Re: Need a little 70's d100 schooling [Re: earlymopar] #2339259
07/18/17 06:37 PM
07/18/17 06:37 PM
dogdays Offline
dogdays  Offline
A four headlight truck is basically a holdover 1964. So dimensions would be same as earlier. Does your truck have a nut on the end of the axle shaft?
R.
OP: '72 was the first of the new body style and had one-year-only front end suspension parts, so the fact it's a '73 makes it more desirable. As far as bed style, the short wide bed is in demand, too. I wouldn't stop the deal over a bed style issue. The truck is 44 years old, they don't come around in decent shape that often.
I looked at an '84 from desert SW and was disappointed to have floor rustout. I was told here that that's common as drains get plugged and water gets inside. It's not a deal killer, but is something to check for.
Re: Need a little 70's d100 schooling [Re: hosehead] #2341007
07/21/17 03:56 PM
07/21/17 03:56 PM
Grove, OK
hosehead Offline OP
hosehead  Offline OP
Grove, OK
Thanks dogdays! I'm not totally against the wide bed but it's the one part of the truck that is damaged and I always wanted a stepside. Although, after some searching, it seems that finding a nice stepside bed may be a bit difficult, so who knows.
Some real good info here though! I'll post pics here if I'm able to get the truck from my buddy. Thanks everybody for the help! You guys rule! bow
63 Plymouth savoy
65 d100
66 dart race project
58 plymouth suburban
Re: Need a little 70's d100 schooling [Re: hosehead] #2341103
07/21/17 07:17 PM
07/21/17 07:17 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Step side beds do seem to be scarce when your looking for one.
I had one shipped in from Iowa years ago. Rust free some dents and a few extra holes in it.
When I sold off my lil red and warlock parts and put the bed on Craigslist for $500 I received zero calls over several months. When I was moving I broke done and called a fellow dodge truck enthusiast who took it off my hands for $300.
Kind of frustrating as I was able to get $750 for a nos box side but no interest in the complete bed.
Red
Re: Need a little 70's d100 schooling [Re: hosehead] #2342443
07/24/17 02:53 PM
07/24/17 02:53 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
About 45% of the SWB runs were step-bed during the 70s
Metal floors started in 81, The company that pressed the sides for dodge was the same one that pressed the Chevy step bed sides, only difference is the ridges that Dodge requested, they were located in Kansans went out of business when GM went to the flare style plastic beds.
Bed sides are the same from 55-85, bed got wider sometime in the late 50's.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Need a little 70's d100 schooling [Re: hosehead] #2384104
10/08/17 09:05 PM
10/08/17 09:05 PM
Grove, OK
hosehead Offline OP
hosehead  Offline OP
Grove, OK
Aaaaaaaaannnd, it's all mine! laugh2 punkrocka
63 Plymouth savoy
65 d100
Re: Need a little 70's d100 schooling [Re: hosehead] #2384522
10/09/17 04:23 PM
10/09/17 04:23 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I notice an exhaust pipe poking out in front of the rear tire.
Where is the gas tank? Behind the seat?
Or is it one of those Heart Throb under the frame deals?
I am wanting to put duels on my 78 and am not sure just how to go about it.
Probably going to move my tank into the bed.
I have a behind the seat tank,
However, I'm not sure I wanna ride around with 20 some gallons of gas in the cab, behind the seat.
I have mechanical Aptitude.
I can screw up anything.
Re: Need a little 70's d100 schooling [Re: QuickDodge] #2468446
03/19/18 02:28 AM
03/19/18 02:28 AM
FL, US
gdc5200 Offline
gdc5200  Offline
FL, US
Originally Posted By QuickDodge
A 318 powered truck is probably the most common. A 73 may have 4 wheel drum brakes.
Starting 1973, all V8 cars and light trucks came with front disc brakes.
