Re: 511 project
[Re: mopar dave]
#2345502
07/30/17 12:05 AM
07/30/17 12:05 AM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
my ECP works great !!! 512cid, cold AC, 105 outside temps, 185ish all day long
Re: 511 project
[Re: mopar dave]
#2345507
07/30/17 12:36 AM
07/30/17 12:36 AM
CSK
Pattison Texas
18" 7 blade direct,Flex a lite
Re: 511 project
[Re: mopar dave]
#2345531
07/30/17 01:21 AM
07/30/17 01:21 AM
CSK
Pattison Texas
things could make noise, converter not full, no load on the front pump.
Re: 511 project
[Re: mopar dave]
#2345561
07/30/17 03:54 AM
07/30/17 03:54 AM
CSK
Pattison Texas
yes fire it up in neutral with 5, or more qts already in it before you start it. I like to have the wheels off the ground on stands
Re: 511 project
[Re: mopar dave]
#2345623
07/30/17 10:42 AM
07/30/17 10:42 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Egineered cooling products Radiator is in. Surprised how well the summit shroud fit radiator and fan. Think this will cool? That looks real good!Soon you will be tuning on that carb and that will be fun.
Re: 511 project
[Re: mopar dave]
#2345662
07/30/17 12:16 PM
07/30/17 12:16 PM
Clanton
northern,Ohio,USA
I have Doms number for that. Shouldn't be too far off. Had Dom and Mark whittier insite on dominator build. That is great to have some tech help from builders who know how.I used a 1050 in the 1990's[n/a] with a .509 and a .590 cam and liked it. ps:Don't take my continued post's as me being a know it all,I am just making conversation.
Re: 511 project
[Re: mopar dave]
#2345669
07/30/17 12:28 PM
07/30/17 12:28 PM
Clanton
northern,Ohio,USA
yep, always up on stands during break in. Do you have a deep trans pan?I think as long as you have 1.5 qts in the vert and about 7 in the pan the trans should be ok with the main concern being the vert being dry.
Re: 511 project
[Re: mopar dave]
#2345763
07/30/17 04:25 PM
07/30/17 04:25 PM
Clanton
northern,Ohio,USA
I'm using a six pack hood. hoping filter clears. I believe i put a 86/93 in it with a 6.5pv Nice!I was able to tune good vacuum so I hope you can also.I also wanted to say I use a Tee handle on the corner valve cover studs and it makes things easy to undo.
