Re: Bolt on hub/bearing assembly [Re: autoxcuda] #2357078
08/20/17 01:23 PM
08/20/17 01:23 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Originally Posted By autoxcuda
Which year(s) B-body axle are you running; 65-67 or 68-70?
1968, but Dusters are pretty wide in the back. My friend has a 65 axle in his Demon and I didn't notice much difference, nothing that couldnt be made up with a small wheel spacer.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Bolt on hub/bearing assembly [Re: goldduster318] #2357159
08/20/17 04:01 PM
08/20/17 04:01 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I measured an all original metal one owner 70 340 Duster yesterday for inner to top 1/4 lip inside edge and go the same exact measurement as the original 68 Barracuda coupe wheel wells I have.
Orignal metal '70 340 Duster
68 Barracuda coupe wheel well with orignal 1/4 panel lip skin still attached
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2357343
08/20/17 11:43 PM
08/20/17 11:43 PM
IN
ahy Offline
ahy  Offline
IN
Originally Posted By 70Cuda383
Sealed bearings would be cool, but I'd be ok with a hub assembly that uses hand packed wheel bearings, primary goal being a hub that I can slip any 5-lug rotor onto, allowing me to fabricate my own brake kit. I know there's some good kits out there but most are using wilwood or Baer calipers. I prefer to use Brembos found on OEM set ups for ease if replavement parts, and the reliability of an all weather caliper complete with dust boots vs the 'resto-mod' stuff that lacks boots.
I currently run a hybrid Dr Diff/Baer setup. Original front's from Baer with their aluminum hubs. Rears from Dr Diff. Also replacement front rotors from Dr Diff. Front rotors are from a late 90's Corvette from memory. Calipers from a Cobra. I could get all normal service parts from the local parts store if I wanted.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2357364
08/21/17 12:37 AM
08/21/17 12:37 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Let us know if you find a usable hub
Re: Bolt on hub/bearing assembly [Re: AndyF] #2357455
08/21/17 09:28 AM
08/21/17 09:28 AM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
Originally Posted By AndyF
If it was me I'd buy the Baer hubs and work from there. Baer stuff is much higher quality than anything that Wilwood makes. If you don't want to spend the money for the Baer stuff then get some drum brake hubs and start with them.
Did Baer stop making them?
http://baer.com/Mopar-hub-hubparts/
**Photobucket sucks**
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2357464
08/21/17 10:16 AM
08/21/17 10:16 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Still making the brake kits using their hubs, so unless it's a case of using up existing stock then no more I gotta think an Email to support might be needed here.
Don't be the exception.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2357481
08/21/17 11:06 AM
08/21/17 11:06 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
Alright. Thanks. I was doing more searching and saw they still list the full kits. They have a full 6-piston kit for $2400. I know I can make my own kit using a 6-piston Brembo for probably about $800. Just gotta find a hub solution
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2357701
08/21/17 05:32 PM
08/21/17 05:32 PM
AndyF Offline
AndyF  Offline
I have one Baer hub on hand if you want to buy it. I'm sure you can come up with another one somewhere. Baer is still selling kids to the have the hubs. Maybe call them and tell them you need one.
Re: Bolt on hub/bearing assembly [Re: AndyF] #2357748
08/21/17 07:25 PM
08/21/17 07:25 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
Let me call Baer first. up
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2357766
08/21/17 07:52 PM
08/21/17 07:52 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Sorry, couldn't resist...
Re: Bolt on hub/bearing assembly [Re: BigBlockMopar] #2357794
08/21/17 09:06 PM
08/21/17 09:06 PM
IN
ahy Offline
ahy  Offline
IN
If I am not mistaken, Dr Diff sells the front hubs and whole front disc kit. I would not hesitate to buy from him.
Re: Bolt on hub/bearing assembly [Re: ahy] #2358017
08/22/17 10:06 AM
08/22/17 10:06 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
He does. And I have bought from him in the past. But he charges $1250 plus shipping for a 4 piston "brembo caliper" copy on a 13" rotor.
I can build myself a set with real 6-piston brembo calipers on 13" rotors for several hundred less than that. Possibly even half of that depending on what price I can get hubs, rotors, etc.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2358145
08/22/17 03:56 PM
08/22/17 03:56 PM
CJD AUTOMOTIVE Offline
You guys know that Coleman builds custom spindles pretty cheap, like under $500, that would allow the use of a variety of big bearing Coleman hubs (also very cheap) This would solve the camber/roll center issue on B and E bodies by having one made taller, and allow you to use a much stronger hub, all under $1500. As far as brakes, 6 piston calipers are nice if needed and the piston area has been calculated and MC and brake pedal ratio setup. You can have more brake force than the tires can use. Everything has to be designed or calculated based on the application.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2366741
09/07/17 12:48 AM
09/07/17 12:48 AM
McKinney, TX
badeeds Offline
badeeds  Offline
McKinney, TX
I made these for my D100 too use Mustang 13" rotors. I machined them so the rotor thickness plus hub put the wheel in stock location.
Re: Bolt on hub/bearing assembly [Re: badeeds] #2366782
09/07/17 02:08 AM
09/07/17 02:08 AM
AndyF Offline
AndyF  Offline
Looks nice and beefy which is what you want for a truck.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2366885
09/07/17 11:54 AM
09/07/17 11:54 AM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Hey Badeeds, those are SUPER nice. I almost wish I had known you were producing something like this instead of cutting down a Dakota rotor. What's the price on these?
Greg
PS. Are you the gent that hooked up a Toyota R154 to a Mopar 2.4L a few years ago?
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2366944
09/07/17 01:52 PM
09/07/17 01:52 PM
McKinney, TX
badeeds Offline
badeeds  Offline
McKinney, TX
Greg, I was thinking about $350 for the pair with studs and races installed. I have been real hesitant on selling because of liability. I have my first version on my truck giving real world test. I will soon have 3 other friends using them soon. They will have the version as pictured. The current version is a lot more beefy in the inter bearing and stud area. Couldn't do much on the out side since the rotor has to slip overit.I did add a male changer that matches up with female chamfer of rotor. Gives strength and keeps rotor centered.
Yes I am the one that mated the 2.4 to the R154.That vehicle is still not running.Hopefully next year. Life, (kid sports, moving, changing career, too many project, ect.....) Got in the way haha.
State of my 34 Dodge pu
