Re: Buy viking or Afco
[Re: dodgeram1998]
#2342623
07/24/17 07:26 PM
07/24/17 07:26 PM
Posts: 10,044 MN
JERICOGTX
MN
The 125's will work well for you at that weight.
69 GTX
68 Road Runner
[Re: dodgeram1998]
#2342928
07/25/17 07:52 AM
07/25/17 07:52 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
afco 3850 for the rear 3855m for the front .
afco recommended me there 125# springs
with a guesstimate of 1600 pounds on the rear
my car is 3375 with me ready to race
what size springs do other duster guys use, Did you do your home work and measure the length required for your car???? I would not just go with there recommended shock length, Take the time and measure.
[Re: dodgeram1998]
#2342979
07/25/17 11:45 AM
07/25/17 11:45 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
We run Strange DA on the rear of the heads up car. They do have their Pro Mod valving in them too. Been great for us and we are handcuffed by running a very short shock because of the body style of the car.
As for spring rate you just need enough spring to hold the car up with the shock at ride height.
[Re: dodgeram1998]
#2350020
08/07/17 01:07 PM
08/07/17 01:07 PM
Al_Alguire
Las Vegas
Hood scoop or no? Fuel pressure on big end? RPM where it is occuring? More info on the combo and whats going on up top will help.
[Re: MR_P_BODY]
#2350508
08/08/17 03:06 AM
08/08/17 03:06 AM
Posts: 312 illinois
dodgeram1998
illinois
1.33 60 4.042 330 6.35 1/8th@ 106.25mph 10.07 1/4@ 131.66mph
hp innovation e 85 carb PLEASED with .130 seats
1050 dommy relative flat fuel curve entire pass of .077 thru .086 lambda with jetting changes never changed mph at the stripe of 131.66 every time? timing locked every pass. car has run previous 9.92 with home built QFT 1050/4150 better weather ? cant compare don't have the data making pass at just before 1000ft it seems to stay stuck on 6700 rpm and cross at 6700
