Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235145
02/26/09 09:05 PM
02/26/09 09:05 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
for some reason thump, i still think you have a vac leak somewhere. just my
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235146
02/26/09 09:06 PM
02/26/09 09:06 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i have a camera on my guages.
Re: Last question(for a while) how to set fuel pressure???? [Re: n_bogie1984] #235147
02/26/09 09:15 PM
02/26/09 09:15 PM
State of confusion
Thumperdart Offline OP
State of confusion
I don`t know about a vac leak it idles way too smooth and doesn`t surge. The video idea is a good one maybe we`ll try that next. Thankxx....
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235148
02/26/09 09:23 PM
02/26/09 09:23 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
hey dom i like chris at continental,ive had 3 of his converters,everytime we pulled out converter and made changes,had no effect.did this many times.i wont go back to chris,hes a great guy,i just dont think his stuff works welll with mopars.
Re: Last question(for a while) how to set fuel pressure???? [Re: 2QUICK4U] #235149
02/26/09 09:32 PM
02/26/09 09:32 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
seen it many many times, 3/4 way down track it just lays over.and he was using 99's drilled out. was a intake leak. 99's in my eyes is way to much. ive even seen hair line crasks in a intake that leak when they under stress/heat, cause this. not trying to say your wrong but my
Re: Last question(for a while) how to set fuel pressure???? [Re: n_bogie1984] #235150
02/27/09 02:37 AM
02/27/09 02:37 AM
State of confusion
State of confusion
Anythings possible I guess........This may be something I look into now, if I can only get one of my friends to spray carb cleaner around the intake at 132+mph.
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235151
02/27/09 01:56 PM
02/27/09 01:56 PM
That rascal is either to fat or running out of fuel in high gear above 5000 rpm
Re: Last question(for a while) how to set fuel pressure???? [Re: Cab_Burge] #235152
02/27/09 04:31 PM
02/27/09 04:31 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What are the signs of being too fat in high gear?
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235153
02/27/09 07:01 PM
02/27/09 07:01 PM
State of confusion
State of confusion
A buddy of mine said I could have a aeromotive 1000 pump and was curious if I could deadhead it for now at the track just to see if my deal is fuel related. He said he did for a couple years race only......how bout any of you?
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235154
02/27/09 07:02 PM
02/27/09 07:02 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats a lot of pump to be dead headed, I wouldn't do it.
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235155
02/27/09 07:04 PM
02/27/09 07:04 PM
2QUICK4U Offline
2QUICK4U  Offline
THATS A GOOD IDEA,TRY THE PUMP,I DONT THINK ITS A FUEL PROBLEM.HOW FAR APART WERE YOUR PASSES,HOW MANY CARS WENT DOWN THE TRACK BEFORE YOU?JUST WONDERING IF YOUR 1ST PASS WAS WITH FRESH VHT,AND PASSES LATER WERE JUST WITH THE RUBBER ON TRACK? PLUS WHAT ABOUT WEATHER CONDITIONS,HOW MUCH DID THE DA CHANGE?
Re: Last question(for a while) how to set fuel pressure???? [Re: emarine01] #235156
02/27/09 11:33 PM
02/27/09 11:33 PM
It is lazy in high gear, the safe way to make sure is to increase the jet sizes one or two sizes on the Holleys and if the car slows down you know you have enough fuel delivery to slow the car down. Once that test is done then try one or two sizes smaller than what it had before jetting it up and see if the MPH goes up, if it does then jet it down some more, a little at a time until it starts to lose MPH
Re: Last question(for a while) how to set fuel pressure???? [Re: Cab_Burge] #235157
02/27/09 11:40 PM
02/27/09 11:40 PM
State of confusion
State of confusion
Cab, when I was at Irwindale we richened the hi-speed bleeds and the car picked up and ran back-to-back 6.22`s at 109+mph w/ 1.36 60 ft`s. So, I have not been able to fatten it up to slow it down yet so who knows but, I was able to fatten it up on the chassis dyno enuff to loose 30hp.
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235158
02/27/09 11:58 PM
02/27/09 11:58 PM
The chassis dyno is not the track, no air being forced into the scoop time for more testing, come to the MATS race and test,test, test and test some more
Re: Last question(for a while) how to set fuel pressure???? [Re: Cab_Burge] #235159
02/28/09 01:42 AM
02/28/09 01:42 AM
State of confusion
State of confusion
I`d like to but there`s no way my tow can leave his wife for that long.
