Re: 1963 MAX WEDGE Welded VIN tag question [Re: eddie23] #3031873
04/08/22 02:39 PM
04/08/22 02:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's how those VIN tags were attached in that era, my '63 & '64 were the same.
Rad support #s are same as bottom left row on fender tag: Sequential order # info.
Good ol' Calif DMV: still making things as difficult as they can.
Several places to decode the tag, mymopar.com & etc - Google's your friend.
Print & take as much paperwork as you can to the DMV to document the car.
Re: 1963 MAX WEDGE Welded VIN tag question [Re: eddie23] #3031965
04/08/22 07:47 PM
04/08/22 07:47 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by eddie23
I'm trying to register a 1963 Plymouth Sport Fury Max Wedge Convertible in CA and they're questioning the authenticity of the vin tag. Can anyone confirm this looks authentic? They've also asked me what the number imprinted on the radiator mount is and I'm assuming it's something corresponding to the motor but not sure. Also, can anyone help decipher the inside fender codes attached?
Contact Darrell Davis, he is on Facebook.
The SO number in the tag matches that of the core support so at least the front of the car looks correct.
Not sure where the rear number is on a convertible, on the hardtop and sedan it’s stamped passenger side package tray next to backlight.
0520 is May 20. The last 4 is the sequence number.
The whole 8 digits will match that of the IBM card available through Chrysler/DaimlerChrysler/FCA/Stellantis Historical.
Hurry up before they change their name again
Re: 1963 MAX WEDGE Welded VIN tag question [Re: eddie23] #3032828
04/12/22 09:28 AM
04/12/22 09:28 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Those all look legit , good luck dealing with the idiots at the DMV .
Re: 1963 MAX WEDGE Welded VIN tag question [Re: A727Tflite] #3036780
04/25/22 02:50 AM
04/25/22 02:50 AM
Melbourne
O
ossietim Offline
ossietim  Offline
O
Melbourne
Re: 1963 MAX WEDGE Welded VIN tag question [Re: A727Tflite] #3094740
11/16/22 04:37 PM
11/16/22 04:37 PM
minnesota
dk426 Offline
dk426  Offline
minnesota
the fender tag on that sport fury convert should have a 9 under the a to be a max wedge car
