Re: 273 DUAL 4 intake- can I use this on NEthing else?
[Re: Michael]
#232645
02/23/09 11:22 PM
02/23/09 11:22 PM
dogdays
OK, I am here long enough to give you another real idea. But first some reality... The 273 and 318 heads use the same intake gasket and for the most part were the same castings. The first two years of the 273 had the intake bolts at a different angle but everything else is the same. 340/360 heads have the same port face with the same bolt holes and the ports are on same centerlines, but they are bigger. For a street engine you could put that intake on a 360 and it'd run great. So that's an excellent idea. The port mismatch isn't nearly as important as one may think. For that same reason a popular swap on 318s is a 340/360 stock intake, they are cheap and make a lot of power. I have one waiting for my 318, $15.00 at the swap meet and it even has nice paint on it.
But back to the Offy.....Put it on the 'bay and list it in the classifieds here for two months. No one will even give you a call. If you can get a decent price, like $100, sell it to them, take the $ and put it towards an intake you really want. After two months you will get tired of it, and aluminum prices are in the dumper like everything else, worth $12 for scrap. It'd be a shame to throw it away. Instead, you get a roller cam 318 like the one from my mother's 86 Fifth Avenue that's sitting in my backyard. Put a 4" stroker in it (optional). Port the 302 heads by yourself. Either plug the holes in the head and drill to your intake's angle or angle-slot the intake holes. You are enough of an artist to not ruin the intake by changing the angle of the holes. No need to "wallow them out" they just need an angle shift. Then regrind the hydraulic roller cam and run two 400-500 carbs. It'll look cool, run real strong up to the cfm limit of the heads, and you'll be the owner of something different. 318 - 391 cubic inches will be big enough to get you into orbit in your '38.
If you REALLY have to run 273 heads because you want to keep all the original bolt holes (I don't know why you'd want to do that)then get with some of the 273 drag racers here to get the best porting tips. They will work too, but I like the 302s better.
Either way do not saddle yourself with a 273 block unless you are a class racer. 318s are free anyway. The cost and difficulty of doing a right 273 rebuild make it a losing proposition. A 318 is exactly the same everything except the bores let the heads breathe better and the extra 45 cubic inches will make a lot of extra power.
Good Luck, R.
Re: 273 DUAL 4 intake- can I use this on NEthing else? pics
[Re: HotRodDave]
#232647
02/24/09 02:02 AM
02/24/09 02:02 AM
Posts: 16,164 Mesa, Arizona
dart4forte
Mesa, Arizona
273s and 318s used the same heads---- port size and all.
Sort of
64-66 273 had a weird intake bolt anfle but the same ports and other bolt patterns and they were small closed chambers. I think they were a 315 casting#.
67 318 and 273 both used a 920 casting head that was closed chamber and virtualy identicle to the 315 except the now more common intake bolt angle.
68-69 they again shared the same head and it was an open chamber head that except the casting number and AIR ports was pretty much unchanged til the 302 casting in 85
All correct except the heads in 66 went from the 5/16 to the 3/8 bolt eliminating the weird angle.
If building a 273 the 920 is the best head to use. You can actually get some good flow numbers out of that head. Here's a pic of my modified 920.
[Re: dogdays]
#232649
02/24/09 02:15 AM
02/24/09 02:15 AM
dart4forte
Mesa, Arizona
Good Luck, R.
On the 302's, we have flow number comparisons that show the stock 920 outflows the 302. With the same mods done to my 920 (stainless valves, bowl blending etc.) the comparison with the 302 still shows the 920 outflows the 302 with the 302 falling off just before .450 of lift. The 920 dosenty fall until after .450. As far as cost to do a 273, I've put together quite a few 273's and compared to the several 360's I've done the costs are pretty much the same. It all depends on how much machine work is needed. Of course if you go with forged pistons on the 273 the parts will be a little more. With the cast flat top piston, 9 to 1 to 9.5 to 1 is fairly easy on the 273.
