Leaking Head Bolt #2347912
08/03/17 03:03 PM
08/03/17 03:03 PM
Rio Linda, CA
John_Kunkel Offline OP
Rio Linda, CA
Finally got around to firing my friend's 511 on a 400 block motor. When adding coolant for the first time the head bolt circled in the pic below started to leak coolant; after firing the motor and running for 20 minutes it continued to leak but stopped leaking for a while after shutdown. Still has a slow leak when cold.
The heads are Stealth, the head bolts are ARP. I checked all my other blocks and this bolt hole (or any other) doesn't extend into the water jacket. No coolant leaks externally from the head gasket or into the combustion chamber. And, of course, the header flange prevents getting a wrench on the bolt but I torqued them myself to ARP specs/procedures.
Has anyone ever found a head bolt hole that is wet? Any history of Stealth heads cracking in that area? The block is from a '72 D-100.
Re: Leaking Head Bolt [Re: John_Kunkel] #2347921
08/03/17 03:10 PM
08/03/17 03:10 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
My guess is a crack in the head.
Re: Leaking Head Bolt [Re: John_Kunkel] #2347942
08/03/17 03:36 PM
08/03/17 03:36 PM
with it dripping before it was even fired I would think badly warped head/block/bad head gasket letting coolant bleed over from a nearby coolant hole since we're thinking the bolt hole is blind.
Re: Leaking Head Bolt [Re: John_Kunkel] #2347952
08/03/17 03:43 PM
08/03/17 03:43 PM
After rereading this, what R3 said, a cracked alum head sounds more likely.
Re: Leaking Head Bolt [Re: John_Kunkel] #2347965
08/03/17 04:04 PM
08/03/17 04:04 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
My RB has a 1/4" hole in the corners[by the locating dowel ] and 1 time I forgot to rtv them and a leak like yours was the result but by the gasket.
Re: Leaking Head Bolt [Re: John_Kunkel] #2347971
08/03/17 04:14 PM
08/03/17 04:14 PM
P
Porter67 Offline
Porter67  Offline
P
Id re torque and run a bottle of ceramic sealer through it myself or re torque and heat cycle it a few times with no rad cap on so not to pressurize the system and see if it works itself out but would watch the oil as well.
Sharp looking project.
Re: Leaking Head Bolt [Re: John_Kunkel] #2347989
08/03/17 04:40 PM
08/03/17 04:40 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Stealth...as in 440 Source Stealth? How old are they...as in when did you order them? I had three crack, in that same exact location, and if thats the case they're junk.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Leaking Head Bolt [Re: A39Coronet] #2348015
08/03/17 05:42 PM
08/03/17 05:42 PM
Rio Linda, CA
Rio Linda, CA
Yeah, 440 Source Stealth; that's disconcerting, this set was in the first batch sold about 8 years ago (project had many delays).
A39Coronet, did the cracks manifest themselves as head bolt leaks?
Re: Leaking Head Bolt [Re: John_Kunkel] #2348043
08/03/17 06:39 PM
08/03/17 06:39 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Might get lucky with a stop leak to see if any effect. Permanent is another question. Probaly best to pull the head. Could it be head gasket close to cooling port in block/head?
Re: Leaking Head Bolt [Re: John_Kunkel] #2348084
08/03/17 07:49 PM
08/03/17 07:49 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Is that a 33 Willies?Tell me more.
Re: Leaking Head Bolt [Re: Sxrxrnr] #2348085
08/03/17 07:50 PM
08/03/17 07:50 PM
God's Country Maryland
GODSCOUNTRY340 Offline
John, just remove that bolt and wrap threads with teflon tape. If it still leaks after that you've got a head problem. Also, make sure it's not leaking from that header stud/bolt above it. Some of those are wet holes and if not sealed they can leak, run down the inside of the header flange onto the head bolt and make it look like a head bolt leaking.
Re: Leaking Head Bolt [Re: John_Kunkel] #2348089
08/03/17 08:03 PM
08/03/17 08:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I would use K Seal in it. It is a special coolant sealant that is different than Barrs Leak which may work also. Just not as permanent as K Seal.
