Re: Small Block Sidewinder Heads FULL port work pics
[Re: MR_P_BODY]
#2345609
07/30/17 10:17 AM
07/30/17 10:17 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I have 2 sets going right now, first set is for a true street driver, so that will only be a bowl blend and valve job, with 2, maybe 3 different valves tested, with different angles, mods, from different manufactures.As an example, I actually found in the past, a valve that " shouldnt have been" better, was actually better in a set of RHS heads. By all rights, it should have been the worst flowing piece, and wasnt. Bowl/valve job will be how the head is most going to be used by the typical customer. I'll post that info when done. I am pretty sure with minimal work they'll push close to 300, but until I do that myself, I will only make assumptions based on what I know from others.When and if I ever get the time, I'd like to blow a set out and see what happens. They are a fantastic value, but dont confuse them for a set of W8's. they fall into a category of great replacement head, with a lot more potential than stock.
RIP Monte Smith
[Re: Prochargedmopar]
#2345704
07/30/17 02:14 PM
07/30/17 02:14 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""So whatcha got as a review? Like what you see?"" I just finished mocking up my Yella Terra 1.65 rockers on these Sidewinders. So far, the alignment looks good. Now I need to check for push rod clearance when my gaskets get here. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Stock valve covers are being glued to the Superformance valve cover gaskets. No problems with fitment.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
#2346222
07/31/17 02:56 PM
07/31/17 02:56 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: sasquatch]
#2346709
08/01/17 02:52 PM
08/01/17 02:52 PM
Prochargedmopar
Granbury TX
Yes, That is a cool idea. As close as we can get to being in the shop without dialing up a skype call. lol
More work being done. I'm most curious about the chamber work, if any, that will be done. Time will tell.
[Re: Rob C]
#2347552
08/02/17 11:03 PM
08/02/17 11:03 PM
YO7_A66
Indiana
""I can't see the Flow chart""
This is a partial of the Promaxx casting.
[Re: YO7_A66]
#2347950
08/03/17 03:41 PM
08/03/17 03:41 PM
dogdays
I looked at Summit and found that a bare pair of smallblock promaxx heads for LA engines is $1100. $1400 will get you an assembled pair. $1525 will get you assembled and hand bowl blended.
No word in the catalog if they have been checked out or as assembled.
I don't need more flow than what they have stock, so no need for porting.
I hope the Sidewinders aren't as expensive.
R.
[Re: dogdays]
#2347977
08/03/17 04:23 PM
08/03/17 04:23 PM
Posts: 2,094 central texas
krautrock
central texas
R. hand bowl blended and assembled with hydraulic springs for $1300 ($100 off) at jeg's. http://www.jegs.com/i/ProMaxx-Performance/723/9360/10002/-1i think these heads should be the ones on the flow sheet posted earlier and the same that Pittsburghracer posted the thread about a while back.
[Re: krautrock]
#2348033
08/03/17 06:24 PM
08/03/17 06:24 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Since PhotoBucket did their little "hissy fit" a lot of old posts are lost without pictures. I will tell to update this post when I get a chance with pictures loaded from another photo site. https://board.moparts.org/ubbthreads/ubbt...ad-testing.html
[Re: dogdays]
#2348426
08/04/17 01:57 PM
08/04/17 01:57 PM
Prochargedmopar
Granbury TX
Sidewinders from mopartsracing.com
$895 with valves $1249 complete with comp cams springs/retainers/valve job/assembled/etc.
#2354346
08/15/17 04:57 PM
08/15/17 04:57 PM
Prochargedmopar
Granbury TX
Final product, Waiting on a call from Todd for payment link and to see when they will ship.
#2354379
08/15/17 06:17 PM
08/15/17 06:17 PM
Prochargedmopar
Granbury TX
My perspective is such that these heads will be perfect for my application. Street/Some strip use in a fairly heavy 3400# vehicle and some BOOST! Gonna make my short block whine line a little baby. hahahah Compared to the best factory Cathedral port heads they do pretty good. I know I could have matched the chevy head flow #'s with some moderately ported EQ's for $1500 but then I'd still have Iron heads and no WOW factor being mine were ported by Larry Smith. Here is some GM head data for reference.
