511 Alive and well once again.
#2339890
07/19/17 06:33 PM
07/19/17 06:33 PM
Posts: 326 Alberta
Wookie316
Alberta
511 Dyno 837.6 HP Back together and ready to go back in Barney. Here is the just of the build. 400 block with a Callie's 4.25 Dragonslayer 13.5-1 Diamond pistons Indy EZ-1 heads flowing just under 370 @ .700 TTI 2 1/8 step headers Indy single plane with 1050 Dom Custom solid roller 268/276 with a hair over .700 lift Peaked at 837.6 @ 6700 and carries nice till 7100 Because we never cut the cloverleaf out of the Manifold it does better with no spacer. I'm fine with that for hood clearance. Should be able to fit a 5" element in it this way. It sounded real strong. Should work well. Biggest issue is finding time and motivation to swap it out with the 440 with a drug problem. Maybe next week. I'd post a dyno sheet but Photobucket want $ from me.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 511 Alive and well once again.
[Re: Wookie316]
#2339955
07/19/17 08:07 PM
07/19/17 08:07 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sounds like a nice build. Goodluck and have fun
[Re: Wookie316]
#2339973
07/19/17 08:48 PM
07/19/17 08:48 PM
Posts: 326 Alberta
Wookie316
Alberta
Thanks. Finding ambition to pull a perfectly good 440 out is my hurdle right now.
[Re: Wookie316]
#2340008
07/19/17 09:49 PM
07/19/17 09:49 PM
Posts: 326 Alberta
Wookie316
Alberta
I knew it would run over 8. Just wasn't sure how much?
[Re: Wookie316]
#2340045
07/19/17 10:50 PM
07/19/17 10:50 PM
Posts: 1,481 Outside
thedriver
Outside
Well that answers my question. Saw the video first, came here to check 😂
1973 challenger Dana. 4 speed. Low deck.
[Re: Wookie316]
#2340089
07/20/17 12:18 AM
07/20/17 12:18 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Great stuff, so it is going in the SuperBee in your sig ? 9.50's ??
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Wookie316]
#2340124
07/20/17 01:29 AM
07/20/17 01:29 AM
Posts: 326 Alberta
Wookie316
Alberta
Maybe with spray. NA at my weight won't run that low.
[Re: Wookie316]
#2340455
07/20/17 05:19 PM
07/20/17 05:19 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Very nice! Put the plate on the big motor too!
[Re: Wookie316]
#2340467
07/20/17 05:41 PM
07/20/17 05:41 PM
Posts: 326 Alberta
Wookie316
Alberta
Thanks. Hope to have some track #'s next Friday.
[Re: Wookie316]
#2340874
07/21/17 11:34 AM
07/21/17 11:34 AM
Posts: 326 Alberta
Wookie316
Alberta
I am spoiled in a B body with an Alterkation front end. Tons of room. I know anything in an A body can be a pain. Helped an bud put a 400 in his Duster last year. Inner fenders were removed and it was still a pain.
[Re: Wookie316]
#2340985
07/21/17 03:07 PM
07/21/17 03:07 PM
Posts: 326 Alberta
Wookie316
Alberta
I am at the low low weight of 4100 at the line with full cell and tubby manning the wheel.
[Re: Wookie316]
#2341060
07/21/17 05:47 PM
07/21/17 05:47 PM
Posts: 326 Alberta
Wookie316
Alberta
If it was kilo it would be 9020 pounds. Yikes.
[Re: Wookie316]
#2341212
07/21/17 10:42 PM
07/21/17 10:42 PM
dartman366
Mt. Vernon, Ohio
I know anything in an A body can be a pain. Helped an bud put a 400 in his Duster last year. Inner fenders were removed and it was still a pain. yes it is, ask me how I know. LOL
[Re: Wookie316]
#2341339
07/22/17 02:53 AM
07/22/17 02:53 AM
Posts: 326 Alberta
Wookie316
Alberta
Yeah probably get started Sunday night. Has to be running Wednesday so I can load Thursday. Weather forecast changed though and not looking great for next Friday.
[Re: 10secGTX]
#2341586
07/22/17 06:44 PM
07/22/17 06:44 PM
Posts: 326 Alberta
Wookie316
Alberta
I am sure many would line up to test.
[Re: Wookie316]
#2343150
07/25/17 04:53 PM
07/25/17 04:53 PM
Posts: 326 Alberta
Wookie316
Alberta
It is sitting in car. Should be all back together no later than tomorrow night. All ready for Friday night test and tune.
[Re: Wookie316]
#2343506
07/26/17 04:31 AM
07/26/17 04:31 AM
Posts: 326 Alberta
Wookie316
Alberta
Photobucket wants $ from me and it isn't happening. Any other ways to post a photo? Got it running tonight. Get the hood on tomorrow and check things over. Should be ready to test Friday.
[Re: dogdays]
#2343928
07/26/17 09:49 PM
07/26/17 09:49 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
How to attach a picture has been posted many times. After you finish your post, click on File Manager below the post. It opens a new window and asks you what picture you'd like to attach. I use the "Browse" button and find it on my computer. Open the pix on my computer, it appears in the new window. Hit Add Picture. If you have another picture go back to Browse and get it. When you're done, hit Done Adding Pictures Thanks, as you can see it worked, Thanks again ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: Wookie316]
#2344292
07/27/17 01:25 PM
07/27/17 01:25 PM
an8sec70cuda
[Re: Wookie316]
#2345110
07/29/17 03:32 AM
07/29/17 03:32 AM
Posts: 326 Alberta
Wookie316
Alberta
Ran 10.21 @ 133 with a 1.45 60 foot. All smiles here.
[Re: Wookie316]
#2345257
07/29/17 01:39 PM
07/29/17 01:39 PM
Posts: 326 Alberta
Wookie316
Alberta
That was 7000. It likes RPM. Not stumbles or hiccups at all. 60 is down a bit from spray which I expected. Maybe an adjustment will help not sure? Have tach video I'm going to send Lenny and see what he thinks?
