Re: Anybody run a 1050 4150?
[Re: viperblue72]
#2347358
08/02/17 03:34 PM
08/02/17 03:34 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My fixture flows carb bodies one barrel at a time..... Which isn't really correct either........ But unless you have a 1200cfm bench...... You do what ya gotta do.
For an approximate wet flow number, I take the dry flow and use .92 of that.
Flowing one barrel at a time, and using the 92% number, an original Holley HP950 (1.375 x 1.750) flows about 860cfm. Traditional Holley 650's, 750's, 850's(with the chokes) come out pretty close to their respective ratings when tested that way. The same cannot be said for most of what I'll call the "new design" carbs.
[Re: BradH]
#2347390
08/02/17 04:42 PM
08/02/17 04:42 PM
Posts: 12,478 Taxes & Virus's R-US, NY
Dragula
... Do not do annular 1050 4150. Based on what opinion or experiences? The guy that bought my PS1000 had an annular carb on his. Mine was over a 1/10 quicker. He wouldn't give it back after testing it. The annular is on my shelf here if your interested in it...it's a nice QF...
[Re: Dragula]
#2347406
08/02/17 05:28 PM
08/02/17 05:28 PM
Posts: 31,203 Oregon
AndyF
... Do not do annular 1050 4150. Based on what opinion or experiences? The guy that bought my PS1000 had an annular carb on his. Mine was over a 1/10 quicker. He wouldn't give it back after testing it. The annular is on my shelf here if your interested in it...it's a nice QF... One data point from some guy with a car that went faster when changing carbs isn't very convincing argument. The annular boosters will pick up a lot of low end torque in a big carb. Your buddy might have lost torque by switching to your carb and since his chassis wasn't very good he ended up going faster.
[Re: AndyF]
#2347579
08/02/17 11:24 PM
08/02/17 11:24 PM
Dragula
... Do not do annular 1050 4150. Based on what opinion or experiences? The guy that bought my PS1000 had an annular carb on his. Mine was over a 1/10 quicker. He wouldn't give it back after testing it. The annular is on my shelf here if your interested in it...it's a nice QF... One data point from some guy with a car that went faster when changing carbs isn't very convincing argument. The annular boosters will pick up a lot of low end torque in a big carb. Your buddy might have lost torque by switching to your carb and since his chassis wasn't very good he ended up going faster. Low end is what he was lacking....If you only have 30cc pumps, you will not catch my PS1000....I had a pair of 50cc pumps and #45 squirters front and rear. He went faster everywhere with mine. MPH picked up, 60ft picked up a bunch, and midrange picked up. Once he bolted mine on, he ended up with traction problems! 60ft went from a 1.58 to a spinning 1.51...He bought new slicks, and he is almost in the 1.49's now..And we are in the heat of the season. So that is my data point, but we know why that carb worked, and I would buy another with my jetting in a heart beat. We tested it on three engines, it was always the fastest carb.
[Re: clonestocker]
#2347615
08/03/17 12:06 AM
08/03/17 12:06 AM
Posts: 13,227 aZLiViN
J_BODY
aZLiViN
I run a 4150 style carb since I don't have intake gaskets for my 4500 intake.... and I don't want to ruin the ones that are presently on it. Have plenty of fun going 9.4's 9.5's.... CLASSIC Jay well to be honest... I don't think the 4500 I have will perform as well as the carb in use. I put an adapter on my 4150 intake and ran our dominator and it actually slowed at Barona. ALSO... the 4500 intake I have was welded up and adapted with not much porting in the plenum area and the port size shape is still that of the craftsman based mill it came off. I will play with it as is with a port match one day. Until then....we'll continue with what we got.
[Re: J_BODY]
#2347645
08/03/17 12:30 AM
08/03/17 12:30 AM
Thumperdart
State of confusion
I run a 4150 style carb since I don't have intake gaskets for my 4500 intake.... and I don't want to ruin the ones that are presently on it. Have plenty of fun going 9.4's 9.5's.... CLASSIC Jay well to be honest... I don't think the 4500 I have will perform as well as the carb in use. I put an adapter on my 4150 intake and ran our dominator and it actually slowed at Barona. ALSO... the 4500 intake I have was welded up and adapted with not much porting in the plenum area and the port size shape is still that of the craftsman based mill it came off. I will play with it as is with a port match one day. Until then....we'll continue with what we got. Totally agree, because the best tuned carb on a manifold that is less than desirable in terms of efficiency can be and is slower as you found out......
