Re: Out of the blue - backfiring through carb while accelerating
[Re: 1968RR]
#2349282
08/06/17 01:42 AM
08/06/17 01:42 AM
RapidRobert
that's what we are here for & everything I know (& am still acquiring) has come from 13 yrs here on Moparts (as an ex employee of Speedway motors I did not learn a single thing there!)
[Re: RapidRobert]
#2349308
08/06/17 03:16 AM
08/06/17 03:16 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
I've had plug wires do this
NS1AAR
[Re: Andrewh]
#2349529
08/06/17 03:46 PM
08/06/17 03:46 PM
Posts: 15,569 Omaha Ne
TJP
Omaha Ne
A lot more info would be helpful, Accelerating ? From a dead stop, cruise, part throttle, WOT etc. What RPM range ?? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: TJP]
#2349552
08/06/17 04:38 PM
08/06/17 04:38 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I just pulled the carb and the pump diaphragms and bowls both look good. When reassembling the carb, I noticed that the rubber vacuum cap on the small base plate port under the front bowl was cracked and likely was causing a small vacuum leak. Could this have been the culprit?
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: TJP]
#2349555
08/06/17 04:39 PM
08/06/17 04:39 PM
1968RR
A lot more info would be helpful, Accelerating ? From a dead stop, cruise, part throttle, WOT etc. What RPM range ?? Part throttle from a dead stop. It hasn't been consistent enough for me to check the RPMs, but I'd estimate between 2500 and 3500.
[Re: 1968RR]
#2349563
08/06/17 04:45 PM
08/06/17 04:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I just pulled the carb and the pump diaphragms and bowls both look good. When reassembling the carb, I noticed that the rubber vacuum cap on the small base plate port under the front bowl was cracked and likely was causing a small vacuum leak. Could this have been the culprit? Quite possibly, especially if you were already borderline lean, either due to jetting or ethanol content.
[Re: 1968RR]
#2349587
08/06/17 05:41 PM
08/06/17 05:41 PM
Challenger 1
Cincinnati, Ohio
I just pulled the carb and the pump diaphragms and bowls both look good. When reassembling the carb, I noticed that the rubber vacuum cap on the small base plate port under the front bowl was cracked and likely was causing a small vacuum leak. Could this have been the culprit? Possible, but when I get backfire out of the carb under load it means my spark plugs are dirty. Some times I bead blast mine clean, once. Then I need new ones. Vacuum leaks cause backfire on decel most times. My plugs used to last for years until I hooked my manual choke for warm up. If I am not careful I will foul out a plug or two if I use the choke too long and get a little back fire out of the carb under load. Fresh plugs it is running clean again. 1500 miles? plenty of time to partially foul a plug ...IMO. If you did not find any other reason. Did you actually pull those 1500 mile plugs to be sure?
[Re: 1968RR]
#2349628
08/06/17 06:59 PM
08/06/17 06:59 PM
1968RR
I replaced the cracked port cap and took the car out for a short drive, and there weren't any backfires. Of course, that doesn't mean that the issues is resolved, but it is a little encouraging.
I pulled the #2 and #6 plugs (as sort of a spot check) about a month ago, and both of them looked good. But if the backfiring persists, I'll go ahead and replace the plugs since I have a new(ish) set lying around.
[Re: Kern Dog]
#2351080
08/09/17 12:43 AM
08/09/17 12:43 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I would do a compression check to see if there is any excessive variance between cylinders. When a camshaft lobe starts to fail, it is often an exhaust lobe. When THIS happens, the exhaust looks for any exit it can find. Sometimes under heavy throttle, the exhaust gets pushed up through the intake valve and into the intake manifold. I've had a pushrod through the exhaust rocker arm do the same thing.
