Re: Oil change and now no oil pressure!
[Re: 500ciBee]
#2347494
08/02/17 09:48 PM
08/02/17 09:48 PM
Posts: 136 Ontario, Canada
500ciBee
Ontario, Canada
I pulled the driver side valve cover off and found that I'm missing the #5 intake pushrod. Haven't taken the intake off to see where it went. I guess the lifter popped out and the pushrod went into the pan. I hope to get a better look this weekend. It has a wet sump stock oil system!
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
[Re: 500ciBee]
#2347544
08/02/17 10:56 PM
08/02/17 10:56 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Well..... With a lifter missing..... It won't have pressure.
I guess the real question now is...... Why did that happen?
[Re: TJP]
#2347644
08/03/17 12:29 AM
08/03/17 12:29 AM
RapidRobert
^^^ agreed, we're here to help, not to dump on people. what 68Plymouth said, now we gotta find what caused it to jump out.
[Re: 500ciBee]
#2347735
08/03/17 08:46 AM
08/03/17 08:46 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Didn't the OP originally mention something about atunnel ram swap at teh same time as well?
I seem to recall that
[Re: 500ciBee]
#2347772
08/03/17 11:13 AM
08/03/17 11:13 AM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
Definitelly a missed lifter of the bore will drop the oil pressure BTDT. We can't say the missed pushrod will mean a lifter out of the bore ( I have bent some pushrods being out of its place and lifter still kept in place ), but it could be.
With a new oil pump, definitelly needs to pack up the pump rotors with grease or oil, but if it was already running, is not necesary
[Re: 500ciBee]
#2347876
08/03/17 02:13 PM
08/03/17 02:13 PM
fast68plymouth
So. Burlington, Vt.
IMO, the two "most likely" scenarios for the pushrod coming out are.....
-if it has adjustable rockers, the adjuster backed off until the pushrod fell out.
-the pushrods are not quite up to the job at hand, and one of them crumpled under the stress
[Re: 500ciBee]
#2347886
08/03/17 02:26 PM
08/03/17 02:26 PM
500ciBee
Ontario, Canada
Before the oil change everything was fine,or so I thought. I had no idea that something was wrong before the oil change. Had oil pressure and the engine was running well. I warmed the engine up before changing the oil and it seemed normal. After the oil and filter change is when I had no oil pressure. This was a routine oil change. I've never had anything like this happen before.
[Re: tman]
#2347945
08/03/17 03:38 PM
08/03/17 03:38 PM
RapidRobert
Mr Murphys' handiwork, luckily he don't show up very often but he don't play when he does.
[Re: Sxrxrnr]
#2348127
08/03/17 09:43 PM
08/03/17 09:43 PM
Posts: 15,469 Omaha Ne
TJP
Omaha Ne
Providing all was well before the oil change as stated the only way I could comprehend this happening is A. the pushrod just happened to snap or bend at that particular time. B. the lifter, if hydraulic may have collapsed enough before oil pressure pumped it back up. I do find it a bit strange and even more so that the lifter jumped out of the bore unless one was winging it which is unlikely. Finding the push rod may help determine the cause.
[Re: TJP]
#2354820
08/16/17 01:11 PM
08/16/17 01:11 PM
500ciBee
Ontario, Canada
I found the problem! The lobe is wiped and the lifter is trashed. Must have been like this for awhile. Not sure if it was coincidence that after the oil change that the lifter wore through and collapsed the lifter and the pushrod fell out. New cam, bearings, lifters and pushrods I guess are in my future. Is it worth the effort to pull the motor out or do in car swap of the cam?
[Re: 500ciBee]
#2354830
08/16/17 01:25 PM
08/16/17 01:25 PM
Posts: 608 TN
1DGEMAN
TN
The best solution is pull the engine and clean all the debris out of it. There is a lot of metal floating around just waiting to cause problems.
Good luck.
Real Men shift for themselves
[Re: 1DGEMAN]
#2354840
08/16/17 01:38 PM
08/16/17 01:38 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Good luck. Or there is already a lot of metal lodged in the bearings and piston skirts b/c you don't know how long this has been going on. Hopefully it isn't chewed up too bad.
