Re: How much power can a stock Hellcat short block take
[Re: Dart451]
#2319942
06/12/17 03:22 PM
06/12/17 03:22 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I imagine it can handle quite a bit. Plenty of the factory non HC blocks are making 1,000+ hp.
[Re: Dart451]
#2320059
06/12/17 06:32 PM
06/12/17 06:32 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Yeah I don't know why people are buying stroker kits for 5.7s, they cost as much as a hellcat short block brand new from the dealer ready to drop in. All the extra money machining and time assembling for another 200 CC and your local machine shop probably ain't as acurate as the factory? It also seems I heard the 6.4 truck engine was all forged guts, it should be a good turbo build also around the same price.
[Re: Dart451]
#2320230
06/12/17 10:59 PM
06/12/17 10:59 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
For boost any stock pistons other than the Hellcat are a roll of the dice with the top ring locations. The Hellcat pistons are good but also have the top ring moved down lower. There are some out there in the 1300 hp already with un-opened bottom ends. Pretty cool IMO.
Mopar to the bone!!!
[Re: Dart451]
#2320249
06/12/17 11:28 PM
06/12/17 11:28 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Considering the power it takes to turn the blower, and accessory losses, I bet those Hellcat shortblock and head assembly's would take a whole lot more than we think. They are built to withstand long periods of full boost, and long life to boot.
[Re: fbs63]
#2320385
06/13/17 07:59 AM
06/13/17 07:59 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
The problem is the VVT. You can lock out the cam phaser but only the factory timing set is available. Im looking at making a cam adapter to use a non-VVT cam in a VVT block using the 6.1 double roller timing set. Like this one? http://www.ebay.com/itm/HEMITRONIX-5-7-6-4-HEMI-VCT-VVT-AND-MDS-ELIMINATOR-CAM-KIT
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: cudadoug]
#2320388
06/13/17 08:08 AM
06/13/17 08:08 AM
ric3xrt
Trumbauersville PA
So if you're a gen 3 rookie like me, how can I use this HC short block?? Will my Eagle heads bolt on?
What carb intake works?
Will front covers interchange? your Eagle heads will bolt on to a HellCat short block. There are a intakes out now, you have the Drag pak, Arrow Racing has a new single plane out now and OCP has had a dual plane out for awhile. Eagle front cover Yes , pre 09 I'm not sure.
[Re: fbs63]
#2320460
06/13/17 11:13 AM
06/13/17 11:13 AM
ric3xrt
Trumbauersville PA
Yes, but I don't like the fact it just pilots off the spocket boss. I will probably turn the first bearing journal down and machine one for a press fit. Sounds good, I like your Idea better . I have the above kit in a 2014 6.4 short block I'm not to keen on how the kit,like you said pilots of the sprocket.
[Re: fbs63]
#2323713
06/19/17 05:39 PM
06/19/17 05:39 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
The problem is the VVT. You can lock out the cam phaser but only the factory timing set is available. Im looking at making a cam adapter to use a non-VVT cam in a VVT block using the 6.1 double roller timing set. Boy, oh boy...that would be a big help on these motors!
[Re: Dart451]
#2333691
07/08/17 04:49 PM
07/08/17 04:49 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
There is a few cats that are putting 1050 to back tires. Was one that went for just a tad more and it blew.... so 1000 at the crank and you will be just fine
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
