Re: Fast68 & other cam guru's. Which one of these is best? [Re: BradH] #2345308
07/29/17 02:43 PM
07/29/17 02:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted By BradH
This is only an observation from my own experience........
1. My RB cam had sh!tty hi-rpm dynamics. It would rev to about 6300-6400 OK, then start to float its a$$ off by 6500.
2. On the same engine dyno where I saw the Racer Brown cam's RPM limitations, I also saw two different UltraDyne NF904 cams pull much better to 6800 RPM with 1.5 rockers.
Brad...... Was the RB test done with 1.5's or 1.6's?
Which UD cams did you try?(I seem to recall you had mentioned a 255/263-110 test)
Re: Fast68 & other cam guru's. Which one of these is best? [Re: fast68plymouth] #2345312
07/29/17 02:56 PM
07/29/17 02:56 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Racer Brown 1.6 intake/1.5 exhaust
UD NF904s tested only with 1.5s
- 251/255 on 108
- 255/263 on 110
Ran the RB ST-21 for years until switching to the COMP XX 266/.600/108, along with going from ported OEM 452s to the Stage VIs you did for me.
My brain hurts having to think back that far...
Re: Fast68 & other cam guru's. Which one of these is best? [Re: rt66jim] #2345343
07/29/17 04:22 PM
07/29/17 04:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
As I recall...... With that particular engine combo..... The RB cam made more power than the UD cams ?
Re: Fast68 & other cam guru's. Which one of these is best? [Re: rt66jim] #2345346
07/29/17 04:32 PM
07/29/17 04:32 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
So Dewayne what would you recommend for it?
Re: Fast68 & other cam guru's. Which one of these is best? [Re: rt66jim] #2345362
07/29/17 04:54 PM
07/29/17 04:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
As I said previously....... For a basic bracket build...... It would be something fairly unglamorous.
Low 270's@.050, barely over .600 lift with the 1.6's....... And IMO it would still need to be broken in with the inners removed, and the spring pressures and heights would need to be verified.
Re: Fast68 & other cam guru's. Which one of these is best? [Re: fast68plymouth] #2345417
07/29/17 07:34 PM
07/29/17 07:34 PM
BradH Offline
BradH  Offline
The RB as tested made about 5 HP more than the smaller UD, and both made more power than the bigger UD.
I always wondered how the smaller UD with the 1.6 intake rockers would have done, or a single-pattern UD 255 on 108, but just ended up running the RB 1.6/1.5 combo.
Re: Fast68 & other cam guru's. Which one of these is best? [Re: rt66jim] #2345432
07/29/17 08:19 PM
07/29/17 08:19 PM
So. Burlington, Vt.
So. Burlington, Vt.
It's just another example of what I've seen numerous times......
Opening the valve as fast as possible doesn't always result in the best power.
Some combos don't respond well to really fast opening rates........especially really fast right off the seat.
