Re: 440 source heads
[Re: Wedgeman]
#2348539
08/04/17 05:01 PM
08/04/17 05:01 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The calculated flow for the curtain area of a 2.14 valve, .100 lift @ 100% c/d(like flowing a straight tube)is right about 100cfm.
Typical c/d at low lifts is 60-80%.
[Re: fast68plymouth]
#2348555
08/04/17 05:33 PM
08/04/17 05:33 PM
Posts: 2,094 central texas
krautrock
central texas
Typical c/d at low lifts is 60-80%. that said, it seems the flow #'s from the facebook pic grab could start at .200" lift... or bench could need calibration, really no telling without more info..
[Re: krautrock]
#2348561
08/04/17 06:00 PM
08/04/17 06:00 PM
BradH
or bench could need calibration, really no telling without more info.. Here are the full curve comparisons... Larry Smith's posted #s assuming the lowest #s are .100": .100" - 120 .200" - 177 .300" - 239 .400" - 282 .500" - 312 .600" - 324 Or, assuming the lowest #s are .200" (which I don't believe to be the situation): .200" - 120 .300" - 177 .400" - 239 .500" - 282 .600" - 312 .700" - 324 MCH's CNC Stealth program advertised #: .100" - 75.0 .200" - 156.7 .300" - 219.8 .400" - 266.2 .500" - 298.8 .600" - 314.9 .700" - 320.7 I can't add anything more to this topic, and still question the bench calibration or some other condition that's resulting in unrealistic low-lift #s. Regardless, carry on with your bad self!
[Re: Wedgeman]
#2348590
08/04/17 07:05 PM
08/04/17 07:05 PM
fast68plymouth
So. Burlington, Vt.
My total guess is...... There's a leak, causing the big low lift numbers.
[Re: Wedgeman]
#2348599
08/04/17 07:25 PM
08/04/17 07:25 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
This is what I got out of my Super Stealths on my bench OOTB .200 140 .300 202 .400 242 .500 256 .600 267 .700 267 after .200 157 .300 217 .400 264 .500 290 .600 314 .700 335 .800 345
[Re: Wedgeman]
#2348710
08/04/17 10:44 PM
08/04/17 10:44 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Mine have been on since they came out.They get beat on pretty good.I did change springs,retainers, and keepers because i run a 588 solid cam and 4 speed.My machinist did some clean up and like the look.He was a perfectionist.Happy with them and i needed straight plugs for my dome pistons.Rocky
Chrysler Firepower
[Re: Wedgeman]
#2348919
08/05/17 12:48 PM
08/05/17 12:48 PM
fast68plymouth
So. Burlington, Vt.
I know flow bench #s can't be compared DIRECTLY, but when they're using a common calibration standard you can expect they're going to be REASONABLY close. Case in point....... I flowed one of the MCH CNC ported stealths about 5 years ago..... .100---72 .200--159 .300--220 .400--266 .500--293 .600--309 .700--313 The thing that's almost never mentioned, and would have more of an impact on the higher lift flow, especially as the flow numbers get bigger......is the shape of the radius for the air inlet. This can result in a 1-3% difference in flow(or more if its a particularly bad one) on the same head, on the same bench.
