Page 2 of 4 1 2 3 4
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322171
06/16/17 03:00 PM
06/16/17 03:00 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Online content
rumblefish72  Online Content
I had this problem ... it was misalignment between my Lakewood scattesrshield and the crank center line. Hopefully, the OPs problem is a simple clutch linkage adjustment for more air gap when the pedal is pressed all the way down. I measured runout when I installed it and it was like 0.016 total (.008 off). I couldn't get the runout below 0.010". It would be 0.008" runout and then I'd tighten the bolts a bit and the runout would grow to 0.014" or more. I'd hit it with a deadblow hammer to try to get it closer but then it would still walk out as I tightened it. I got it as close as I could and welded the dowel alignment bushings onto the scattershield. I thought I could live with it but it dragged and made shifting into first from neutral difficult. I could tell that the cluster was spinning with too much drag when I tried to put it into 1st. It would finally crunch in as I pressed the shifter forward and I'd take off. I finally decided that the 30 yr old bellhousing needed to be retired so I switched to a Quicktime. The pilot bushing was way shot when I took it apart. The Quicktime indicated at 0.002" total runout right out of the box which made me happy. But after just a little bit of driving, the clutch fork pivot bracket folded over and I had to limp home. I think that everyone but me must be running a hydraulic throwout bearing by now but I didn't want to fix what wasn't broken (linkage) and I didn't have another $700 to throw at it. My family is giving me this Sunday off so I hope to bolt it all back together and get it down off the jackstands. Stay tuned ...
I do use the Pennzoil "Synchromesh" NON synthetic gear oil and that has always worked well over the 40+ years that I've been driving a 18 spline 833.
151111QuicktimeBellhousingCentersUpAtOneThouOutSmall.jpg151111QuicktimePlusHemi4SpeedAndShifterSmall.jpg
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: A833 18spline, hard to put into 1st after being in neutral [Re: Supercuda] #2322182
06/16/17 03:40 PM
06/16/17 03:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By Supercuda
Synchros do not work when at a stop and shifting into any gear.
They most assuredly do. What happens when you shift a non-synchro trans from neutral to 1st gear at a stop without waiting for the input shaft to coast to a stop?
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322189
06/16/17 03:58 PM
06/16/17 03:58 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Originally Posted By lilred
Do you recall as to exactly what oil you ended up using as I would definitely give it a try, was it just regular of the shelf 80/90 gear oil??? Thanks
Yup just plain 90wt gear oil.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322211
06/16/17 04:25 PM
06/16/17 04:25 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Everytime I see Pennzoil, I make the sign of the cross..
EVERY car ( back in the day) that was using Pennzoil, and was burning oil ( blue smoke), stopped when changed out to Castrol or Kendall, ( the brands I used) after I stopped using Pennzoil...
Many years ago and a different time, but I never use any Pennzoil products...
Re: A833 18spline, hard to put into 1st after being in neutral [Re: minivan] #2322262
06/16/17 05:52 PM
06/16/17 05:52 PM
katakan
lilred Offline OP
lilred  Offline OP
katakan
Does anyone have the product number for the Pennzoil as the pic does not show it.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322301
06/16/17 07:18 PM
06/16/17 07:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Pennzoil 3501.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322302
06/16/17 07:21 PM
06/16/17 07:21 PM
katakan
lilred Offline OP
lilred  Offline OP
katakan
Someone asked if it grinds going into gear, I can upshift and down shift no problem, it is only hard to put into 1st if I put into neutral and try to go back into gear,
I have tried the 2nd gear deal before going into 1st and it is hard to go into 2nd as well.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322313
06/16/17 08:03 PM
06/16/17 08:03 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
To me it sounds like shifter alignment, shift fork wear (they wear at the ends which pushes the slider assembly at an angle) or something else wrong in the slider assembly itself.
It will go into 3rd and 4th easily from neutral?
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322323
06/16/17 08:20 PM
06/16/17 08:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
based on the responses it might be worth changing the fluid once or twice, twice to flush twocents
keep us posted beer
Re: A833 18spline, hard to put into 1st after being in neutral [Re: TJP] #2322347
06/16/17 09:09 PM
06/16/17 09:09 PM
katakan
lilred Offline OP
lilred  Offline OP
katakan
I phoned the local Napa and it looks like they have the #3501 so will change it the next chance I get, I will leave the clutch freeplay as is just to see if it is the oil problem.
The shift forks were replaced so they are in good condition, I think I tried the 3 or 4th gear from neutral and almost think there was no difference, there is no grinding once it does go into gear.
