REAR FUEL TANK 80 D100 STEPSIDE #2360222
08/26/17 05:56 PM
08/26/17 05:56 PM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
WHAT IS A GOOD TANK TO USE BEHIND REAR AXLE?
Re: REAR FUEL TANK 80 D100 STEPSIDE [Re: rickb67] #2360243
08/26/17 06:56 PM
08/26/17 06:56 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
The ramcharger tank went behind the rear axle. it fits between the frame rails so I don't think it will interfere with the stepside at all. you will need to Fab some mounting brackets or steal them from a ramcharger.
Re: REAR FUEL TANK 80 D100 STEPSIDE [Re: rickb67] #2360521
08/27/17 11:45 AM
08/27/17 11:45 AM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
Several of the hot rod guys use a 1st gen mustang tank. It will fit between your frame rails without much effort. As stated above the RC tank is rear mounted but holds 35gal IIRC.
Re: REAR FUEL TANK 80 D100 STEPSIDE [Re: wedgeheaded] #2360899
08/27/17 11:49 PM
08/27/17 11:49 PM
Pennsylvania
P
polaris400cc Offline
P
Pennsylvania
Unless you use the smaller steel tank that was the standard tank on a ramcharger. I forget exactly maybe 22gal. But either way I don't think the smaller steel tanks have been available in the aftermarket for some time.
Re: REAR FUEL TANK 80 D100 STEPSIDE [Re: rickb67] #2360921
08/28/17 12:23 AM
08/28/17 12:23 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
THANK YOU GUYS
Re: REAR FUEL TANK 80 D100 STEPSIDE [Re: polaris400cc] #2360939
08/28/17 01:11 AM
08/28/17 01:11 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I swapped a ramcharger tank into a '76 Club Cab I had back in the '90's.
If you find a donor ramcharger and it has a metal tank, its the smaller tank. All 35 gallon tanks were plastic.
Either tank uses the same crossmembers, just the straps are different.
And I'm not 100% sure, but, I think the smaller tank was used predominantly on two wheel drive RC's (mid '70's, not the later RC's).
If you go with the RC tank, you need to swap in the crossmembers from the RC. The tank will dictate where they need to go. The hardest part of swapping the crossmembers is getting the factory rivets out.
If you decide to go Mustang, disregard what I just said.... biggrin
John
Re: REAR FUEL TANK 80 D100 STEPSIDE [Re: rickb67] #2361719
08/29/17 02:09 PM
08/29/17 02:09 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I have a complete 36 gal. Ramcharger tank setup with cross members.
Contact me if interested.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: REAR FUEL TANK 80 D100 STEPSIDE [Re: rickb67] #2362051
08/29/17 11:33 PM
08/29/17 11:33 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I had an 80 4x4 with a 2nd tank. It was plastic, and was located behind the rear axle. I believe it was 18 or 20 gal. Would have been the rear auxiliary factory tank. I have no idea if it is still available or not.
My saddle tank was cracked, so I disposed of it and only used that rear tank for the 12 years I used that chassis (it was under my 50 Dodge 4x4), so I know it wasn't bigger then 20 gal. Gene
Re: REAR FUEL TANK 80 D100 STEPSIDE [Re: rickb67] #2362090
08/30/17 12:26 AM
08/30/17 12:26 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
a mid 90's grand cherokee 5.2 has a nice plastic tank....
