Page 4 of 4 1 2 3 4
Re: Lightweight battery [Re: sixpackgut] #2355539
08/17/17 04:39 PM
08/17/17 04:39 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I did not investigate how they test cca. It wouldn't mean much to me anyway. All I care about is will it start the car and stay charged from the alternator.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Lightweight battery [Re: Bad340fish] #2355596
08/17/17 06:22 PM
08/17/17 06:22 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Originally Posted By Bad340fish
Did they mention how the CCA number was achieved? Some of those companies reference a pulse CCA which is done on a 5 second scale as opposed to a 15 second test. The 25 amp hour seems low for the CCA but I am not familiar with the lithium stuff.
Most of the LI batteries like Joel mentioned are rated differently than normal lead acid car batteries. They stop the test when voltage drops to 10 volts on LI batteries as I recall, while SAE tests used on lead acid batteries normally run them all the way down to 7.2 volts.
Re: Lightweight battery [Re: sixpackgut] #2355667
08/17/17 08:54 PM
08/17/17 08:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mu Lithium battery weighs 10lbs and spins the motor over like nothing else ever has. I had two XS 16 volts in it and it was ok. Put in the single Lithium battery and it spins like nothing I have ever heard. That's a 605" BB with 60MM Babbit bearing, 15.8-1 compression and 1300+lbs of open valvespring pressure. In other words it takes a LOT of effort to spin her over.
Re: Lightweight battery [Re: Al_Alguire] #2355733
08/17/17 10:16 PM
08/17/17 10:16 PM
Nebraska
TT5 Valiant Offline
TT5 Valiant  Offline
Nebraska
Al, what Lithium battery are you using?
Re: Lightweight battery [Re: sixpackgut] #2355972
08/18/17 11:46 AM
08/18/17 11:46 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My current one is a Lithium Pros unit. There are a lot of lithium batteries out there for sure these days. I have heard good and bad about most. My best advice is buy a battery and charger from the same manufacturer and follow their directions religiously. They will go to "sleep" after sitting for long periods of time and some can be a PITA to "wake up". Been there done that..
Re: Lightweight battery [Re: sixpackgut] #2356485
08/19/17 11:46 AM
08/19/17 11:46 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Al,
Which which Lithium Pro battery are you using?
Thanks,
Bill
Re: Lightweight battery [Re: sixpackgut] #2356517
08/19/17 12:39 PM
08/19/17 12:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have an L1600A, the reason was the size it fits the battery box that is in the car, also have their charger.
Re: Lightweight battery [Re: Hemi_Joel] #2357717
08/21/17 05:54 PM
08/21/17 05:54 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Originally Posted By Hemi_Joel
Prices are coming down on the lithium. I just ordered an Antigravity ATX20 Battery for $369 with free shipping.
I'll let you know how it works out.
Right on the case it says something about max charge at 12A. How big of an alternator you running?
I was seriously looking into LiFePO4 batteries, until my Optima died on the road a few weeks ago and I replace it with a Deka AGM.
LiFePO4 is more stable that Li-Ion, and you can get batteries that have built in BMS and can take higher charge rates. The only downside was the reserve capacity...
Keep us posted Joel!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Lightweight battery [Re: sixpackgut] #2357719
08/21/17 06:00 PM
08/21/17 06:00 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I have a 105 amp alternator. I'm no electronical genius, but it is my understanding that the regulator keeps the voltage at a level that will not overcharge the battery. It won't generate enuff voltage to force 105 amps of current flow into a battery that only wants 12 amps.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Lightweight battery [Re: sixpackgut] #2358886
08/24/17 12:49 AM
08/24/17 12:49 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I just picked up one of these for my Sport Bike:
EarthX Batteries
It's stunning how light it is and how fast it spins my 12:1 750 "L" twin. Also, they have a built-in microprocessor that manages the battery.
Very happy with it and will be running one in the car in the future.
Mo' Farts
Moderated by "tbagger".
Re: Lightweight battery [Re: sixpackgut] #2359267
08/24/17 07:20 PM
08/24/17 07:20 PM
ccarson Offline
ccarson  Offline
I have a pair of 12V Odyssey PC925 Batterys wired in parallel they are 17# each, Dry Cell so they can be mounted on their side if needed,
around 150.00 eaCH
I do run a alternator and put them on maintainers when not in use.
Re: Lightweight battery [Re: Grizzly] #2359620
08/25/17 01:19 PM
08/25/17 01:19 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
EarthX Batteries
I was looking at the ETX1200 for my street car. I was close to pulling the trigger, but the battery died unexpectedly on a road trip, so now I have a new battery...haha
Re: Lightweight battery [Re: Triple Threat] #2361375
08/28/17 09:36 PM
08/28/17 09:36 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Originally Posted By Triple Threat
I'm in the process of building a new car and it will be getting a Lithium battery as well.