Plus K Seal is made for cracked engines and has saved many motors.
I have a retired mechanic friend who years ago suggested I use it in a cracked 4 cyl forktruck motor and it sealed it up for another 15 years of use.
K seal check it out. It is used/applied differently than Barrs Leak too, heads up.
Re: Leaking Head Bolt [Re: John_Kunkel] #2348159
08/03/17 10:30 PM
08/03/17 10:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The Stealths exh holes are all dry.Mine have been on since the first run.never a problem.What head gaskets did you use.I know the first sets had a chamber problem.I run Fel Pro marine gaskets.Rocky
Chrysler Firepower
Re: Leaking Head Bolt [Re: John_Kunkel] #2348209
08/03/17 11:39 PM
08/03/17 11:39 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Yup, first batch had a big cracking issue. Mine also originated at that same bolt location, and leaked as soon as it got any temperature. They replaced mine, and I finally got them to send me a set of Edelbrock Victor's (I paid the difference), and have been running them ever since.
Take some pics as it sits now, and then more when you yank the heads off. Hopefully your friend has the documents showing when they were purchased, maybe 440 Source will determine they were part of the bad batch and stand behind them. Then, replace them with Edelbrock RPMs (they are an Edelbrock dealer) or another American Made SR head. Don't bother trying any "fix", besides trying to get a refund.
I was very grateful that they worked with me, and continue to buy "certain" things from them...just not heads or rotating assemblies.
Re: Leaking Head Bolt [Re: John_Kunkel] #2348230
08/04/17 12:32 AM
08/04/17 12:32 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
440 source has fixed the problem, it would be nice to just get some replacement 440 source heads.
Re: Leaking Head Bolt [Re: CSK] #2348240
08/04/17 12:43 AM
08/04/17 12:43 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I think in this case it depends on how they fix the issue. If they replace them, sure, use them. But if they say "no, sorry, it's been too long"...would you want to send them another $1000, simply out of principal?
Re: Leaking Head Bolt [Re: A39Coronet] #2348247
08/04/17 12:54 AM
08/04/17 12:54 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I agree, I was saying if they warranty the defective ones.
Re: Leaking Head Bolt [Re: John_Kunkel] #2348283
08/04/17 02:31 AM
08/04/17 02:31 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Part of the cracking problem with the first gen heads so I've been told was the holes for the dowel pins weren't machined deep enough. When the head was torqued the pin bottomed out before the gasket fully crushed.
If those are some first gen heads that's probably what happened.
Maybe some talent with a TIG welder can save them if you can't get warrantee but I think if you use the right approach they might give you some help. My dealings with Brandon were always positive. I'm assuming he still owns the place.
I know it's a pain but I would confirm with Source if what I heard/read on here was true and if so, pull the other head and measure the dowel pin depth and correct if necessary. Just because it hasn't cracked yet doesn't mean the headbolt stress prying on it won't crack it later.
Kevin
Re: Leaking Head Bolt [Re: A39Coronet] #2348484
08/04/17 03:16 PM
08/04/17 03:16 PM
Rio Linda, CA
Rio Linda, CA
Well, after we got the header off you could see the hairline crack from the spark plug hole to the bolt hole.
My friend called 440 Source and they acknowledge that the first batch was bad, they replaced them free for 4 yrs. but that's long past so they offered to sell him a new pair at cost....he's gonna go that way.
Re: Leaking Head Bolt [Re: John_Kunkel] #2349902
08/07/17 03:06 AM
08/07/17 03:06 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Have them thoroughly checked and corrected, guide clearance, dowel pin depth, fix the valve job and do some housecleaning in the bowls and they should serve him well.
I've heard the seat inserts need to be blended into the bowls and IMHO there is no such thing as a mass produced performance valve job so correcting those things should get them to at least flow advertised numbers.
Nice that after 8 years they offered some assistance.
Kevin
