Re: Front drums to discs
[Re: minivan]
#2326365
06/25/17 12:06 PM
06/25/17 12:06 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
New shoes also require miles and adjustments before working well. The shoes have to wear in until they match the radius of the drums. When new the shoes have high spots and don't make full contact with the drum
**Photobucket sucks**
[Re: minivan]
#2326408
06/25/17 01:16 PM
06/25/17 01:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
That is why you are supposed to radius the shoes when installing them.
[Re: RapidRobert]
#2326476
06/25/17 03:58 PM
06/25/17 03:58 PM
Posts: 835 Alberta
4mulaS
Alberta
If you use A body calipers, ask for ones for a '76 A body as they have a 2.75" bore as opposed to the 2.60" for '73-'75 A calipers for more front bias. external dimentions/fitment is identical. & you might measure the bore at your parts house to confirm you are being given the right ones. This is true, also if one uses a 82' ish diplomat caliper you get the large bore and a plus is that the brake hose mounts in the bottom of the caliper and bleed out the top which can make bleeding easier. I think the dart ones mount hose at the top and bleed at the top. If you use diplomat calipers rear ,punted you need to use the hoses from a diplomat too. Or any hose that is 15"long. 69 camaro hoses also work
66Scar
[Re: 70Cuda383]
#2327137
06/26/17 08:47 PM
06/26/17 08:47 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
New shoes also require miles and adjustments before working well. The shoes have to wear in until they match the radius of the drums. When new the shoes have high spots and don't make full contact with the drum And that is why, way back then, we matched the radius of the new shoes to the drums after the drums ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) were turned.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: minivan]
#2327149
06/26/17 09:19 PM
06/26/17 09:19 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
On the brake hoses, just because they look good on the outside doesn't mean there good on the inside. Most pulling problems are caused from the inside of the hose deteriorating causing a blockage. If it pulls to the right, it's the left hose causing the problem/
