Page 1 of 9 1 2 3 4 5 6 7 8 9
Weird MoPar interchangability..... #23334
02/07/06 10:17 PM
02/07/06 10:17 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
I remember hearing a 1969 Barracuda hood would directly interchange with a 1973-1976 Dart a long time ago, though I never actually tried it so I don't KNOW it's true.
Is there any other weird interchanging that can be done...?
When I tried B body Wilwood discs on my 1969 C body front end, I found out that although my C body spindles had the Wilwood hub 1/4" farther away from the hub's base- the inner and outer bearings were the same part # and the swap was relatively easy....
CrAzYMoPaRGuY
Re: Weird MoPar interchangability..... [Re: CrAzYMoPaRGuY] #23335
02/07/06 11:13 PM
02/07/06 11:13 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
That same 67 to 69 Barracuda can interchange their front and rear bumpers.
Here's one I'm sure no one will ever use but it sure came in handy for me one time ago. Driveshaft from a 72 Dart 904, 7 1/4" perfect fit into a 79 New Yorker after 440, 727 and 8 3/4" swap.
Wheels of any LH car which is has a metric 5 x 114 mm will fit our 5 by 4.5". The center register is a nice snug fit too. Caution: Don't try this at home the offset is
2.2L K car alternator with V belt. Direct bolt in.
Re: Weird MoPar interchangability..... [Re: Magnum] #23336
02/07/06 11:37 PM
02/07/06 11:37 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Door handles from 80's and 90's Dodge trucks will fit 68-70 B bodies.
Re: Weird MoPar interchangability..... [Re: Magnum] #23337
02/07/06 11:39 PM
02/07/06 11:39 PM
Canada
Canada
Haha!
Reminds me of my J body 1980 Cordoba LS- I met a guy at a swap meet, and talking with him, I told him I had an 8 3/4" rear end, a 440, and a 727 transplanted into my car.
He then told me to find a long box 70's ClubCab Dodge pickup, and take the rear half of the two piece driveshaft, and it would bolt right in.
Skeptical, I bought one at the wrecker, and sure enough.....
CrAzYMoPaRGuY
Re: Weird MoPar interchangability..... [Re: KillerBee] #23338
02/07/06 11:39 PM
02/07/06 11:39 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
fury turn signal lenses fit superbirds...
Re: Weird MoPar interchangability..... [Re: ph23vo] #23339
02/08/06 12:11 AM
02/08/06 12:11 AM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
They are super bird park lites )70 Fury III that is !
Re: Weird MoPar interchangability..... [Re: stateline] #23340
02/08/06 12:20 AM
02/08/06 12:20 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I just like the fact that my slant starter fits a Hemi
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Weird MoPar interchangability..... [Re: Rug_Trucker] #23341
02/08/06 12:27 AM
02/08/06 12:27 AM
Turn signal switch and canceling cam from up to 1976 Dodge Vans will work in a 65' Coronet Steering column.
Re: Weird MoPar interchangability..... #23342
02/08/06 12:34 AM
02/08/06 12:34 AM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Where is the guy who put a 70 dart rear bumper/valence panel on his 76 dart??? :
He is usually in here.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Weird MoPar interchangability..... [Re: CrAzYMoPaRGuY] #23343
02/08/06 12:40 AM
02/08/06 12:40 AM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I believe I read once upon a time that on a Chrysler Airflow, the right front and left rear doors will interchange as well as the left front and right rear. I know, not much use to most of us but I thought it was interesting!
Re: Weird MoPar interchangability..... [Re: CrAzYMoPaRGuY] #23344
02/08/06 12:52 AM
02/08/06 12:52 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Dodge truck hood hinges are also the same as B-body hinges.
Nautilus Racing-
Re: Weird MoPar interchangability..... [Re: Chris2581] #23345
02/08/06 01:04 AM
02/08/06 01:04 AM
I found that a Ford door striker bolt from the parts store would replace my broken one on my '71 Plymouth Satellite.
Also, a Ford dust cap cover for the wheel bearings from parts store will fit also. The Mopar one was too small...
Re: Weird MoPar interchangability..... #23346
02/08/06 02:35 AM
02/08/06 02:35 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The console from the 60 s Dart was also used in the 70s darts..
Re: Weird MoPar interchangability..... [Re: sthemi] #23347
02/08/06 02:51 AM
02/08/06 02:51 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
One of the 1970 Charger front bumper supports/brackets is the same exact part used on all 1966-71 Street Hemis as Alternator adjustment brackets.
Re: Weird MoPar interchangability..... [Re: sthemi] #23348
02/08/06 02:55 AM
02/08/06 02:55 AM
I'm taking note again keep on going
Re: Weird MoPar interchangability..... #23349
02/08/06 04:13 AM
02/08/06 04:13 AM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
Defroster vents from '71-up pickups and vans work on '63-'66 A bodys. Door arm rests from vans work on 4dr B bodys...probably others. The round dome light covers are found in alot of different models. Pedal dress up trim found on alot of Mopars work on B bodys. Remote trunk release from M bodys work on earlier cars. Inside door handles, window crank handles from trucks and vans work on B bodys.
Guess if it works, why change it?
Eric
Re: Weird MoPar interchangability..... [Re: ScottSmith_Harms] #23350
02/08/06 04:27 AM
02/08/06 04:27 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Get out.... really ? Got any pictures of this? That sounds neat...
hmmm what output rating do they have .
Re: Weird MoPar interchangability..... [Re: CokeBottleKid] #23351
02/08/06 04:33 AM
02/08/06 04:33 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Those NOS Hemi 71 E-body door hinges actually came off a seventies Dodge Pickup.
Sheldon
Re: Weird MoPar interchangability..... [Re: RUNCHARGER] #23352
02/08/06 06:51 AM
02/08/06 06:51 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
was told that the front left fender lower portion (body line and below) would interchange with the right rear quarter panel (body line and below) and same for other diagonal swap. This for plymouth cudas 70-74. have not tried this but eyeballing it it looks convincing.
Re: Weird MoPar interchangability..... [Re: CokeBottleKid] #23353
02/08/06 09:24 AM
02/08/06 09:24 AM
Butler, PA
romanucci Offline
romanucci  Offline
Butler, PA
I'm curious about that one, too. Does the K-car alternator still have an external regulator? Is it one field wire or two?
