So, impacting the toe isn't the issue, but impacting the camber is. I see what you mean.
I can mark the rear cam bolt location, move the front one back out a bit and then bring the rear out a bit. It may not be perfect, but I can trial and error it enough to get it to go down the road straight like it does now. Then I'll drive it awhile and see if I want to put it back on the rack.
Wheel alignment has always been one of those things that I had no real grasp of the details. Through this process, I have not only gotten the Cuda to go down the road straight, but I have learned a lot about camber and caster and what they do.
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
again
