Re: Edelbrock Performer RPM Cylinder Head for Gen III HEMI
[Re: fbs63]
#2390631
10/21/17 01:12 AM
10/21/17 01:12 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
You can. I tubed my eagle heads i run
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: moparts]
#2398784
11/05/17 01:07 PM
11/05/17 01:07 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
For NA, yeah the BGE is hard to beat, There doesn't seem to be a lot of feedback on the Eddy heads yet, and at $1300 for One head I'm surprised they are sold out(according to summit complete assembled head). as for when is the Eddy a better head, I can't answer that. I don't know anyone personally that has them., the Intake manifold yes, I know 2 and they are split on how they feel, One loves it , the other put it on CL a week after he got it.
[Re: moparts]
#2399222
11/06/17 09:35 AM
11/06/17 09:35 AM
ric3xrt
Trumbauersville PA
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: moparts]
#2399841
11/07/17 09:24 AM
11/07/17 09:24 AM
Posts: 153 MI, USA
moparmitch
MI, USA
Anyone know combustion chamber sizes for eagle and apache?
Wondering what the compression would be for putting an eagle on a 6.4?
Maybe I'll start a new thread for this, what do you think?
Approx new prices for a NEW high comp (12/1 or better?) G3:
3500--OEM 6.4 shortblock,has steel crank 1500--OOTB eagle heads, change springs if needed 0720--ritter intake 1100--Dominator carb 0720--MSD-6 & harness 0700--dragpak type cam, suit to fit combo or use 6.4 cam 0420--lifters 8660--total
Add a few other new parts and maybe pickup other pieces used and have a NEW high comp motor for around 12K or less?
Get a used low mile 6.4 shortblock and it gets even better...
We know the rods and pistons are OEM, but these motors have proven to be strong and take lots of abuse. As much as I don't like the VVT configuration, people are locking this out and making big power reliably.
If you figure a moderate, but realistic 1.5 HP per cube, we get 588 HP for this 392 build. Go with 1.54 HP/cube and get 603 HP.
This seems like a lot of performance for an essentially "bolt-together" motor that wouldn't need a lot of support (if any) from a machine shop. Of course it would be advisable to measure and check/adjust everything as necessary.
Just a thought, as this is what we have readily available and to use with mostly new OEM pieces.
[Re: toddinNH]
#2399929
11/07/17 01:39 PM
11/07/17 01:39 PM
Posts: 1,541 USA
hudsonhornet7x
USA
What is this BGE head you all seem so high on? Not "high" high, but positive. The BGE stands for Big Gas Engine. These are the 6.4 engines that come with the heavy duty ram trucks. The heads you mentioned are basically Hellcat type heads with a conventional intake bolt pattern instead of the supercharger intake.
[Re: toddinNH]
#2400072
11/07/17 06:28 PM
11/07/17 06:28 PM
ric3xrt
Trumbauersville PA
What is this BGE head you all seem so high on? Not "high" high, but positive. Best description froA2Speed web site What is a “HEMI Big Gas Head”? Think of it as a Hellcat head with a 6.4 intake manifold bolt pattern. This is the head used in the RAM Truck equipped with the 6.4L HEMI, first made available in 2014. The HEMI Big Gas head was extensively redesigned by Dodge SRT engineers with keen focus on durability in a heavy duty environment. Some key features: Castings and Material: The casting is derived from the SRT8 Hellcat head, giving the Big Gas Heads substantially improved internal reinforcement and improved water jackets. They are also made of the same 356 T-6 aluminum alloy found in the Hellcat Head. (vs. the T319 modified alloy used in the Apache 6.4L head). Valves: By our measurements the Big Gas intake valves are 54.3 mm (2.138”); exhaust valves are 42 mm (1.654”); the same size as the Apache’s. The Big Gas valve guides are stainless steel and seats are a modified steel alloy. Both the Big Gas and Apache valves have hollow stems to reduce inertial mass allowing for higher RPMs. Exhaust valves are sodium filled; when the exhaust valve gets hot, the sodium liquefies which in turn transfers heat from the valve head to the valve guides via a “cocktail shaker” effect induced by valve’s motion. This style of exhaust valve helps prevent hot spots in the combustion chamber & valve head which reduces the possibility of pre-ignition. Visually it’s apparent that the Big Gas valves are a different material or have a different coating then the Apache’s; but as of this writing I haven’t been able to get a spec for this. Intake Ports: On both the 6.4L Apache and Big Gas HEMI heads no clean-up machining is necessary on the intake ports. When the heads are cast, a fine sand (AFS 90) is used around the intake port cores. This provides the intake ports with a smooth surface finish and exceptional flow characteristics. Intake valve angle on both heads is 18°. Exhaust Ports: Experience has shown that the greatest gains in Gen III HEMI heads are found in the exhaust ports. The Big Gas exhaust ports have improved long turns, guide support and ceiling. Un-like the Apache, the Big Gas HEMI head has fine sand cast exhaust ports, the resulting smooth surface finish improves flow characteristics dramatically. Exhaust valve angle on both heads is 16.5°. Combustion Chamber: The Apache and Big Gas heads have similar quench-free combustion chambers. The Apache chamber is 73.4 cc’s, we will be pouring both chambers next week, will report results in a new thread. Valve Springs: The Big Gas and Apache heads come with the same valve springs; meaning that replacement is required for aftermarket cams. In summary: In summary, the Big Gas head is an outstanding yet affordable option for boosted applications where cylinder pressure and thermal stresses are anticipated. It’s a great option for a naturally aspirated motor as well, particularly if it's bottle-fed.
[Re: fbs63]
#2400149
11/07/17 08:46 PM
11/07/17 08:46 PM
Posts: 12,385 Taxes & Virus's R-US, NY
Dragula
Here are some pics of the heads. I bought them bare so we could try a few things with them. One nice thing is they come with no valve job so you have material to work with. Thanks for posting pics of my new heads. I think Ray just received them, hopefully he can do a mild clean up on them. Probably going on an aluminum 6.1 block...
[Re: moparts]
#2400162
11/07/17 09:05 PM
11/07/17 09:05 PM
Posts: 397 NH, USA
toddinNH
Egghead
Egghead
NH, USA
What is a “HEMI Big Gas Head”? Think of it as a Hellcat head with a 6.4 intake manifold bolt pattern....etc.
Thanks gents! I now know all I need to know about BGE heads. It seems like they are the pick of the litter in factory Gen 3 heads. 356-T6 is a huge improvement. It's pretty impressive that a gas powered NA production truck has hollow stem intakes and sodium filled exhaust valves. One would have to think that the valves are a stainless alloy. My guess would be a 21-4N, which would assist in the "durability in a heavy duty environment" parameter. If this paragraph proves to be in error, I'll eat a hat..my own. I just searched and found pictures of the assembled BGE heads. The valves are definitely coated with at least a different color, but I will assume that the coatings too, are part of that "durability in a heavy duty environment" bit. Thanks again to you both. School was painless today.
