Re: Aluminum wedge block
[Re: moparmafia]
#2349400
08/06/17 12:24 PM
08/06/17 12:24 PM
Posts: 19,410 Las Vegas
Al_Alguire
Las Vegas
Well good thing I don't have really high power, that's a relief.
[Re: Al_Alguire]
#2349624
08/06/17 06:50 PM
08/06/17 06:50 PM
Posts: 43,385 Bend,OR USA
Cab_Burge
Well good thing I don't have really high power, that's a relief. Yeah, right ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif)
[Re: Al_Alguire]
#2349795
08/06/17 11:27 PM
08/06/17 11:27 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Last I checked not many here are chasing ever last little HP..Trust me aluminum is the way to go unless you are one of those Comp, Pro Stock or Nascar guys on here... I guess it's time for me to research the subject a little deeper... you guys have done surprisingly well with an aluminum block... and definitely headed in the right direction... I was never one that thought N/A and aluminum blocks went together in the same subject... 100 lb lose on my car would be huge... time for me to do homework I guess.. I guess number one question would be how would the car work..being 100 lb lighter on the nose.. that will be my starting point..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: moparmafia]
#2350028
08/07/17 01:20 PM
08/07/17 01:20 PM
Al_Alguire
Las Vegas
Shiloh you will end up like us. Moving EVERYTHING in the car back up front. We have moved literally everything, there is nothing left on the back of the car these days. We are at 54/46 after all the work. But it is a very short wheelbase car that is EXTREMELY sensitive to weight. BUT IMO the block is well worth its weight ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Building ANY racecar as light as possible allowing the weight to be moved to where it will best help the car work is the key. We are now no longer the wheelie king of the class putting it on the bumper round after round. FWIW we laso have an aluminum block in my Stratus and Dragster, had one in the Cuda too, but they don't make big power anyway... Birdtracker interesting FBS set up there. Be anxious to see how it works for you.
[Re: birdtracker]
#2350152
08/07/17 04:17 PM
08/07/17 04:17 PM
Posts: 409 Texas
mprhound
Texas
I will be trying out my first aluminum block soon. Birdtracker Have you run the fbs heads before? I have a motor going together with a set, just picked up a hogan sheet metal intake for them
[Re: birdtracker]
#2350219
08/07/17 06:02 PM
08/07/17 06:02 PM
Posts: 568 Ky
moparmafia
Ky
I will be trying out my first aluminum block soon. Birdtracker What heads are those?
[Re: moparmafia]
#2350309
08/07/17 09:28 PM
08/07/17 09:28 PM
Superfreak
Superfreak
It's to bad that the compacted graphite blocks are not floating around.
[Re: moparmafia]
#2350658
08/08/17 12:42 PM
08/08/17 12:42 PM
Al_Alguire
Las Vegas
Compacted graphite blocks are EXTREMELY heavy. The heaviest block I ever have picked up was the spare 99 Hemi block we had. It was a very short deck block with one side of the skirt milled away. No one likes machining them as they are hard on equipment too. FWIW my 99 Hemi ready to race, carbs to pan weighed in at 885lbs! For comparison my aluminum B1 is 525lbs
[Re: moparmafia]
#2351806
08/10/17 12:13 PM
08/10/17 12:13 PM
Al_Alguire
Las Vegas
He is a good guy and likely has more experience with them than most anyone else does for sure.
[Re: Al_Alguire]
#2352071
08/10/17 08:37 PM
08/10/17 08:37 PM
Cab_Burge
FWIW my 99 Hemi ready to race, carbs to pan weighed in at 885lbs! For comparison my aluminum B1 is 525lbs Al, how much HP and torque differences between the two motors? My thinking that a lot of the fast full chassis cars needing more front weight on them like you found out wouldn't mind the extra weight of a iron block up front, maybe not ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
[Re: Al_Alguire]
#2352145
08/10/17 10:36 PM
08/10/17 10:36 PM
Superfreak
Superfreak
Compacted graphite blocks are EXTREMELY heavy. The heaviest block I ever have picked up was the spare 99 Hemi block we had. It was a very short deck block with one side of the skirt milled away. No one likes machining them as they are hard on equipment too. FWIW my 99 Hemi ready to race, carbs to pan weighed in at 885lbs! For comparison my aluminum B1 is 525lbs in doing a little reading on the blocks, it was stated the blocks can be lightened a fair bit and still have a lot of strength. It also stated that the correct tooling is readily available but since milling speeds require half the rpm and half the feed speed the machining costs are probably 3 times then grey iron. OK Al.....you talked me out of it.
