Page 2 of 3 1 2 3
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2333313
07/07/17 09:57 PM
07/07/17 09:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
This is a very worthwhile reminder. I had good luck with Sta-bil + running it with the fuel pump shut off until it stalled + a little marine fogging oil at the end. Sat for 4 years, ran the fuel pump and it fired right up. I've had the bowls off a few times since, am thankful to not have found any creeping crud in there.
Rich H.
Esse Quam Videri
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2333684
07/08/17 04:31 PM
07/08/17 04:31 PM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
I learned the hard way also. On one of my cars, I put it away during the winter, and discovered in spring time my needle and seats became so hardened they wouldn't hold the float level anymore. Also my mechanical fuel pump stopped working, and was filled with a powder form of gas. What I do now, I get 5 gallons of 110 vp race gas, run it through and put it away with that, no more problems.
Re: Reminder: Don't put your carb away "wet"... [Re: 70gtx1] #2461148
03/04/18 09:26 PM
03/04/18 09:26 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Bump...
Got "bit" again. Found the secondary accel pump needle below the nozzle screw on one of the aluminum body carbs we dynoed in October has corroded in place.
I've sqirted brake cleaner in the passage from both directions, did the same with WD-40, blasted air from the metering block passage... still stuck. Guess I'll let it sit with more WD-40 in the passage hoping it'll free up.
My OPINION at this point is that an aluminum carb that is used with fuel that contains any alcohol should be completely disassembled if it's going to be sitting around for more than a few weeks.
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461157
03/04/18 09:49 PM
03/04/18 09:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why I don't mind race gas or at least mixing in my street-er............never see that even when it used to sit for a month or more............ beer
Re: Reminder: Don't put your carb away "wet"... [Re: Thumperdart] #2461167
03/04/18 09:59 PM
03/04/18 09:59 PM
BradH Offline OP
BradH  Offline OP
Got a suggestion for something better to loosen that check needle?
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461203
03/04/18 11:01 PM
03/04/18 11:01 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Switched to E85 last year for the octane and price. After the winter weather ended the fun for the year, I drained the cell and ran a couple gallons of pump gas through the pump and lines and caught the return line fuel in a jug. Ran the gas out of the carb, then removed it and completely disassembled it and removed all traces of any fluid. I had the E85 in there all last summer with no corrosion in the naked aluminum fuel cell, and nothing in the carb. or Al fuel lines. Don't know if I'm stupid lucky or what,but I didn't see any of the horror stories some E85 users speak of.
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461205
03/04/18 11:07 PM
03/04/18 11:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
PB Blaster is pretty aggressive. Or some kind of mild acid, like the stuff you clean nasty aluminum with to weld it. Blow gun from the metering block side of the carb body. Just be careful where it's aimed or cover the top with a towel.
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461216
03/04/18 11:40 PM
03/04/18 11:40 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
So you didn’t even try to dump an 8 dollar bottle of stabilizer in to at least see if it would save you any grief?
I want my fair share
Re: Reminder: Don't put your carb away "wet"... [Re: SomeCarGuy] #2461243
03/05/18 12:15 AM
03/05/18 12:15 AM
BradH Offline OP
BradH  Offline OP
Engine went from dyno back to stand. Carb was drained of 50/50 pump 93 E10 / leaded race fuel and put on shelf. Residual fuel in accel pump circuit corroded. Not sure where the bottle of stabilizer was supposed to used in this situation.
Re: Reminder: Don't put your carb away "wet"... [Re: CMcAllister] #2461246
03/05/18 12:20 AM
03/05/18 12:20 AM
BradH Offline OP
BradH  Offline OP
PB Blaster... yeah, ran out of it before this problem turned up. Give that a try next.
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461305
03/05/18 02:06 AM
03/05/18 02:06 AM
AndyF Offline
AndyF  Offline
Brad - unheated garage? I wonder if that makes it worse. I usually just drain the carbs but I do not take them apart and I haven't had any issues. But I keep my shop at 65 degrees so maybe that helps?
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461313
03/05/18 02:17 AM
03/05/18 02:17 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Do you have access to an ultrasonic cleaner? They work great and can get solvent to reach to both sides of the needle to loosen it.
Re: Reminder: Don't put your carb away "wet"... [Re: AndyF] #2461314
03/05/18 02:18 AM
03/05/18 02:18 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Let me see if I got this straight.
Ride them hard and put them away dry coffee
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461331
03/05/18 03:50 AM
03/05/18 03:50 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I put a dab of oil in the passage and use a steel pointed poker and pry in the slotted area and rock it back n forth with and then use compressed air on the inlet side on the main body face if needed........Rubber hammer to knock it loose if that doesn't work..........
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461334
03/05/18 04:02 AM
03/05/18 04:02 AM
SomeCarGuy Offline
SomeCarGuy  Offline
Dyno fuel cell...
Re: Reminder: Don't put your carb away "wet"... [Re: SomeCarGuy] #2461354
03/05/18 08:49 AM
03/05/18 08:49 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^This is what I use so far so good ^^^ coffee
Re: Reminder: Don't put your carb away "wet"... [Re: SomeCarGuy] #2461374
03/05/18 10:10 AM
03/05/18 10:10 AM
BradH Offline OP
BradH  Offline OP
Dyno fuel cell...
Not my dyno. Guess I r an an idjit.
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461471
03/05/18 02:07 PM
03/05/18 02:07 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Got an 87 ford box van I bought new, 48,000 original miles, I use for my work. 460 ci. Might sit 4-6 months or longer at a time, starts right up and runs fine (holly carb) but all this talk has got me worried a little. If it ain't broke I ain't touching it. Always used whatever was at the pump, leaded reg at first, now 10% corn.
Re: Reminder: Don't put your carb away "wet"... [Re: cudaman1969] #2461472
03/05/18 02:15 PM
03/05/18 02:15 PM
BradH Offline OP
BradH  Offline OP
Responses in no particular order...
Andy -> My garage leads directly into my basement / psuedo shop; carbs are stored there where it's climate controlled
Dominic -> If the PB Blaster soak doesn't free it up, mebbe I'll ship it to Hesperia for you to hammer on it
RTS -> Nope, no ultrasonic cleaner access of which I'm aware
WHITEDART -> Ummm... yeah, pretty much; the more crap I'm seeing in my carbs, the I less want to leave it to chance they'll be good the next time I want to run 'em
Re: Reminder: Don't put your carb away "wet"... [Re: BradH] #2461595
03/05/18 06:07 PM
03/05/18 06:07 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Brad, I've had good luck with Kroil in these type of situations. Jim
Page 2 of 3 1 2 3
