Re: Will this piston/stroke/rod length work? [Re: B1MAXX] #235541
02/26/09 05:37 PM
02/26/09 05:37 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Why not just use 7.1 rod 1.313 piston (3.75 stroke 400 shelf piston) and 4.5 stroke rb and deck the block for desired comp ratio?
Cuz I already have the pistons.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Will this piston/stroke/rod length work? [Re: Von] #235542
02/26/09 11:05 PM
02/26/09 11:05 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
6.8 rod 4.5 stroke deck for comp. ratio. Or do you have the crank too?
Re: Will this piston/stroke/rod length work? [Re: B1MAXX] #235543
02/26/09 11:30 PM
02/26/09 11:30 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Dont have the crank. But, if I decide to do the 4.5 stroke, I'll do like you say. Shouldnt be a big deal.
