Re: A833 18spline, hard to put into 1st after being in neutral
[Re: Supercuda]
#2322182
06/16/17 03:40 PM
06/16/17 03:40 PM
Posts: 25,777 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Synchros do not work when at a stop and shifting into any gear.
They most assuredly do. What happens when you shift a non-synchro trans from neutral to 1st gear at a stop without waiting for the input shaft to coast to a stop?
[Re: lilred]
#2322189
06/16/17 03:58 PM
06/16/17 03:58 PM
Posts: 6,391 Abilene, Texas
fastmark
Abilene, Texas
Do you recall as to exactly what oil you ended up using as I would definitely give it a try, was it just regular of the shelf 80/90 gear oil??? Thanks Yup just plain 90wt gear oil.
[Re: lilred]
#2322211
06/16/17 04:25 PM
06/16/17 04:25 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Everytime I see Pennzoil, I make the sign of the cross..
EVERY car ( back in the day) that was using Pennzoil, and was burning oil ( blue smoke), stopped when changed out to Castrol or Kendall, ( the brands I used) after I stopped using Pennzoil...
Many years ago and a different time, but I never use any Pennzoil products...
[Re: lilred]
#2322313
06/16/17 08:03 PM
06/16/17 08:03 PM
Posts: 5,161 CT
GTX MATT
CT
To me it sounds like shifter alignment, shift fork wear (they wear at the ends which pushes the slider assembly at an angle) or something else wrong in the slider assembly itself.
It will go into 3rd and 4th easily from neutral?
[Re: lilred]
#2322380
06/16/17 11:03 PM
06/16/17 11:03 PM
Posts: 14,494 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I wouldn't over think it....... it's just an oil change. It will either help or not.
[Re: lilred]
#2322412
06/17/17 12:05 AM
06/17/17 12:05 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Did I miss what happens when going directly into reverse from neutral. If grinding likely a clutch release issue or severe misalignment or tight pilot bearing/bushing drag would be a good guess.
If any clutch drag or pilot bearing drag at all causing main shaft to continue spinning with clutch pedal down, synchronizes will relieve this but with great effort. Going into reverse, of course no synchro help at all.
[Re: John_Kunkel]
#2322423
06/17/17 12:19 AM
06/17/17 12:19 AM
Posts: 15,343 Omaha Ne
TJP
Omaha Ne
[Re: fast68plymouth]
#2322580
06/17/17 12:04 PM
06/17/17 12:04 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
The op says he's in neutral, then can't get it back into gear.
If the trans is in neutral, and the clutch is engaged, everything is turning. When you push the clutch pedal in, there is usually still some amount of drag helping to keep everything spinning, and when you go to put it into gear, the synchro has the job of stopping the rotation and aligning the teeth so it will slide into gear.
Surely you've heard someone grinding a gear to get it engaged........ They don't grind when they're not turning.
I still say a fluid change would help, and the Pennzoil synchro-mesh was recommended to me by a guy who does a lot of transmissions.
It's not that expensive and it's easy to do. Thats true when in neutral and the clutch is out the input shaft is turning as is the countershaft and the syncro's do work when you shift into gear since the gears are turning. Try this and when you push in the clutch and go to put it in first wait about 10 seconds before you try to put it in first after you push the clutch all the way in. By then all the gears should have stopped turning and it should go right in first with no grinding. If it does not and seems no different then when you go into first as soon as you push the clutch in then something is causing the input shaft to still be spinning when the clutch is in. I have seen a pilot bearing that was to tight cause this years ago. If it goes into gear normally then you know the input shaft stopped turning as it should. Myself I found that if its a clutch adjustment not letting the clutch disengage all the way you will usually also have shifting problems with all gears. I would still make sure the clutch adjustment is right but it does sound like the syncro is not working right. Can the wrong fluid be the cause ?? Myself I have not run into that but from what others have seen the wrong fluid may affect how the syncro's work so it surely wont hurt to change the fluid and try it. Good luck with it , Ron
[Re: lilred]
#2322628
06/17/17 02:15 PM
06/17/17 02:15 PM
fast68plymouth
So. Burlington, Vt.
I still feel that making sure the air gap is wide enough would be the first step.
If that's found to be sufficient......then change the oil.
[Re: lilred]
#2322665
06/17/17 04:09 PM
06/17/17 04:09 PM
Posts: 601 Mass
charge70
Mass
Not sure if this was said earlier,if it was sorry.When having trouble shifting into 1st gear,has the op tried shutting the engine off.That would tell you if its a clutch or transmission problem.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
