Re: ThermoQuad tuning at Cruise
[Re: RayR]
#2367727
09/09/17 01:17 AM
09/09/17 01:17 AM
Posts: 1,761 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
RayR, sorry, I'm a little late to this thread, but I've got a handy little tuning spreadsheet I put together some time ago to help me with the tunning efforts. It's a Lotus 1-2-3 spreadsheet (alright, alright...you done laughing yet? LOL), but Excel should have no problems pulling it in. Anyways, the 'Comparison' tab does a all-at-once check, while the 'RodJetMatrix_A/B/C' tabs do the specifics. Each one defines a BASELINE setting of jets and rods, then calculates the % surface area change for available fuel...so this actualy gives you the real difference the carb sees as opposed to a straight forward jet/rod diameter changes. It does this calculation for the primary, secondary and TOTAL areas. Than given the mix of my tuning components it lays out the Lean=>Rich roadmap. Re: air bleed sizing, etc, etc...I've done a whole bunch of experimentation with these, great carbs to tune, but yeah, not having any spare parts and tunning (jets, rods, etc) is a real impediment. In addition to the great stuff in this thread check out the following posts: 1) thread_1 2) thread_2 3) Dippy.org thread
[Re: RayR]
#2368008
09/09/17 08:19 PM
09/09/17 08:19 PM
Posts: 62 montreal, quebec,canada
7e5dartsport
there is one thing about tuning thermoquads that most dont seem to know. the primary side of the carb should be tuned by the metering rods in my opinion.i know that they are hard to find. but here is my tip: use edelbrock avs rods bent and cut to thermoquad length on the big end. they are available from edelbrock. i could be wrong but there is no need to play with the air bleeds in the carb top portion.
fully legal sounds the same as full illegal...
[Re: 7e5dartsport]
#2368053
09/09/17 10:11 PM
09/09/17 10:11 PM
RapidRobert
but here is my tip: use edelbrock avs rods bent and cut to thermoquad length on the big end. they are available from edelbrock. Good info, which ones?
[Re: RayR]
#2369291
09/12/17 10:42 AM
09/12/17 10:42 AM
Diplomat360
Windsor, ON, Canada
...The spreadsheet sounds great, unfortunately I couldn't get Excel to recognize it - any chance you can save as an Excel and re-post?... OK, here it is...I did not have a chance to open this up in Excel, I used Apache OpenOffice though and it come up fine.
[Re: BDW]
#2369483
09/12/17 04:11 PM
09/12/17 04:11 PM
Diplomat360
Windsor, ON, Canada
I applaud you guys, but reading through all this just makes me all the happier I converted to fuel injection. LOL, you know, I'm an IS guy by profession...so FI is normally "my thing"...but so is working with the "elements" Cave-Man style...ha ha...ahh...the joy of overcoming the air/fuel obstacles!!!
