Clutch fork I.D. #2332526
07/06/17 02:57 PM
07/06/17 02:57 PM
central IL reg Nov 18, 1999
Stroker Offline OP
Stroker  Offline OP
Is this an A body fork?
Just trying to figure out the clutch problems I'm having.
Re: Clutch fork I.D. [Re: Stroker] #2332544
07/06/17 03:19 PM
07/06/17 03:19 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Hard to say for sure from the one picture, but that looks like a 66-up big block B and E body as well as 67-69 BB a body fork. If it is it should be 10 7/8" long. Early A body clutch fork are 10 1/2" long.
You don't say what year A body you have or the engine your running. If its a 68-up small block, I can say its not the correct clutch fork as its too short. Here is a link to brewers sight to help, and they have great information on there website. http://www.brewersperformance.com/products.asp?cat=102
Matt
Re: Clutch fork I.D. [Re: Stroker] #2332621
07/06/17 05:00 PM
07/06/17 05:00 PM
Stroker Offline OP
Stroker  Offline OP
That one's pretty close to 10 7/8.
I have a '72 B body with a QuickTime bell and Tremec TKO 600. (small block)
I had a place swap trannys and ended up with a bent fork bracket.
Re: Clutch fork I.D. [Re: Stroker] #2332847
07/07/17 12:15 AM
07/07/17 12:15 AM
Stroker Offline OP
Stroker  Offline OP
It looks like the right one, according to the Brewer's link.
Thanks!
