Re: New Six pack fuel lines leaking
[Re: 340SIX]
#2355627
08/17/17 07:42 PM
08/17/17 07:42 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Wow those are kool where can one get them? Posted above by 62maxwgn Flare a piece of 5/16" copper tubing,cut off the flare,insert in fuel inlet fitting and no more leaks.
I have mechanical Aptitude. I can screw up anything.
[Re: DAYCLONA]
#2355696
08/17/17 09:34 PM
08/17/17 09:34 PM
Posts: 9,896 MI, usa
dvw
MI, usa
I'll use either a teflon paste or grease to lube the threads so that they help seat the flare and prevent galling of the threads, using a tube wrench instead of a "regular" wrench will also prevent you from "egging" the flare nut causing leaks by making it harder to fully seat the tube nut sealing the flare, stainless or steel I have used this method for 20+ years. Sounds wrong, but it works. I can't explain why it works except for the lubrication properties. A dab, not a blob, on the threads and flare. I didn't believe it when I was told either. One night as a last resort I tried it. Made a believer out of me. No leaks ever. Doug
[Re: Challenger 1]
#2355902
08/18/17 06:25 AM
08/18/17 06:25 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I ran into that issue last year when I was putting my T/A together. My lines were leaking like crazy at the carbs, and nothing seemed to help, until my engine builder told me to put some grease on the threads before installing the lines. I never thought that would work, but was running out of ideas. Greased the threads up with red grease, installed and tightened them, fired up the engine, and dry as a bone! ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Grease or oil is best and should always be used on flare fittings to allow you to get them tight. IMO never use teflon tape anywhere on a fuel system, never. Because it is near impossible to get all the little pieces out when you take it apart. Plus it looks like sh!t and tells everyone you don't understand flare fittings. I tried thread greasing on my six pack lines, still had 2 fitting that leaked. Perhaps fittings are a bit worn as must undo them each time I wish to remove carbs. Any six pack owner understands this dilemma. Teflon tape relieved immediately. Have never a problem easily removing it. As I happen to use an use an air cleaner, impossible to see any teflon tape on fittings. Leaking fuel lines are a more certain sign that someone does not know what they are they are doing,,,,not to mention the risk of burning the vehicle down. To each their own
[Re: glenngomango]
#2355907
08/18/17 07:57 AM
08/18/17 07:57 AM
Posts: 2,473 Answering the call of the wild
ThermoQuad
Typical moparts...the experts weigh in with good advice and you guys kick them with your cave man automotive fixes and opinions. The only reason I am even attempting to help the uninformed is to keep you guys from giving the six pak more negative internet BS. We give you a "procedure" [tuning guide] and you can't even take the time to read it, but you come on here & expect one of us to just give you that quick answer to the quick question. For free no less. When you install 6 pak fuel lines all the lines need to be installed together and tightened simultaneously. The lines are leaking because the flare end is not seating against the seat on the fitting. DOH!! Teflon tape on the threads does not seal anything. Lubricating the nut threads and the between the nut and tube will allow the nut to turn and not grab the tube when tightening. You need QUALITY flare wrenches as well. A properly tuned six pak will outrun it's 4bbl equal... ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif)
[Re: TJP]
#2356079
08/18/17 03:10 PM
08/18/17 03:10 PM
Sxrxrnr
Northern Calyfornua
I am well aware of the sealing mechanism of how flared fuel lines do their business.
Again I repeat that I have had circumstances where lubrication of threads(this is not exactly new science in automotive repairs,,,every Model T shade tree mechanic understood this) has not resolved a leak, where teflon tape has.
Have any of the experts considered the possibility that perhaps the teflon tape itself serves the purpose of lubrication of the threads more effectively than mere oil or grease that gets squished out of the threads because of the intense pressure generated per square inch as the fitting is increasingly tightened,,,,whereas the structure of the tape's chemistry maintains its lubricating capabilities no matter how much pressure is generated?
I thought not! I do not necessarily subscribe to my anecdotal guess on this,,,perhaps one of our members with expertise in this science might chime in.
I have already agreed that perhaps effectiveness of my fittings and/or line flares may be below perfection.
As an aside as a six pack owner,,,,I have several times referred to and read well the "white" paper on six pack tuning,,,,still does not make me an expert, just as I am not on Rochester fuel injections with which I am familiar,,,but have learned much of value,,,just as reading many great books on tennis or golf does not make us great players. However cannot remember ever reading a single one of those books where the reader was belittled as not ready to go on the tour because they are not as expert as the author.
