Re: Weird MoPar interchangability.....
[Re: mopars_1]
#23414
12/03/09 10:28 PM
12/03/09 10:28 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Gen II Dakota rally instrument clusters appear to be identical to those first used on '80's FWD Dodge Lancers and Chrysler Lebaron GTS.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Greg55_99]
#23419
12/03/09 11:55 PM
12/03/09 11:55 PM
Posts: 6,342 SE PA.
QuickBpBp
SE PA.
Didn't see these sooooo.... Easy one 70-6 A-body sport mirrors switch bases and they become '70 E-body only mirrors.. Easy #2 68 coronet grille same As 69 Charger 500 #3 Some mid sixties slant 6 air cleaner lids are the same as the 64 big block lids and just like the chrome version 273 commando air cleaners... Next one little harder '68 Valiant front park lamps same as '69 Daytona Charger... Hard one '70-2 Dart/Valiant a/c water valve is the same as 71-2 B-body Strato vent valve... That's all for now...
[Re: QuickBpBp]
#23421
12/04/09 12:33 AM
12/04/09 12:33 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
mmmmm, two opinions ( just opinions ) about that.
70 cup shape is diff than 71 and laters ( on ANY body ), being outer curves more sharpened to 70s
then also the recesed area to fit pedestal on cup... I don't think will match the angle and shape.
dunno what pieces exactly I found the difference, but is a fact I tried to make a mix betwen some mirrors and the recesed area on cup didn't match, and they were all 71 and laters B bodies units, so If this is for same cup shape and just year difference, you can imagine between diff cup shape, and even more on diff body
[Re: autoxcuda]
#23423
12/04/09 02:00 AM
12/04/09 02:00 AM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
OK... while not strictly "MoPar".... I'm pretty sure my Jensen Interceptor has an early 70's E body remote driver's side mirror... I know my PW motors in my Jensen are 70's MoPar power window motors, I swapped mine out, same part# and all.... Factory air cleaner on my car is the factory big block dual snorkle Mopar air cleaner...
CrAzYMoPaRGuY
#23424
12/04/09 09:47 AM
12/04/09 09:47 AM
Posts: 1,061 New Mexico
dmerc
New Mexico
The rubber tips used on rear package trays of hatchback Omni's, Shadows, etc. are the same as the tips used on 60s/70s mopar sunvisors.
That's really great to know! I need a couple of those. Wonder if they can be had from the dealer?
[Re: magnumcharger]
#23426
12/04/09 03:29 PM
12/04/09 03:29 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Pretty well ALL of the consoles in B and C bodies of each year are the same...
Since you capitalized ALL, a couple exceptions are: 70 Fury same as B; 70 Chrysler is different, 65 Chrysler has different top plates from B and Fury, 65 Monaco 500 extends 2-3" into the rear bench seat (which is unique), 66 Charger is full-length, 1-year-only.
Probably a few other years I overlooked.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#23428
12/04/09 04:56 PM
12/04/09 04:56 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Speaking of late 50's dual quad air cleaners, the filter elements are the same as on older Cherokee 140's. Seriously.
Lead, follow or get the hell out of the way
[Re: slantzilla]
#23429
12/05/09 07:09 AM
12/05/09 07:09 AM
Posts: 2,177 ill
dennismopar73
ill
[Re: dennismopar73]
#23430
12/05/09 07:42 AM
12/05/09 07:42 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I've found all of the numbermatching bigblock Mopar engine blocks from highdollar '69/'70 Mopars fit my fullsize Chryslers just fine and are even more fun to drive and abuse... The larger B-body poly-urethane leafspring frontbushings fit '65 C-bodies just fine aswell. The smaller bushings fit earlier Chryslers just aswell. All poly shackle-bushings interchange aswell. Same goes for poly-urethane strutrod bushings although the inner ones have to be ground down.
[Re: dennismopar73]
#23431
12/05/09 09:21 AM
12/05/09 09:21 AM
Posts: 4,285 Ohio
64dodge572
Ohio
if you overbore a 413 120 you can make a 426 wedge
+.120 bore on a 413 block (4.19+.120=4.31) makes a +060 over 426 or 437ci!!
[Re: dennismopar73]
#23432
12/05/09 09:24 AM
12/05/09 09:24 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
413 +.070os makes a 426, not 413 +.120os
[Re: B5 Bee]
#23433
12/05/09 11:54 AM
12/05/09 11:54 AM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
The speed-warning device in the passenger seat of a 70 'Cuda telling the driver to slow down can be installed in other cars with the exact same functionality.