[Re: fast68plymouth]
#2347691
08/03/17 02:36 AM
08/03/17 02:36 AM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
Running huge carbs seems to be all the rage these days, so I won't even try and talk you out of it.
I'll just say that my one experience with one...... A qft-q1050......On a roller cammed, Indy headed 572....... was good. It made a few more hp than a Mighty Demon 850. A few like 3 or 30? It was about 5hp. .028" in Venturi diameter is only going to get you so much. Thanks for the reply. I have a Mighty Demon 850 anuular. (Throttle Bore 1.75 inch Venturii Size 1.560 inch) The 337 manifold is ported, no room for a 4500 adapter. Doesn't seem worth the time or expense to pick up 5 hp.
[Re: AndyF]
#2347844
08/03/17 01:29 PM
08/03/17 01:29 PM
Thumperdart
State of confusion
On my 470 the QF 1050-AN (annular boosters) worked much better than the Holley 850 and 950 that I tried. The 950 was converted to annular boosters which improved it significantly, but the QF 1050 was still the best carb.
However, this is just dyno testing where we run the engine from 5000 to 7000. The carbs could behave differently on the street or the track. On the dyno we don't really have a way to test "driveability" issues. My point finally strikes gold............. a 5000-7000 dyno pull in no way even touches on street drive-ability or low speed manners just like the one you sold Brad I tested. Couldn't even do a burnout no joke but after working the idle, transition and cruise, it's drive able.......And personally hearing about 4150's on Big blocks especially making even 500+ deserves a Dommy especially a 572 like someone mentioned..........CRAZY and leaving a LOT on the table no matter what you heard or read..........PROVEN every day........
[Re: 65Fury440]
#2347857
08/03/17 01:47 PM
08/03/17 01:47 PM
fast68plymouth
So. Burlington, Vt.
I'll just say that my one experience with one...... A qft-q1050......On a roller cammed, Indy headed 572....... was good. It made a few more hp than a Mighty Demon 850. A few like 3 or 30? It was about 5hp. .028" in Venturi diameter is only going to get you so much. Thanks for the reply. I have a Mighty Demon 850 anuular. (Throttle Bore 1.75 inch Venturii Size 1.560 inch) The 337 manifold is ported, no room for a 4500 adapter. Doesn't seem worth the time or expense to pick up 5 hp. My test was downleg vs downleg. And, fwiw...... I've been testing for, and sorting out driveability issues on the dyno for 27 years. The dyno can be used for a lot more that wot testing.
[Re: viperblue72]
#2347898
08/03/17 02:43 PM
08/03/17 02:43 PM
Posts: 2,905 Pattison Texas
CSK
Pattison Texas
I went from Holley 1.563 w/down leg, to 1050 AN , drivability is much better, my engine combo likes it.
[Re: viperblue72]
#2348612
08/04/17 07:46 PM
08/04/17 07:46 PM
fast68plymouth
So. Burlington, Vt.
The "1025" sleeves were 1.562 as I recall..... The black ones.
In that venturi/throttle bore combo(1.562 x1.750) .....If it was a Race Demon RS it was a "1025", as a Race Demon w/o removable sleeves it was a "1000", and if it was a Mighty Demon it was an "850".
#2348640
08/04/17 08:32 PM
08/04/17 08:32 PM
Posts: 2,686 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I have a Race Demon RS 950 Annular that I converted to a 1050 down leg. Drives fine on the street and ran my best times. I have switched to a Gen 3 Dominator and the test results are not in yet. The new carb was not zeroed in yet.And I haven't been back out to test it . The engine is a 572" Hemi. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: viperblue72]
#2348685
08/04/17 10:02 PM
08/04/17 10:02 PM
fast68plymouth
So. Burlington, Vt.
It's been years since I flowed any of those things, but to the best of my recollection.... They were about 920-930cfm.
The annular boosters were 20-25cfm less.
I had also bought some of the largest sleeves..... I think they might have been 1.590(?).... Silver color iirc...... And they didn't increase the flow at all.
#2348687
08/04/17 10:09 PM
08/04/17 10:09 PM
BradH
In that venturi/throttle bore combo(1.562 x1.750) .....If it was a Race Demon RS it was a "1025", as a Race Demon w/o removable sleeves it was a "1000", and if it was a Mighty Demon it was an "850". Yep, the 1.562" venturi was the "1025"; still have my black sleeves. Re the advertised size differences... I figure BG felt if you didn't pay the extra $$$, you didn't deserve the extra CFM!
