Re: Stock crank, aftermarket rod/piston question... [Re: Porter67] #2363257
09/01/17 04:22 AM
09/01/17 04:22 AM
I can't remember if it is 28.0 or 28.5 grams per ounce confused
Any one on here know for sure?
My point is a gram doesn't very weigh much shruggy
Re: Stock crank, aftermarket rod/piston question... [Re: sycboi] #2363261
09/01/17 04:41 AM
09/01/17 04:41 AM
P
Porter67 Offline
Porter67  Offline
P
Its an interesting topic for sure.
Some of the best admit to questioning what a good balance is, how can everyone use the 5 grams for oil?
I normally send a simple figure for the bearings and spiral locks on paper, some of the king bearings I use are 5 grams lighter then clevite, a single triple wound spiral lock is 2 grams heavier then a double wound.
But I always use the same number, I didnt realize this until very recently.
For me, who at times has the worst luck I just have things balanced because the $175 is better then pulling a motor down and doing it again.
It would be much worse to have to tell a paying customer I thought the balance would be ok and I will have your car another 2 weeks to a month.
If we all were not critics of others it would be nice to have a post on what some have gotten away with going against the norm.
Re: Stock crank, aftermarket rod/piston question... [Re: Porter67] #2363346
09/01/17 11:06 AM
09/01/17 11:06 AM
moparx Offline
moparx  Offline
boy would that be a fun thread ! i have "cheated" a whole bunch of times, some last longer than you would expect, while others lasted just enough to get the job done !
beer
Re: Stock crank, aftermarket rod/piston question... [Re: sycboi] #2363398
09/01/17 12:18 PM
09/01/17 12:18 PM
New York
polyspheric Offline
polyspheric  Offline
New York
28.35 grams = 1 oz.
Boffin Emeritus
