Re: lake wood scatter sheild
[Re: bigblockbryan]
#2323131
06/18/17 04:01 PM
06/18/17 04:01 PM
Posts: 8,157 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
is THIS it? were all smallblock flywheels 130 tooth? If so I only need the nose cone piece. If not I need this: Lakewood adapter kit And PERFECT timing as I have had the Lakewood and Center force forever but just broke a clutch spring on the stock unit yesterday Thanks for any help
[Re: UCUDANT]
#2323663
06/19/17 03:55 PM
06/19/17 03:55 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
is THIS it? were all smallblock flywheels 130 tooth? If so I only need the nose cone piece. If not I need this: Lakewood adapter kit And PERFECT timing as I have had the Lakewood and Center force forever but just broke a clutch spring on the stock unit yesterday Thanks for any help Yes all smallblocks were only 130tooth. If that is a smallblock bellhousing you shouldn't need that .
[Re: bigblockbryan]
#2323730
06/19/17 06:09 PM
06/19/17 06:09 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What exactly does that little tab with the stepped stud on it do?
We have one of the Lakewood bell housings we use on the dyno, and I thought the one starter bolt hole for the 130T flywheel was just drilled in the wrong place.
For the dyno, it's not really a big deal. The upper bolt fits okay, and on the bottom one I just use a c clamp.
[Re: Stanton]
#2324107
06/20/17 11:42 AM
06/20/17 11:42 AM
JohnRR
Running up your post count about sums it up. Late to the party as usual ... all his issues have been addressed. If you pull your head out of your backside long enough to see what was actually going on in the world around you you'd realize to whom I was responding to ... UCUDANT asked twice about this part, and flywheel tooth count near the end of this thread and no one had responded to his 2 requests for info. but thanks for playing ...
