Re: car body dolly wheels ??
[Re: His and Her 69's]
#2330601
07/03/17 11:56 AM
07/03/17 11:56 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
(the car is gutted except for the front and rear suspensions are on it yet) This was your problem. Other than the engine/trans, these are the heaviest items on the car. Remove those and two people can damn near carry the shell - ok, I'm exaggerating a little but you get my drift!
#2338134
07/17/17 12:48 AM
07/17/17 12:48 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
We bought a whirley jig back in 1992, got the offroad tire kit and the tires still are good to this day and support a car on the jig with no problem. I think I put air in them twice in 25 years. With that said, the right tires will be fine. I know I used hard plastic casters and they aren't fun in soft dirt and gravel.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Neil]
#2339703
07/19/17 01:53 PM
07/19/17 01:53 PM
Posts: 8,260 fredericksburg,va
cudaman1969
fredericksburg,va
Put down some plywood sheets, or 2x wood, and make tracks to and from for the car to roll on.
Move car. Stop. Reposition wood. Move car again. Repeat..... I was reading through to find out if someone mentioned this. What I was going to say. One other way (I going to try myself) is use 2/12s attached like a 4 post lift, stretchers in between. Just bolt together. I need to roll mine outside on gravel to sand blast. Put 1/1 strips on edge to keep from rolling off.