[Re: HotRodDave]
#232650
02/24/09 02:17 AM
02/24/09 02:17 AM
dart4forte
Mesa, Arizona
What size valves do you have in there? What CC? Did you get them flowed before and after? I got a set of 920s sittin around on a complete 67 273 wondering what to do with the thing.
PM me
[Re: dogdays]
#232651
02/24/09 03:29 AM
02/24/09 03:29 AM
Posts: 470 Big Chicago
amixon
Big Chicago
O [
Put a 4" stroker in it (optional). Port the 302 heads by yourself. Either plug the holes in the head and drill to your intake's angle or angle-slot the intake holes. You are enough of an artist to not ruin the intake by changing the angle of the holes. No need to "wallow them out" they just need an angle shift. Then regrind the hydraulic roller cam and run two 400-500 carbs. It'll look cool, run real strong up to the cfm limit of the heads, and you'll be the owner of something different. 318 - 391 cubic inches will be big enough to get you into orbit in your '38. A 318 is exactly the same everything except the bores let the heads breathe better and the extra 45 cubic inches will make a lot of extra power.
Good Luck, R.
I actually purchased a complete set up minus the air cleaners for one of my projects from moparts or ebay (I forget, I'm not a smart man just really big) and I want to do the same stroker short block and make it a vintage Nascar-ish look. Two little 500 Eddys or Carters seem to work perfect on this intake, I just followed the baseline that Edelbrock uses for the SBF and SBC dualquad kits. I think Edelbrock has a different part number for their dual carbs... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Hope it helps, and forget about the "save the whales" folks here, use the part the way you want! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RUMBLON]
#232652
02/24/09 03:34 AM
02/24/09 03:34 AM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
I want to thank everyone for all the info. I think at this point I will save this manifold for the car in the photo below and start searching for some carbs to go with it. I have never spent any $$ on building a 273, so I may as well rebuild a real 273 car and use this manifold and make a little sleeper out of it. It will be cool to build a 273 car.
I will search for a 360 for the 38 Plymouth. I actually have a late mod 360 sitting in the weather that came out of my daughters truck a few years back. I am sure it is junk now, but I see 360s in craigslist a lot and pretty cheap.
I dont need a maxed out stroker, but a little UMPH would be nice and it needs a nice sound. How are the 360 crate motors? And if I look for a 360, whats a good year to try and find. I see mid 80s vans all the time with running engines and trans for the $300-500 range. I may get lucky and find something that I can throw in.
Also, I see a lot of people using the 518 trans??? is that an over drive trans of some sort as some lower gears and a 4 speed auto console shift of some kind would be cool or a 5 speed mopar trans, what options are out there.
And last, is there alink to both a good 360 build and a 273 build???? I am no mechanic and certainly no engine builder, but I need to learn. I honestly prefer body and paint work and custom metal work.
here are a couple of pics of my 273 67 dart. I also have a 67 POST Dart that has a new 340-6 motor. I have recently decided to take off the 6 pack and use it down the road on something else as I am going to drive this dart a lot.
Thanks again Dave
[Re: RUMBLON]
#232654
02/26/09 01:12 AM
02/26/09 01:12 AM
dart4forte
Mesa, Arizona
Thanks again Dave
Nice start. like I said earlier if you are interested PM me and I can give you some information.
[Re: dart4forte]
#232655
02/27/09 12:29 PM
02/27/09 12:29 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Nothing rare about that intake. It can still be purchased new from Offy.
The small ports up against a gasket matched intake port onthe head? It should provide an anti reversion effect.
As for the 920 heads? I have a set also. I was thinking of bolting them on a 360 or 318 for a MPG mild motor.
Should we start a 920 head thread?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#232657
02/28/09 01:55 PM
02/28/09 01:55 PM
RUMBLON
Cambridge Idaho
The small ports up against a gasket matched intake port onthe head? It should provide an anti reversion effect. As for the 920 heads? I have a set also. I was thinking of bolting them on a 360 or 318 for a MPG mild motor. Should we start a 920 head thread? Quote:
Nothing rare about that intake. It can still be purchased new from Offy. what do they sell for new??? Dave