![Name: 678E2201-2101-4C8F-8D3E-8CFCE2FC804E.JPG
ID: 294854 678E2201-2101-4C8F-8D3E-8CFCE2FC804E.JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/294854/filename/678E2201-2101-4C8F-8D3E-8CFCE2FC804E.JPG)
[Re: Sxrxrnr]
#2356150
08/18/17 05:17 PM
08/18/17 05:17 PM
Posts: 15,567 Omaha Ne
TJP
Omaha Ne
[Re: Sxrxrnr]
#2356192
08/18/17 07:04 PM
08/18/17 07:04 PM
Challenger 1
Cincinnati, Ohio
Yea teflon tape provides lubrication and anti seize properties. But like I said above it leaves many pieces of tape inside the fittings when removed and is not good to use around auto fuel systems. And teflon tape in this case provides no lubrication between the sleeve nut and the back of the flare where it is needed most like pointed out above. Got to read what is posted. Grease or oil has no harmful effects to the fuel system if it gets inside. And yes tubing wrenches are used, didn't even think I had to point that out since it was posted above already. I do not use copper flare washers but can understand how they might be beneficial in some cases. But they reduce the thread engagement if used and doubles the places for it to leak like pointed out above. Type R copper would be best because it is thinner than type L soft copper tubing. Would I buy them somewhere? No This how you make them like what was said above. That groove in your tubing cutter is for cutting off the least amount of tubing if your tubing is flared already. Not really for making flare washers. The only time I have put something between my flare fittings is a cone screen to protect against dirt, not to help seal it.
[Re: Challenger 1]
#2356206
08/18/17 08:15 PM
08/18/17 08:15 PM
Posts: 10,778 North Dakota
6PakBee
North Dakota
I'll throw in my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I can't find where the original poster said he was using stainless or steel lines. The corrective action is the same regardless. If the fittings are leaking, unless the machining on the fittings is poor, the tubing flare is defective in some way. Otherwise the fitting wouldn't be leaking. I have a selection of stainless steel female fittings and with a GOOD tubing wrench and lubrication on the nut, I tighten the bejesus out of them. This re-forms the flare on the tubing so it will seal. Never failed me yet. As a note, I've only used stainless lines one time (brakes) and never again. I had to tighten them so tight to stop them from leaking I was afraid I would either strip the fitting or gall it. Again, just my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) , feel free to do whatever turns your individual crank.
[Re: 6PakBee]
#2356217
08/18/17 08:33 PM
08/18/17 08:33 PM
Challenger 1
Cincinnati, Ohio
I'll throw in my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I can't find where the original poster said he was using stainless or steel lines. The corrective action is the same regardless. If the fittings are leaking, unless the machining on the fittings is poor, the tubing flare is defective in some way. Otherwise the fitting wouldn't be leaking. I have a selection of stainless steel female fittings and with a GOOD tubing wrench and lubrication on the nut, I tighten the bejesus out of them. This re-forms the flare on the tubing so it will seal. Never failed me yet. As a note, I've only used stainless lines one time (brakes) and never again. I had to tighten them so tight to stop them from leaking I was afraid I would either strip the fitting or gall it. Again, just my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) , feel free to do whatever turns your individual crank. I know about stainless lines, they are hard as heck and hard to get sealed. But not only that, but since you have to tighten them so tight the first time, the second time could be even tougher to get them to seal because the seat is indented from the hard stainless and sometimes they don't go back together exactly the same as the first time. Mild steel on brass is the best sealing combo and longest lasting imo. Stainless is more prone to cracking because it is so hard.
[Re: Porter67]
#2356665
08/19/17 05:40 PM
08/19/17 05:40 PM
Sxrxrnr
Northern Calyfornua
Reading your posting reminded me that I too likely have stainless repro's that is the root to my unique difficultly in ensuring a good seal. And the comments from others posting reminded me of the problems caused by using stainless tubing with braking systems,,,which I have on my 59 Vette with disc brakes which has always been a problem with only one caliper. It is generally believed by many that stainless brake lines can be a real bear and strongly advise usage. No reason why the same could apply to fuel lines. Likely why the copper solution as recommended by earlier postings has worked well, as copper and even steel are far more malleable than stainless and will conform and accommodate idiosyncratic fittings better.
When first installed on my Six Pack, I experienced no leaks. It was only subsequent R&R's where I had problems. The first time seal likely made male and female 'conform' but subsequent R&R's were unable no matter how tightly cinched were unable to undo the original 'set' and adjust to a new set as female and male matings were not exactly the same,,,,even though I would carefully before tightening of ferrules 'wiggle' fuel lines within them about as I tighten them to ensure an exact mating. Yes I do use only the correct flare wrenches.
The next time I have fuel lines removed, I will examine very closely brass connectors and lines.
Using a magnet, I just now checked the lines and ferrules on the theory that some stainless, not all is magnetic just as regular steel. Lines and ferrules both are magnetic so still do not know if steel or magnetic stainless. However as brass is likely softer than either, will be curious to find if any damage preventing proper mating is in the brass fitting itself. Again copper being softer than steel or stainless it could conform to brass and accommodate ok.
The advice on greasing behind the flare on the line is well taken,,,,even when using my teflon tape approach. When using the lubricant approach I do lube this area,,,,but have been negligent in doing so when forced to teflon solution.
