Re: Will engine have to come out to replace oil pan gasket? [Re: larrymopar360] #2375104
09/22/17 04:36 PM
09/22/17 04:36 PM
5thAve Offline
5thAve  Offline
Cool sounds like a fun project.
Re: Will engine have to come out to replace oil pan gasket? [Re: buildanother] #2375182
09/22/17 08:01 PM
09/22/17 08:01 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Oh, I see what you're saying. I thought you were saying I spelled it wrong, lol. I wasn't concerned with year accuracy as long as it was a Chrysler blue-ish color. I can't tell the difference unless they are side by side.
Facts are stubborn things.
Re: Will engine have to come out to replace oil pan gasket? [Re: 5thAve] #2375183
09/22/17 08:02 PM
09/22/17 08:02 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thank you. I'm very excited about getting it on the road!
Re: Will engine have to come out to replace oil pan gasket? [Re: larrymopar360] #2375196
09/22/17 08:30 PM
09/22/17 08:30 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Just picked up 2 of the 4349217ab paint yesterday myself. It is blue alright, but if they call it turquoise, so be it.
Re: Will engine have to come out to replace oil pan gasket? [Re: buildanother] #2375210
09/22/17 08:59 PM
09/22/17 08:59 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Has turquoise on label
Re: Will engine have to come out to replace oil pan gasket? [Re: larrymopar360] #2375260
09/22/17 11:43 PM
09/22/17 11:43 PM
chicagoland,usa
chicagoland,usa
That's odd, as they sell, or at least used to sell the correct turquoise for the sixties engines.
Re: Will engine have to come out to replace oil pan gasket? [Re: buildanother] #2384523
10/09/17 04:24 PM
10/09/17 04:24 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
It's out and work in progress
Re: Will engine have to come out to replace oil pan gasket? [Re: larrymopar360] #2384524
10/09/17 04:26 PM
10/09/17 04:26 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Using all premium parts and gaskets, and doing double roller timing chain with tensioner while it's out, HD water pump, and will clean it real well and paint up
Re: Will engine have to come out to replace oil pan gasket? [Re: larrymopar360] #2384525
10/09/17 04:28 PM
10/09/17 04:28 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Last one...for now grin
Re: Will engine have to come out to replace oil pan gasket? [Re: larrymopar360] #2384529
10/09/17 04:44 PM
10/09/17 04:44 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted By larrymopar360
Fel Pro Gaskets: Fel-Pro FELBS40094 1 14.95
Rear Main Seal
Small Block Gaskets: SFP3180 1 32.95
Superformance Carbon-X
Valve Cover Gasket Set
Small Block Gaskets: SFP6300 1 18.95
Superformace Intake
Gasket Sets; 273-360
Small Block Gaskets: SFP340-K1 1 28.95
Superformance Gasket Kit
with Front Seal
Sure is a lot of gaskets there.
I get a fel-pro kit and it has all I need.
Last one was less then $30.oo
shruggy
I have mechanical Aptitude.
I can screw up anything.
Re: Will engine have to come out to replace oil pan gasket? [Re: larrymopar360] #2384553
10/09/17 05:26 PM
10/09/17 05:26 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Whenever I can get a Superformance gasket I do. They are superior to anything else. Scratchinfortraction turned me on to those and he was right. Unfortunately, they no longer have the rear main for my 360.
Re: Will engine have to come out to replace oil pan gasket? [Re: larrymopar360] #2384565
10/09/17 05:48 PM
10/09/17 05:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Re: Will engine have to come out to replace oil pan gasket? [Re: larrymopar360] #2384571
10/09/17 05:54 PM
10/09/17 05:54 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
You may have noticed my dented grille. I did pick up a nice used one. It will go on after this project is done.
