Page 9 of 11 1 2 7 8 9 10 11
Re: My bracket hemi build [Re: Triple Threat] #2361123
08/28/17 12:08 PM
08/28/17 12:08 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
15 more runs Saturday. All on the throttle stop for 10.90 practice. Managed to win Super Pro and Super Street.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My bracket hemi build [Re: Triple Threat] #2361583
08/29/17 08:47 AM
08/29/17 08:47 AM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Congrats! beyond impressive...
Re: My bracket hemi build [Re: Triple Threat] #2361723
08/29/17 01:14 PM
08/29/17 01:14 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
have you checked the rocker tips? how do they look
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: My bracket hemi build [Re: Triple Threat] #2361762
08/29/17 02:03 PM
08/29/17 02:03 PM
Renton Washington
Renton Washington
The valve covers haven't been off since May of 2016.
I'll give them a look this winter as I'm planning to freshen the engine.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2388105
10/16/17 11:34 AM
10/16/17 11:34 AM
Renton Washington
Renton Washington
Well this season is officially in the books after yesterday. 194 runs on the year.
Also ran a new best yesterday, Incrementals
1.37
6.17@111.08 mph
9.743@136.90 mph
Only change from my normal bracket set up was tossing on a set of 325/50/15 drag radials. 2 inches less height and radial construction was worth quite a bit. The car still wants more gear, it likes shifting around 7300 but is only going through the traps around 6900.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2388213
10/16/17 02:44 PM
10/16/17 02:44 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
1.37
6.17@111.08 mph
9.743@136.90 mph
This post is deserving of a "new best thread"
On the class racer forums, they say that you want to hit peak hp at the 1000 ft mark. So if your peak is 7300 than you want to hit that at 1000ft and than pray you dont break a valve or spring the last 320 60ft
Re: My bracket hemi build [Re: Triple Threat] #2388253
10/16/17 04:01 PM
10/16/17 04:01 PM
Renton Washington
Renton Washington
There is a new best thread in race only, I'm keeping my updates here so everything is tracked in one location for people to follow along and to easily look back on the progress from 10.20's to 9.70's
I think 4.56's would be ideal for this engine, with a trap rpm of 7600+ that would take advantage of the acceleration early like the class cars do. However, with as many runs as I make I don't like the idea of leaning on it that hard. Someone else can have that honor and the glory.
Would be fun to put this engine in a lighter car. In bench racers theory, a <2800# car, 904 trans and more rear gear should be capable of high 8's
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2389358
10/18/17 02:43 PM
10/18/17 02:43 PM
wa.state
raceadodge Offline
raceadodge  Offline
wa.state
I hope I will be doing that very thing next year, but with a 2500# car 727 trans and 430 gears.
Re: My bracket hemi build [Re: Triple Threat] #2392060
10/23/17 09:09 PM
10/23/17 09:09 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I'm thinking out loud here and your car is impressive!
Could it be that your heads are too big?
Wonder if less flow top end , which most of the time = more mid range , would work better?
I was always under the impression that there are two ways to feed a port.
RPM or CID.
Once again impressive car!
Matt
Re: My bracket hemi build [Re: Triple Threat] #2392099
10/23/17 10:44 PM
10/23/17 10:44 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am close to pulling the trigger on one of these. My Cuda weighed 3250 with an iron block Hemi and alum heads. Never got to weigh it qith the all alum 605 in it, but it felt lighter than anything else I have run in it...Figure one of these would put to 3100 or so....That little engine would run pretty good in my junker at that weight.
What compression is yours?
Re: My bracket hemi build [Re: MattW] #2392178
10/24/17 01:40 AM
10/24/17 01:40 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
RPM or CID.
Matt
I have already posted on moparts my step by step port on apache heads and what to expect on flow. I do not make them big.
The stock port size is bigger than Chip's ports on his 572 hemi
Re: My bracket hemi build [Re: Triple Threat] #2409427
11/26/17 11:58 PM
11/26/17 11:58 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Dustin when you first put this deal in the car, it fit under the Hemi scoop, right?
If I recall that correctly, what was the intake that you used??
Thanks!
Re: My bracket hemi build [Re: Triple Threat] #2409668
11/27/17 03:43 PM
11/27/17 03:43 PM
Renton Washington
Renton Washington
Short Ritter 4500 with no spacer under the carb and no air cleaner it barely fit.
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2410123
11/28/17 01:08 PM
11/28/17 01:08 PM
cudadoug Offline
cudadoug  Offline
Thanks, Dustin.
Re: My bracket hemi build [Re: Triple Threat] #2499839
05/24/18 03:04 AM
05/24/18 03:04 AM
SoCal
Brian Hafliger Offline
SoCal
Dustin, did you use TTI headers or ??? If so, can you get a diaper on the engine with them?
One more...car or truck timing cover?
Thanks!
Brian
Brian Hafliger
Re: My bracket hemi build [Re: Brian Hafliger] #2500289
05/25/18 12:12 PM
05/25/18 12:12 PM
Renton Washington
Renton Washington
Thanks!
Brian
2" TTI Headers
I have a Generic Summit Diaper on the car, most of which ended up melting to said headers. It's not the best situation, but since the headers basically touch the block and pan, there aren't a lot of options. NHRA requires me to have a diaper to Run Super Street, and they never questioned it.
Truck cover, modified to work with the motor plate
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2500403
05/25/18 05:18 PM
05/25/18 05:18 PM
SoCal
SoCal
Thank you...I'm doing a similar build to yours and a customer of ours for my duster...finally.
I think I'll do custom headers so the diaper goes on without that problem.
Brian Hafliger
Re: My bracket hemi build [Re: Triple Threat] #2501733
05/29/18 12:51 PM
05/29/18 12:51 PM
Renton Washington
Renton Washington
I think that would be best. If you can run the rear tube through the inner fender like a SB hedman header you'd be in much better shape. Starter access and everything else is a pain with the TTI's
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #2502041
05/29/18 11:22 PM
05/29/18 11:22 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I tried running a diaper with my 2” TTIs and ran into the same issue. Ended up fabricating a belly pan lined with pig mat to keep the local track officials happy.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: My bracket hemi build [Re: 71yelladustr] #2502348
05/30/18 04:57 PM
05/30/18 04:57 PM
SoCal
SoCal
Do you have any pics of it?
Thanks!
Brian Hafliger
