shorter than their spec length as mine are, your head decking may have come really close to balancing out the short rods. If you know the angle the pushrods make relative to the cylinder deck, you may be able to calculate the effective pushrod lengths needed. May just be easier to measure lengths with the special adjustable pushrod and checking spring... Alternatively, you could be running with too much preload which may cause excessive lifter pump-up, leading to excessive valve lift, reduced power, and rough idle. Here's a brief discussion about the effects of too little or too much lifter preload: Pump It Up - Preloading Is Important!
