RR survivor engine bay #2334344
07/09/17 09:47 PM
07/09/17 09:47 PM
Omaha
road Offline OP
road  Offline OP
Omaha
Own a survivor 69 RR and would like to find some contacts to ask questions about possibly improving the appearance of the engine bay area. What could be done.
Re: RR survivor [Re: road] #2334519
07/10/17 03:10 AM
07/10/17 03:10 AM
between the coasts
4mayhemi Offline
4mayhemi  Offline
between the coasts
Originally Posted By road
What absolutely not to do or what can be done to the car
Some things and anything. Mix or match question and answer.
. . . so you're looking to buy a non-restored RR? Can you be a little more specific?
Re: RR survivor [Re: road] #2334571
07/10/17 10:38 AM
07/10/17 10:38 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Doing ANYTHING to "improve" the appearance of a survivor is a VERY bad idea. You will essentially be erasing history which is what makes a survivor so special. People that will be interested in a survivor car appreciate and understand the fact that they aren't always "pretty", that dirt and wear are signs of a good honest original car that hasn't been messed with.
Here are a couple survivor Hemi engines. True survivor fans go nuts over engines that look like this, they don't need to look pretty to impress.
Re: RR survivor [Re: road] #2334574
07/10/17 10:44 AM
07/10/17 10:44 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Can you post a picture for us? Maybe we can offer some suggestions. It's only a survivor so long as it's original so I would be very hesitant to do much. Maybe a gentle cleaning if there's an excessive amount of dirt from gravel road driving of years of winter driving, etc.
Re: RR survivor [Re: road] #2334594
07/10/17 11:18 AM
07/10/17 11:18 AM
UP
finn Offline
finn  Offline
UP
Once it's repainted, it's neither original nor a survivor.
Clean it. Gently.
Re: RR survivor [Re: road] #2334957
07/10/17 09:48 PM
07/10/17 09:48 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I would just clean it. I don't see any reason for an accumulation of grease & dirt just because some previous owner neglected to keep the car clean.
I also don't understand people who leave worn-out parts like plug wires on an engine that needs them replaced to run properly; clean & bag the originals, put on the most accurate/correct replacements you can find, and respect the car. Same for leaking gaskets, dry-rotted tires, shredded upholstery and rust-through.
Re: RR survivor [Re: road] #2334983
07/10/17 10:24 PM
07/10/17 10:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The problem with cleaning is that many subtle details can be easily lost in that effort, grease pencil markings, etc. are extremely fragile and not always visible or obvious until halfway removed, it's easy to wipe most of them right off.
If selling is the goal, I'd recommend against it and let the buyer see it as is and decide where to go from there. .02
Re: RR survivor engine bay [Re: road] #2335088
07/11/17 12:29 AM
07/11/17 12:29 AM
between the coasts
4mayhemi Offline
4mayhemi  Offline
between the coasts
If you just bought it like your original post implied then it could help to post pictures here. There have been many a car listed as "survivor" in the WIW and some keen-eyed mopartians have found multiple items that disqualify some as "survivor."
It's not to tear your RR apart, but if there's a lot of non-wear replacement items that might answer some what-to-do questions. If it turns out solid, that's a bonus for you too.
There will probably be (and already are) 2 camps in this thread. Post the pics and let em discuss and we all learn something.
Re: RR survivor [Re: ScottSmith_Harms] #2335095
07/11/17 12:40 AM
07/11/17 12:40 AM
between the coasts
4mayhemi Offline
4mayhemi  Offline
between the coasts
Funny thing, if that Hemi was eat-on clean, and I dribbled a tear of oil on the plug wire, I would think "oh #$%& what have I done!" And in its current patina condition, if I cleaned around the oil cap fill hole (like I always do from habit) I would think "oh #$%& what have I done!"
Re: RR survivor [Re: road] #2335205
07/11/17 10:45 AM
07/11/17 10:45 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Ok...if a grease pencil mark is not able to be seen covered in dirt, and cleaning it will render it gone or illegible, why does it matter? If it cant be seen, and cleaning removes it, it doesnt really exist anymore, except in a sort of "shroedingers cat" kind of context.
Re: RR survivor [Re: road] #2335223
07/11/17 11:16 AM
07/11/17 11:16 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It's a matter of knowledge and cleaning techniques. IMO its something that should be left in the hands of an expert, just like cleaning a valuable painting, you don't just break out the Purple Stuff and a shop towel and have at it.
Re: RR survivor [Re: road] #2335254
07/11/17 12:07 PM
07/11/17 12:07 PM
A collage of whims
A collage of whims
True; you want to document it with photos and be thoughtful, not just blast away with degreaser & steam-cleaning. If resale is the goal, maybe leave it as is. For the cars I've kept around to enjoy, I've never understood leaving leaks and worn-out parts, but other things like wear on paint & such free me from worrying about perfection. I've always had a thing about cleanliness on my stuff, but as the saying goes, they're only original once.
Photos would help - and they're always interesting - and should illustrate the level of survivorship and any attention the car might/might not benefit from. At this point, there's not enough info.
Re: RR survivor [Re: topside] #2335299
07/11/17 01:28 PM
07/11/17 01:28 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Yeah what Scott said about the purple cleaner it will dull paint and once I learned the hard way cleaning an original road runner horn, it ruined my voice of the road runner decal. I was sick!
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: RR survivor [Re: mopargem] #2335383
07/11/17 04:07 PM
07/11/17 04:07 PM
florida/ Georgia
Tom Fox Offline
Tom Fox  Offline
florida/ Georgia
Should Have Used Acme Degreaser, Would Have Been Fine. boogie
Re: RR survivor [Re: Tom Fox] #2335423
07/11/17 06:02 PM
07/11/17 06:02 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
drumhit
Re: RR survivor [Re: mikemee1331] #2335484
07/11/17 08:15 PM
07/11/17 08:15 PM
Omaha
road Offline OP
road  Offline OP
Omaha
pic
Re: RR survivor [Re: road] #2335485
07/11/17 08:17 PM
07/11/17 08:17 PM
Omaha
road Offline OP
road  Offline OP
Omaha
pic
Re: RR survivor [Re: road] #2335488
07/11/17 08:24 PM
07/11/17 08:24 PM
Omaha
road Offline OP
road  Offline OP
Omaha
pic
Re: RR survivor [Re: road] #2335491
07/11/17 08:27 PM
07/11/17 08:27 PM
Omaha
road Offline OP
road  Offline OP
Omaha
pic
Re: RR survivor [Re: road] #2335492
07/11/17 08:27 PM
07/11/17 08:27 PM
Omaha
road Offline OP
road  Offline OP
Omaha
pic
