Re: Cam selection questions
[Re: ahy]
#2357893
08/21/17 11:52 PM
08/21/17 11:52 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
I think anything over 235 or so degrees at .050" will be plenty "lumpy". What will be nice to drive? Also not beat up the valvetrain too much for street driving?
I think the Lunati at 243 degrees duration fits the bill. Would probably do OK with stock Eddy springs also.
FWIW, I run an "MM lobe" 243 @ .050" duration and .55 lift on a 496 and like it. It works OK with power brakes also... much more cam would not. I ran a "MM Lobe" 259 @ .050 and .585 lift in my 470 and I liked it a lot. I did add a vacuum canister for the power brakes though. I'm probably going to put that cam back in the 496 when it's done.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: Sledge_57]
#2358316
08/22/17 09:41 PM
08/22/17 09:41 PM
Posts: 3,095 Idaho
Runner
Idaho
FWIW, I run an "MM lobe" 243 @ .050" duration and .55 lift on a 496 and like it. It works OK with power brakes also... much more cam would not. I ran a "MM Lobe" 259 @ .050 and .585 lift in my 470 and I liked it a lot. I did add a vacuum canister for the power brakes though. I'm probably going to put that cam back in the 496 when it's done. were both of these speced by muscle motors? and are they on a 112 lsa? the 259@.050 cam looks like the cam in my 470 from muscle motors. i am happly with it, but i think i would have rather called up dwayne and got what he sugested
[Re: Runner]
#2358452
08/23/17 03:58 AM
08/23/17 03:58 AM
Sledge_57
Dearborn Hts, MI
were both of these speced by muscle motors? and are they on a 112 lsa? the 259@.050 cam looks like the cam in my 470 from muscle motors. i am happly with it, but i think i would have rather called up dwayne and got what he suggested Yes the 259@.050 was, my 470 was also built by MM and I think that was their cam of choice for a lot of those 470's A shame Mike's closing shop, I wanted them to build my new engine...
Doug
