Re: Some Pro Comp "Victor" stuff.....
[Re: fast68plymouth]
#2319376
06/11/17 12:53 PM
06/11/17 12:53 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The minor welding porosity is inside of the gasket fire ring, so I don't expect any problems from it.
As for the seat install, I heat the head to 250* for about 1/2hr, and the seat rings get put in a cooler with ice.
With aluminum heads I machine the seat bore to have about .007-.008 interference fit with the insert at room temperature.
[Re: BradH]
#2319387
06/11/17 01:17 PM
06/11/17 01:17 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Doing it right the first time is always the cheapest and easiest. All the people who look at things strictly from the "Did I get a 'deal'?" or "Did I get the best price?" perspective don't want to hear that. These are some of the details that are left out of most of the "I got these heads for a $1000 what a deal" stories that people like to tell. Thanks for sharing Dwayne, After the 1st couple of pics I didn't think there would be a happy ending
"Just a Bracket car dressed up like a streetcar"
#2319421
06/11/17 02:09 PM
06/11/17 02:09 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
When Dale and I bought his AMX in 1997, it came with a set of damaged MP Stage VI heads. They've been on about five engines since, as we've traded them back and forth between friends and family. They require a trip to the machine shop every time for something. I bet we've spent over 4K on those "free" castings in the last twenty years!
Meanwhile my Edelbrock RPMs have provided excellent service since 2002 with a couple of very minor freshen-ups.
Thanks for the pics and explanation, great work as always!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
#2319445
06/11/17 02:54 PM
06/11/17 02:54 PM
fast68plymouth
So. Burlington, Vt.
Billy, I'm actually working on some stage 6's at the shop now.
It's one of those things where.......the customer already owns them.......and you can't quite get into a set of comparable new heads for what it would cost to get these into shape.
These happen to be brand new, but I've had a few sets of used ones come through the shop where there was a good argument to be made that it might have been better to cut your losses and move on.
They still trickle into the shop from time to time.
In the case of the Pro Comps....... it wasn't really any fault of the heads themselves that resulted in the dropped valve. I'm sure if the same parts had been installed in a set of Ede Victors, the outcome would have been the same.
#2320761
06/13/17 09:05 PM
06/13/17 09:05 PM
fast68plymouth
So. Burlington, Vt.
I've had them a lot worse....... This wasn't really that bad of a job.
It's just a lot of little things that take time, and that adds up.......but no one part of it was really hard to do, or all that time consuming.
The first thought I had wasn't that it as going to be hard to finish, it was actually whether or not it was going to be cost effective to do it. As I mentioned previously, had there not been porting done, it wouldn't have been.
#2320871
06/13/17 11:43 PM
06/13/17 11:43 PM
fast68plymouth
So. Burlington, Vt.
I gave him an estimate on the repair...... He thought about it, and said "yes". There was no pressure........ He could have said no.
I don't know that I'd call it a "bottomless pit". They're done, and should work better than they ever did.
The guides are nice and straight, correct clearance, better valve job, correct size valves, reblended bowls/seats, more flow than before...... And the valves won't be running into each other.
If the head hadn't already been welded when I got it, that could have been the tipping point that pushed the cost into the "just get a new head" territory, but it was already done.
Of course, if it was an actual Victor head, there would have been no question it would be cost effective to fix it, since the cost of a Victor head casting is about double.
