Re: Clutch fork I.D.
[Re: Stroker]
#2332544
07/06/17 03:19 PM
07/06/17 03:19 PM
Posts: 3,136 tennessee,usa
mattsmopars
tennessee,usa
Hard to say for sure from the one picture, but that looks like a 66-up big block B and E body as well as 67-69 BB a body fork. If it is it should be 10 7/8" long. Early A body clutch fork are 10 1/2" long. You don't say what year A body you have or the engine your running. If its a 68-up small block, I can say its not the correct clutch fork as its too short. Here is a link to brewers sight to help, and they have great information on there website. http://www.brewersperformance.com/products.asp?cat=102Matt
[Re: Stroker]
#2332621
07/06/17 05:00 PM
07/06/17 05:00 PM
Posts: 2,271 central IL reg Nov 18, 1999
Stroker
That one's pretty close to 10 7/8. I have a '72 B body with a QuickTime bell and Tremec TKO 600. (small block) I had a place swap trannys and ended up with a bent fork bracket.
