Re: Spray from the line ? [Re: cmcgee123] #234044
02/24/09 07:40 PM
02/24/09 07:40 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hum... just thinking.... I´m not going to blow my 318 so easy... so... being more conservative it´s a must...
I will try the hook of the car when finish the mini-tubbing and ladders... as the car hooks fine... will try the shots!
Ithink I´ll start with the 100hp shot off the line!!
Also coulde use a dual stage (plate + foggers) or a progressive nitrous controller with the foggers... progressive looks better....
And... my 318 have to kick some chevy turboed 6cc´s! They are all around here....
1973 Brasilian Dart
E100, boosted 390"
Re: Spray from the line ? [Re: dart_73_br] #234045
02/24/09 10:59 PM
02/24/09 10:59 PM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
if your running the right tire you shouldnt have to wory about hooking. im using alston double adjustable lader bars and a 28 13.5 et street hooks just fine sprayin the 200 with the converter flashing 3800 on a 440.
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
Re: Spray from the line ? [Re: cmcgee123] #234046
02/25/09 12:37 PM
02/25/09 12:37 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I used to spray my 360 off the line with a 180 shot on 28x11.5 Hoosier QTP and 4.10 gears...worked great as long a the track was preped well.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Spray from the line ? [Re: FlyFish] #234047
02/25/09 12:45 PM
02/25/09 12:45 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Yes. I will test the track conditions... I will not shot until it hooks.... if I have good conditions.... will shot off the line...
Re: Spray from the line ? [Re: dart_73_br] #234048
02/25/09 03:08 PM
02/25/09 03:08 PM
Chicagoland
chargerron69 Offline
Chicagoland
383 727 4500 flash on the spray 430 gear on super stocks and a 30x9 hoosier radial slicks on a fogger with .030 n20 jets out of the hole. 10.48 @ 126 best.
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
