Re: Aftermarket Carb Main Bodies - Inspect Closely!
[Re: BradH]
#2342005
07/23/17 04:04 PM
07/23/17 04:04 PM
Posts: 11,799 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Everything needs inspected these days. Except for the top shelf or custom places, QC has become pee poor in the race to the bottom of the price point.
[Re: BradH]
#2342011
07/23/17 04:16 PM
07/23/17 04:16 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Brad....do you still have one of the BG main bodies with replaceable boosters?
It would be interesting to see if there is any power difference in the two different shaped air entries.
[Re: BradH]
#2342157
07/23/17 10:06 PM
07/23/17 10:06 PM
Thumperdart
State of confusion
Man made and mass produced so ya, check everything and some of you guys have seen my findings on FB w/a few different brands of carb stuff and no different than heads, cams rockers gears etc. ANYTHING we purchase needs the fine tooth comb approach and good for you Brad on finding and fixing the problems although you shouldn't have to..........
[Re: BradH]
#2342374
07/24/17 12:36 PM
07/24/17 12:36 PM
fast68plymouth
So. Burlington, Vt.
Brad, what size is the annular body you bought?
I suppose one way to (hopefully) avoid such qc issues with a carb body, if someone were looking to do some experimentation, would be to buy one that's been "done" buy a carb shop.
Several years ago I bought a couple of bare(and when they say "bare" they mean it) genuine Holley HP bodies to build up into carbs....... A 950 and a 1000. I built up the 950....... Works "okay". Never got around to doing the 1000...... Although I have all the pieces to do it.
[Re: BradH]
#2342710
07/24/17 09:24 PM
07/24/17 09:24 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
My billet QF metering blocks were full of shavings and some threads were stripped... My zinc plated Proform main body that I got ~15 years ago was great
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: BradH]
#2343042
07/25/17 01:48 PM
07/25/17 01:48 PM
fast68plymouth
So. Burlington, Vt.
I bought a few of those original ProForm zinc bodies..... Like 12 years ago or so.
Mine had a pretty noticeable lip/step in the Venturi where the upper and lower halves of the mold met.
I also didn't care for the way the booster feed area was finished off. The Holley boosters have a nice radiused entry into the booster, whereas the PT body had a sharp squared off entry. I never did any before/after tests to see if that really matters or not....... I just put a radius on them to basically mimic how they come from Holley before I put them into service.
I built a few new carbs from scratch out of them....... And they worked pretty well.
I also built a new carb out of the Holley HP replacement body a couple of years ago, QFT blocks and billet baseplate, aluminum bowls, etc........ Still haven't tried it on anything yet.
[Re: BradH]
#2343091
07/25/17 03:10 PM
07/25/17 03:10 PM
fast68plymouth
So. Burlington, Vt.
Brad, how are the booster feed entries finished on that body? Radiused or squared off?
[Re: fast68plymouth]
#2343261
07/25/17 08:54 PM
07/25/17 08:54 PM
BradH
Brad, how are the booster feed entries finished on that body? Radiused or squared off? Not squared off (I've seem some of those before, especially w/ the last of the BG sh!t), but not a nice radius like Holleys (used to?) come with. It looks more like a wedge-shaped tool was used to flare out the end, but not as steep as the angle on the tool I picked up. When I was done tightening 'em up, my tool left another angle on the outside of the booster swedging... kind of like the top cut on a valve job. If boosters don't look like they have a nice transition at the swedging (is that even a word?), I'll do my own or work to improve the entries.
[Re: BradH]
#2343270
07/25/17 09:12 PM
07/25/17 09:12 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
after your post I checked mine, looks like the same one you bought, 2 loose AN boosters, I just put this carb together about 2 months ago, Thanks Brad for reminding us to check even the simple things.
[Re: BradH]
#2344141
07/27/17 10:35 AM
07/27/17 10:35 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Everyone, in every business, and on the road, is lost in social media, and the magic phone of security, and happiness. Quality of work, or even attention to it are very, very low priorities now. The payment for sub par work is the only priority close to precious companion phone. Because without constant, and ever increasing funds, the precious, and all it's magical powers will be lost.
[Re: dthemi]
#2344144
07/27/17 10:42 AM
07/27/17 10:42 AM
Posts: 19,696 north of coder
moparx
Everyone, in every business, and on the road, is lost in social media, and the magic phone of security, and happiness. Quality of work, or even attention to it are very, very low priorities now. The payment for sub par work is the only priority close to precious companion phone. Because without constant, and ever increasing funds, the precious, and all it's magical powers will be lost. now THAT might be the closest explanation yet !
[Re: dthemi]
#2344297
07/27/17 01:32 PM
07/27/17 01:32 PM
Thumperdart
State of confusion
Everyone, in every business, and on the road, is lost in social media, and the magic phone of security, and happiness. Quality of work, or even attention to it are very, very low priorities now. The payment for sub par work is the only priority close to precious companion phone. Because without constant, and ever increasing funds, the precious, and all it's magical powers will be lost. EVERYONE is a BIG word and I promise you I nor most of the good people I deal w/do not fall in this category..........but I get it and no monkey see monkey do in my world cos $$$ is the gift for GOOD work and greed is unfortunately all around along w/poor quality...........
[Re: BradH]
#2345394
07/29/17 07:25 PM
07/29/17 07:25 PM
BradH
Let me add another caveat: Don't trust that the sizes of the air bleeds that come with the main body kit are what's on the spec sheet, or even matches what's stamped on the bleed. I was sorting & measuring a bunch of bleeds today and with the stamped .033 MABs that came on the main body above... ONE was .033, ONE was .031+, and the other TWO ".033s" weren't even that big. They are now, cuz I drilled 'em to all match, but anyone who ASSumes they are right when bolting parts together won't know for sure either way.