What I did notice was that if I went into 1st from neutral it would kind of road block it but if I keep pressure on the shifter it would go into 1st, there is no grinding into 1st or 2nd from neutral, just feels like its blocked but like I said it would go if I keet pressure on the shifter.
When you overanalyze this it does make sense that maybe the oil is too slippery and not stopping the synchros, but when I keep pressure on the shifter it stops the synchros????
Once I change the oil I will keep everyone posted.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322380
06/16/17 11:03 PM
06/16/17 11:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I wouldn't over think it....... it's just an oil change.
It will either help or not.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: fast68plymouth] #2322395
06/16/17 11:33 PM
06/16/17 11:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
But it may take more than 1 change to flush the slippery stuff out.or some kind of flush, brake clean, acetone ?? shruggy
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322412
06/17/17 12:05 AM
06/17/17 12:05 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Did I miss what happens when going directly into reverse from neutral. If grinding likely a clutch release issue or severe misalignment or tight pilot bearing/bushing drag would be a good guess.
If any clutch drag or pilot bearing drag at all causing main shaft to continue spinning with clutch pedal down, synchronizes will relieve this but with great effort. Going into reverse, of course no synchro help at all.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: John_Kunkel] #2322423
06/17/17 12:19 AM
06/17/17 12:19 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
realcrazy no
OH nothing John, just RAM it in, and generate some FLAKES to seat the bearings and parts, Makes for a smoother shifting trans when no teeth are left on the gears. whistling stirthepot haha
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322514
06/17/17 04:46 AM
06/17/17 04:46 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
A warped clutch disc could do exactly what is described. How do you warp a clutch disc?
By letting the back end of the transmission hang down while main shaft is in clutch plate but not yet in pilot bearing is one way. This can warp the disc enough to still have drag even with clutch pedal to the floor.
Question is: Did this all start after overhauled transmission was installed, or was it overhauled because of this problem?
In other words, when did this problem first begin!
Again, what happens when shifting from neutral to reverse? If grinding it is not an oil or synchro problem. It is most like a clutch problem, or remotely a mal-adjusted linkage issue.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: fast68plymouth] #2322580
06/17/17 12:04 PM
06/17/17 12:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The op says he's in neutral, then can't get it back into gear.
If the trans is in neutral, and the clutch is engaged, everything is turning.
When you push the clutch pedal in, there is usually still some amount of drag helping to keep everything spinning, and when you go to put it into gear, the synchro has the job of stopping the rotation and aligning the teeth so it will slide into gear.
Surely you've heard someone grinding a gear to get it engaged........ They don't grind when they're not turning.
I still say a fluid change would help, and the Pennzoil synchro-mesh was recommended to me by a guy who does a lot of transmissions.
It's not that expensive and it's easy to do.
Thats true when in neutral and the clutch is out the input shaft is turning as is the countershaft and the syncro's do work when you shift into gear since the gears are turning. Try this and when you push in the clutch and go to put it in first wait about 10 seconds before you try to put it in first after you push the clutch all the way in. By then all the gears should have stopped turning and it should go right in first with no grinding. If it does not and seems no different then when you go into first as soon as you push the clutch in then something is causing the input shaft to still be spinning when the clutch is in. I have seen a pilot bearing that was to tight cause this years ago. If it goes into gear normally then you know the input shaft stopped turning as it should.
Myself I found that if its a clutch adjustment not letting the clutch disengage all the way you will usually also have shifting problems with all gears. I would still make sure the clutch adjustment is right but it does sound like the syncro is not working right. Can the wrong fluid be the cause ?? Myself I have not run into that but from what others have seen the wrong fluid may affect how the syncro's work so it surely wont hurt to change the fluid and try it. Good luck with it , Ron
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322583
06/17/17 12:22 PM
06/17/17 12:22 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Pretty sure I remember way back when to use ATF in the 4-trans. I think the one I had used it and it shifted fine. Just a 23 spline, but same principle.
Change the oil and try it, cheap and doesn't take long to do. Probably have to do it twice, but that is what I would do.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322628
06/17/17 02:15 PM
06/17/17 02:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
I still feel that making sure the air gap is wide enough would be the first step.
If that's found to be sufficient......then change the oil.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: fast68plymouth] #2322633
06/17/17 02:24 PM
06/17/17 02:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree Forget the pedal free play dimension and check the air gap at the disc.
Re: A833 18spline, hard to put into 1st after being in neutral [Re: lilred] #2322665
06/17/17 04:09 PM
06/17/17 04:09 PM
Mass
charge70 Offline
charge70  Offline
Mass
Not sure if this was said earlier,if it was sorry.When having trouble shifting into 1st gear,has the op tried shutting the engine off.That would tell you if its a clutch or transmission problem.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Page 2 of 4 1 2 3 4
