Re: Stock Cam replacement
[Re: psh]
#2322991
06/18/17 11:54 AM
06/18/17 11:54 AM
RapidRobert
Dave Hughes has a good rep. & a cam for low compression would for sure have enough vac for PB, no worries there.
[Re: 451Mopar]
#2323539
06/19/17 11:56 AM
06/19/17 11:56 AM
RapidRobert
That is the Whiplash cam. It installs at 102 intake centerline (closes the intake early for good dynamic compression) and has a narrow lobe seperation angle which gives it alot of overlap (rough idle, low vacuum.) so one of those cams intended for low comp actually has low vac? I never would of guessed & I woulda thought just the opposite.
[Re: psh]
#2323603
06/19/17 02:03 PM
06/19/17 02:03 PM
Posts: 14,500 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
so one of those cams intended for low comp actually has low vac? I never would of guessed & I woulda thought just the opposite. You're surprised a cam that specs out as 232/245-107(as per the Hughes site)would have low vacuum? I would absolutely expect low vac out of that cam...... Especially in a low cr motor. It's designed to idle rough...... Which is done by dirtying up the idle with lots of overlap.
[Re: psh]
#2323638
06/19/17 03:22 PM
06/19/17 03:22 PM
fast68plymouth
So. Burlington, Vt.
I didn't see it mentioned anywhere...... But if the "plan" is to retain the OE carb(TQ), intake, and exhaust manifolds, then IMO........ That really narrows down what I would feel are the "appropriate" cam choices.
And if that is how it's going to be run, then I def feel the big valves are a step in the wrong direction.
[Re: psh]
#2323639
06/19/17 03:24 PM
06/19/17 03:24 PM
Posts: 75,023 U.S.S.A.
JohnRR
U.S.S.A.
Still want to know what Worman would use LOL
and then avoid it at all costs ...
[Re: fast68plymouth]
#2323755
06/19/17 06:59 PM
06/19/17 06:59 PM
RapidRobert
so one of those cams intended for low comp actually has low vac? I never would of guessed & I woulda thought just the opposite. You're surprised a cam that specs out as 232/245-107(as per the Hughes site)would have low vacuum? I would absolutely expect low vac out of that cam...... Especially in a low cr motor. It's designed to idle rough...... Which is done by dirtying up the idle with lots of overlap. Well I ain't a cam guy & I had assumed that a cam that is specifically designed to build/trap compression would have a good vac #. Obviously not & I learned something today.
[Re: psh]
#2324115
06/20/17 11:52 AM
06/20/17 11:52 AM
JohnRR
U.S.S.A.
psh you said the cam had flat lobes , safe to assume you are taking this engine further down ... like completely apart ... than just a bad choice head rebuild?
If you are stuck on stock iron junk then fast68plymouth is the person to see , it's only a 2.5 to 3 hour ride up to his shop.
[Re: psh]
#2324618
06/21/17 11:38 AM
06/21/17 11:38 AM
RapidRobert
I know some of you wont like this but I purchased the KC661 kit. Nah we're good with that! post how it acts when the time comes.
[Re: psh]
#2326168
06/24/17 05:59 PM
06/24/17 05:59 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
Hello
New to Moparts
Could anyone suggest a replacement cam for a 1974 Roadrunner 400 "P" code motor? I don't want to change the factory rockers or pushrod length if I don't have to? I see Sealed power CS-661 or kit KC661 with lifters, or Yearone MP31, Comp Cams 21-212-4. Cannot seem to find the exact specs of the original. Heck, what would Worman use? Also anyone use the Sealed power rockers or arms (vintage)
Thanks I have the same car 35000 mile 74 Roadrunner with a 400/auto. My car is stock except for a 3" TTI exhaust and 3.91 gears. The no. 5 intake lobe went bad and I had to replace the cam. The cam that's free is right for me, so I wound up with a 274 comp. This is not a great selection, rough idle noticeably less low end torque. I'm not happy with it. I was going to make the same post, so this is what I need to know. I look forward to seeing how it works out for you.
1974 Roadrunner
1967 Charger
