Re: Dropped the *!:*;#* wrench
[Re: maximus]
#2343952
07/26/17 10:22 PM
07/26/17 10:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
How about filling the void with spray in foam and let it be, if all else fails.
[Re: maximus]
#2344040
07/27/17 01:33 AM
07/27/17 01:33 AM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
If the flex magnet or tape suggestions don't work from inside trunk/quarter, then try a Rare Earth magnet, which are strong. Place a microfiber rag over the magnet and place the magnet on the class A surface (outside quarter panel/rocker) where you believe it is. Once you feel/hear wrench drag it toward rear quarter (trunk area).
I used this type of magnet/process to assist operators locate torque converter nuts when dropped into trans housing during assembly (trans to fly wheel secure). There was no access hole at the bottom of trans, so the operators would place the magnet at the bottom of case then they dragged the magnet toward starter pocket where they were able to grab lost torque nut.
[Re: maximus]
#2344119
07/27/17 10:04 AM
07/27/17 10:04 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Buy a new wrench and forget about it... it's not going to rattle much if at all. Don't spray foam it. Cut apart a new challenger and see how the inside of the panels look with that crap in there.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: maximus]
#2344251
07/27/17 12:24 PM
07/27/17 12:24 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Turn the car upside down. If the car is pretty much complete, put two of those drive-on ramps on the opposite side and drive the car onto them. Maybe that angle will help you out. I drove my Durango on two ramps placed on the same side. I was able to get the gas tank straps replaced that way. If you don't have ramps, you can make some out of scrap 2x8s. http://www.mustangworld.com/ourpics/News/mwramps/ramps7.JPG
[Re: Silver70]
#2344279
07/27/17 01:11 PM
07/27/17 01:11 PM
RapidRobert
it's not going to rattle much if at all. that's what I was thinking tho it does mess with a persons' pride to leave it there. You've sure gotten alot of love on this one tho, I think it struck a nerve cuz we've all been there!
