Page 2 of 4 1 2 3 4
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345940
07/30/17 10:44 PM
07/30/17 10:44 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Many years ago Mopar put out a warning about putting Fram filters on the Cummins it would void the warranty. Must be a reason. I only use Wix or Napa gold's or Fleet Guard on my vehicles
Real Men shift for themselves
Re: Oil change and now no oil pressure! [Re: 1DGEMAN] #2345956
07/30/17 10:56 PM
07/30/17 10:56 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Just change the filter,disable the ignition,crank the engine until you see oil pressure on the gauge,reconnect ignition,and then cross your fingers and take it for a cruise.
You don't have a Milodon external system do you? I have seen more than one dual line system lose its prime after an oil change twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Oil change and now no oil pressure! [Re: fourgearsavoy] #2346001
07/31/17 12:03 AM
07/31/17 12:03 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Add me to the list of having experienced first hand no oil pressure on a mopar BB following a oil+filter change with a FRAM filter. This was at least 10 years ago. Have never purchased any FRAM product of any type since.
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2346025
07/31/17 12:49 AM
07/31/17 12:49 AM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
I'll get another filter and pull the distributor and see if it will build pressure. Sure hope I didn't spin a bearing on the startup!
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
Re: Oil change and now no oil pressure! [Re: davenc] #2346026
07/31/17 12:50 AM
07/31/17 12:50 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Last time I used a Fram PH8A for my DD, I was in a pinch, all the store had, so I figured what the hell, I know it was against my better judgement, lasted 1 day, the filter case ruptured just enough to cause a slow/moderate leak, luckily I got it home in time before losing all my oil/pressure...LAST time for a FRAM filter
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2346029
07/31/17 12:58 AM
07/31/17 12:58 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
As fourgearsavoy said, do you run an external oil system ?
1963 Plymouth Max Wedge
1971 Barracuda
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2346030
07/31/17 12:58 AM
07/31/17 12:58 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
After seeing a cut open fram filter with the paperboard ends glued on crooked, I will never use one again. Cheaply made. My brother said it looked like a kindergartner made it!!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2346076
07/31/17 04:38 AM
07/31/17 04:38 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
So did the new oil filter fix it?
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2346093
07/31/17 09:40 AM
07/31/17 09:40 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Had this happen on my 360 one time. Changed oil put a fram filter on it, fired up, no oil pressure. Loosen the filter and there was oil there, so put on a MOPAR filter and fired up and had oil pressure. No more FRAM filters for me....
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2346138
07/31/17 11:41 AM
07/31/17 11:41 AM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
I haven't had a chance to work at it yet. Will try to get this figured out later this week.
Thanks for all of the help and suggestions!
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2346154
07/31/17 12:22 PM
07/31/17 12:22 PM
Andrewh Offline
Andrewh  Offline
I wouldn't pull the distributor yet.
just swap filters and pull the coil plug and crank for a little bit to see if it moves the gauge.
if it doesn't then do it. but if it does, it saves you the trouble of marking everything to line up again.
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2346156
07/31/17 12:24 PM
07/31/17 12:24 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Doubt you spun a bearing on that short a run.I had oil pump go bad on BBs and drove a few miles home with no pressure.Put thousands of miles on after I fixed it.Rocky
Chrysler Firepower
Re: Oil change and now no oil pressure! [Re: GTSDart340] #2346176
07/31/17 01:00 PM
07/31/17 01:00 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Si Senor
Re: Oil change and now no oil pressure! [Re: therocks] #2346179
07/31/17 01:12 PM
07/31/17 01:12 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Dang! You're luckier than me, I only ran mine at idle for maybe two minutes total after the oil light (okay, never went out after a cold start at work) came on and developed a light knocking. I drove it that way until I got the 440 assembled.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2346180
07/31/17 01:16 PM
07/31/17 01:16 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Crap filter quality really stinks now days. I had someone in my garage mocking my K-mart oil filters. I bought a case of filters back in high school 30 years ago and misplaced about half dozen filters. Finally found them in a box of old parts. I don't know who made them, but said made in the USA and look to be as good as a WIX when I cut last one apart. I hope 500ciBee finds the problem.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2347300
08/02/17 02:26 PM
08/02/17 02:26 PM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
Got a new Mobil 1 filter. I pulled the distributor and used a 5/16 hex rod to prime the pump. Not getting any pressure on the gauge. How much resistance should the pump have? I'm using a cordless drill and it has no problem turning the pump. I ran the drill for probably a few minutes.
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2347312
08/02/17 02:46 PM
08/02/17 02:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You are running the drill in reverse aren't you?
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2347325
08/02/17 02:56 PM
08/02/17 02:56 PM
an8sec70cuda Offline
If the pump builds prime, it should try to rip the drill out of your hand. Not sure a cordless drill will do it...not for long anyway.
You should be spinning it counter-clockwise like Stumpy said.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2347366
08/02/17 03:56 PM
08/02/17 03:56 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
The question about what type of oil system is being used still hasn't been answered.
Re: Oil change and now no oil pressure! [Re: fast68plymouth] #2347444
08/02/17 07:02 PM
08/02/17 07:02 PM
dogdays Offline
dogdays  Offline
When the pump builds pressure the drill should about stop.
I lost an engine because I failed to recognize trouble when I primed the pump with my drill and the drill just kept on spinning even after the oil light went out. The engine lasted about 4000 miles before #1 rod bearing and #1 main bearing were worn enough it sounded like a Diesel.
So if the drill doesn't bog down you have a real problem.
R.
Page 2 of 4 1 2 3 4
