Re: Oil change and now no oil pressure!
[Re: 500ciBee]
#2345940
07/30/17 10:44 PM
07/30/17 10:44 PM
Posts: 608 TN
1DGEMAN
TN
Many years ago Mopar put out a warning about putting Fram filters on the Cummins it would void the warranty. Must be a reason. I only use Wix or Napa gold's or Fleet Guard on my vehicles
Real Men shift for themselves
[Re: 1DGEMAN]
#2345956
07/30/17 10:56 PM
07/30/17 10:56 PM
Posts: 10,559 Rittman Ohio
fourgearsavoy
Rittman Ohio
Just change the filter,disable the ignition,crank the engine until you see oil pressure on the gauge,reconnect ignition,and then cross your fingers and take it for a cruise. You don't have a Milodon external system do you? I have seen more than one dual line system lose its prime after an oil change ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 500ciBee]
#2346025
07/31/17 12:49 AM
07/31/17 12:49 AM
Posts: 136 Ontario, Canada
500ciBee
Ontario, Canada
I'll get another filter and pull the distributor and see if it will build pressure. Sure hope I didn't spin a bearing on the startup!
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
[Re: davenc]
#2346026
07/31/17 12:50 AM
07/31/17 12:50 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Add me to the list of having experienced first hand no oil pressure on a mopar BB following a oil+filter change with a FRAM filter. This was at least 10 years ago. Have never purchased any FRAM product of any type since. Last time I used a Fram PH8A for my DD, I was in a pinch, all the store had, so I figured what the hell, I know it was against my better judgement, lasted 1 day, the filter case ruptured just enough to cause a slow/moderate leak, luckily I got it home in time before losing all my oil/pressure...LAST time for a FRAM filter
[Re: 500ciBee]
#2346029
07/31/17 12:58 AM
07/31/17 12:58 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
I'll get another filter and pull the distributor and see if it will build pressure. Sure hope I didn't spin a bearing on the startup! As fourgearsavoy said, do you run an external oil system ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 500ciBee]
#2346030
07/31/17 12:58 AM
07/31/17 12:58 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
After seeing a cut open fram filter with the paperboard ends glued on crooked, I will never use one again. Cheaply made. My brother said it looked like a kindergartner made it!!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: 500ciBee]
#2346138
07/31/17 11:41 AM
07/31/17 11:41 AM
500ciBee
Ontario, Canada
I haven't had a chance to work at it yet. Will try to get this figured out later this week. Thanks for all of the help and suggestions!
[Re: 500ciBee]
#2346156
07/31/17 12:24 PM
07/31/17 12:24 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Doubt you spun a bearing on that short a run.I had oil pump go bad on BBs and drove a few miles home with no pressure.Put thousands of miles on after I fixed it.Rocky
Chrysler Firepower
[Re: GTSDart340]
#2346176
07/31/17 01:00 PM
07/31/17 01:00 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
After seeing a cut open fram filter with the paperboard ends glued on crooked, I will never use one again. Cheaply made. My brother said it looked like a kindergartner made it!! Si Senor
[Re: therocks]
#2346179
07/31/17 01:12 PM
07/31/17 01:12 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Doubt you spun a bearing on that short a run.I had oil pump go bad on BBs and drove a few miles home with no pressure.Put thousands of miles on after I fixed it.Rocky Dang! You're luckier than me, I only ran mine at idle for maybe two minutes total after the oil light (okay, never went out after a cold start at work) came on and developed a light knocking. I drove it that way until I got the 440 assembled. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 500ciBee]
#2346180
07/31/17 01:16 PM
07/31/17 01:16 PM
Posts: 5,141 East Aurora (Buffalo) NY
RoadRunner
Crap filter quality really stinks now days. I had someone in my garage mocking my K-mart oil filters. I bought a case of filters back in high school 30 years ago and misplaced about half dozen filters. Finally found them in a box of old parts. I don't know who made them, but said made in the USA and look to be as good as a WIX when I cut last one apart. I hope 500ciBee finds the problem.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: 500ciBee]
#2347300
08/02/17 02:26 PM
08/02/17 02:26 PM
500ciBee
Ontario, Canada
Got a new Mobil 1 filter. I pulled the distributor and used a 5/16 hex rod to prime the pump. Not getting any pressure on the gauge. How much resistance should the pump have? I'm using a cordless drill and it has no problem turning the pump. I ran the drill for probably a few minutes.
[Re: 500ciBee]
#2347325
08/02/17 02:56 PM
08/02/17 02:56 PM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
If the pump builds prime, it should try to rip the drill out of your hand. Not sure a cordless drill will do it...not for long anyway.
You should be spinning it counter-clockwise like Stumpy said.
[Re: 500ciBee]
#2347366
08/02/17 03:56 PM
08/02/17 03:56 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The question about what type of oil system is being used still hasn't been answered.