There is no neutral safety switch in life
Re: Need a little 70's d100 schooling [Re: gdc5200] #2468605
03/19/18 03:16 PM
03/19/18 03:16 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Not 4wd trucks. 1975 was the 1st year for discs on them. The 74 Ramcharger may have had discs though. I'd have to look it up.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Need a little 70's d100 schooling [Re: hosehead] #2468827
03/19/18 10:55 PM
03/19/18 10:55 PM
Paducah, KY USA Earth
jcruse64 Offline
jcruse64  Offline
Soopernaut is correct on the trucks, I believe. My '73 W200 has 4 wheel drum brakes. Can't remember if the light trucks might have had the front disc option, though.
Re: Need a little 70's d100 schooling [Re: hosehead] #2468863
03/20/18 12:10 AM
03/20/18 12:10 AM
Grove, OK
hosehead Offline OP
hosehead  Offline OP
Grove, OK
My little d100 has factory discs in front.
63 Plymouth savoy
65 d100
Re: Need a little 70's d100 schooling [Re: hosehead] #2468951
03/20/18 07:58 AM
03/20/18 07:58 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
From memory the discs were required starting in 77
I want my fair share
Re: Need a little 70's d100 schooling [Re: hosehead] #2469057
03/20/18 12:29 PM
03/20/18 12:29 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
In case you wanted to lower yours heres a really good looking truck. The "Tin grille Dodge Truck" group on facebook is pretty active and always has stuffer sale on it.
Re: Need a little 70's d100 schooling [Re: NV69B7RR] #2469061
03/20/18 12:32 PM
03/20/18 12:32 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Sharp truck
Re: Need a little 70's d100 schooling [Re: Soopernaut] #2469074
03/20/18 12:45 PM
03/20/18 12:45 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Disk were standard on 4x2s starting in 72 (drums were an option)
4x4s disk were standard on ALL models under 400 series the heavier series had drum in till the SEG (special equipment group) closed shop
After 35 years and parting out/scraping over 250 of these trucks I have only every come across 2 post 71's 4x4s with disk one was 72 W200 and the other was a 73W300
Re: Need a little 70's d100 schooling [Re: BIGGERED] #2469079
03/20/18 12:49 PM
03/20/18 12:49 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Originally Posted By BIGGERED
Hosehead
Here you go, this is for 78-81 things to note.
Box lengths both listed as 6.5" SW or SS
115" WB has 2 frames, D1 and W1 78-80, 81 is listed as separate part #s, this may be when the box mounting changed.
Note my 72-73 Manual shows a picture of the boxes but includes no panel part #, says order by description.
I have a 74-77 P Manual as well if you need more info.
Red
Rail stampings were identical between 4x2 and 4x4 only the X-members were different.
Re: Need a little 70's d100 schooling [Re: hosehead] #2469140
03/20/18 02:38 PM
03/20/18 02:38 PM
Canada
demon Offline
demon  Offline
Canada
No Dodge 4x4's came with disc brakes until 1975, except the 1974 Ramcharger.
Re: Need a little 70's d100 schooling [Re: hosehead] #2469177
03/20/18 03:31 PM
03/20/18 03:31 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
short beds are 6.5 feet long-----when you drop the tailgate that 4x8 sheet of plywood sits right there on the bed and tailgate---nothing hanging over the edge.....
Re: Need a little 70's d100 schooling [Re: savoy64] #2469841
03/21/18 06:05 PM
03/21/18 06:05 PM
Canada
demon Offline
demon  Offline
Canada
I bolted a 1961 dodge stepside bed onto my 74, and swapped beds between a 1975 Sweptside and a 1980 Stepside. 100% identical fit.
Re: Need a little 70's d100 schooling [Re: NV69B7RR] #2470182
03/22/18 01:33 AM
03/22/18 01:33 AM
SomeCarGuy Offline
SomeCarGuy  Offline
That’s sweet! What mirrors are those? and the air dam looks nice too, did you make it?