We have 1 local racer that has been running one on a sponsorship deal for about 2 years now in a street strip car with great success. It's a 14 volt battery and weighs 14 pounds. Standard alternator, but does take a "special" 10 amp charger that you can get for $35.
Do you know the name of the company? And it's 14 volts?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Lightweight battery [Re: 1967dartgt] #2361666
08/29/17 12:53 PM
08/29/17 12:53 PM
Renton Washington
Triple Threat Offline
Renton Washington
http://www.intellapower.com/220-project.html
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Lightweight battery [Re: sixpackgut] #2590484
12/11/18 06:03 PM
12/11/18 06:03 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
I thought I would resurrect this thread. What are the current thoughts on Lithium batteries? I am intrigued by the EarthX batteries for an NHRA Stock car, but was also considering a 16 volt system. I would be interested to here your experiences.
Thanks, Rod
Real Men shift for themselves
Re: Lightweight battery [Re: sixpackgut] #2590487
12/11/18 06:07 PM
12/11/18 06:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have been using a Lithium Pros battery and charger with zero issues. When I first made the switch I had a charger issue, they replaced the charger and battery free of charge. Very happy with it and NOTHING will crank your car over faster. I could not believe how much faster it was than the std XS 16 volt I had in the car.
Re: Lightweight battery [Re: sixpackgut] #2590511
12/11/18 06:49 PM
12/11/18 06:49 PM
AndyF Online content
AndyF  Online Content
I designed a small battery shelf for my Duster to hold a lightweight battery. It seems to work just fine. I used it during the summer in my Coronet and it spun the engine over just fine.
Re: Lightweight battery [Re: Bad340fish] #2590885
12/12/18 03:47 PM
12/12/18 03:47 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Simply put , if all the current required cannot pass through the circuit the cables will overheat and that heat ADDs resistance and reduces the current available to cover the load, it's all interrelated.
Generally though the Ground cable doesn't need to be as large as the Positive cable so long as the length is short and it has solid continuity/connection to the frame.
1/0 AWG welding lead is great cable for line/load connections, it is fine stranded and when used with Crimp connectors makes for a solid air tight connection for all the electrons to flow.
Especially with low voltage systems any resistance at all decreases the energy (current) available dramatically. It's not as much the size of the ground but more the quality of the ground.
WIZE
In Car:
Re: Lightweight battery [Re: Hemi_Joel] #2590931
12/12/18 04:58 PM
12/12/18 04:58 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Prices are coming down on the lithium. I just ordered an Antigravity ATX20 Battery for $369 with free shipping. 780 cca, 25 amp hours, under 5 pounds. It's getting mounted on the inside of the framerail, very close to the starter to save the weight and voltage drop of long cables. They said a standard alternator will charge it fine, as long as it doesen't discharge to under 10.5 volts. If it goes under 10.5V, it shuts off and a special charger is needed to wake it up. So I am putting a sensitive digital voltmeter in the car.
I have a 7 year old dyna-batt that is 14 pounds and will start a car, but I don't trust it 100%. So I will build the battery box to fit the anti gravity and the dynabatt, and bring the dyna for a spare.
OK, here is my update:
I installed the antigravity battery in my hot rod coupe, along with a 105 amp GM alternator. Then I did some street driving, a couple drag strip tests, then completed Drag Week 2018.
I love my little 4.5# AntiGravity battery! It performed flawlessly. With the powermaster starter, it cranked my 13:1, 468" hemi over like the plugs were out of it. Except one time it wouldn't start the car when I forgot the radiator fan on for about 40 minutes. It did not get low enuff to put the battery to sleep. If it does go to sleep, you need a special charger to wake it up. I brought the special charger along on Drag Week, plus a jumper pack that has a built in 110 volt inverter/outlet. So I could plug the charger into it and wake up the battery if it ever got ran that far down.
Not only did I save the weight of the battery, I saved about 20# of cable by mounting the battery a foot away from the starter on the inside of the frame rail, instead of in the trunk. The NHRA mandated battery cut off switch is right there too, with the lever of it on the floor inside the car where I can reach it if I forget to turn it on. A 3/8" x .030" wall stainless steel tube runs from the lever, back through the trunk and out the back of the car as a remote control for the switch. That is much lighter than a Morse cable.
Bottom line, I liked my battery so much, I started down the path of becoming a dealer for them. But their terms regarding liability and indemnification for dealers were unacceptable to me, so I passed on that opportunity, but I still love their battery's.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Page 4 of 4 1 2 3 4
