Why is my Charger overheating (with data)
#2303153
05/12/17 12:29 AM
05/12/17 12:29 AM
Posts: 2,260 IL
furious70
IL
my 68 Charger has a problem with overheating after 20-30min of around town driving. It's ok on the highway, but tooling around the burbs it gets hot, up to 230*
440 alum cross flow rad 2 elec fans always on shroud
with my infrared temp gun the intake was 250, front of each head 230 top rad hose 200, bottom rad hose 145, driver's side water pump housing 200
seems like the rad is working?
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Why is my Charger overheating (with data)
[Re: furious70]
#2303164
05/12/17 12:40 AM
05/12/17 12:40 AM
RapidRobert
Yes the rad is working cuz it is good at speed. If your timing is in the ballpark I'm thinking not enough airflow from the fans.
[Re: furious70]
#2303177
05/12/17 12:59 AM
05/12/17 12:59 AM
Posts: 2,260 IL
furious70
IL
26" 2 core alum cross flow - universal.
How much temp drop should I expect across the rad?
[Re: furious70]
#2303186
05/12/17 01:31 AM
05/12/17 01:31 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
same type of rad i have except its a down flo.I took my dual spal fans off and went back to a stock fan and shroud.temps went from 220 in traffic to 190 and thats on a hot fl. summer day.
[Re: bonefish]
#2303194
05/12/17 01:47 AM
05/12/17 01:47 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
same type of rad i have except its a down flo.I took my dual spal fans off and went back to a stock fan and shroud.temps went from 220 in traffic to 190 and thats on a hot fl. summer day. Yep. There you go. Also the universal radiators do not fit as tight to the body radiator support. Fill in the gaps with closed cell foam.
[Re: furious70]
#2303875
05/13/17 04:22 PM
05/13/17 04:22 PM
Posts: 2,260 IL
furious70
IL
would you try a fixed 5 blade or 7 blade clutch? I found both in the shop and will take back to Chicago to try.
[Re: furious70]
#2303887
05/13/17 05:02 PM
05/13/17 05:02 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
would you try a fixed 5 blade or 7 blade clutch? I found both in the shop and will take back to Chicago to try. I have a 7 blade, flex a lite fixed blade, on my 68 Charger, works great, 512 cid,cold AC in Southeast Texas, it gets over 100deg here, my car will run 180ish all day long.
[Re: furious70]
#2318928
06/10/17 01:23 PM
06/10/17 01:23 PM
Posts: 2,260 IL
furious70
IL
I had the right spacers to put the 5 blade fixed on and it's dramatically better but not solved. It takes longer to heat up, but it traffic jams it will move off the t-stat. Going down the road it does cool itself off better. I need to seal the top of the rad support to the rad, the sides are now sealed, they weren't before.
Probably going to try one of the clutch fans, I've ordered the spacers
[Re: furious70]
#2318953
06/10/17 02:12 PM
06/10/17 02:12 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Probably going to try one of the clutch fans, I've ordered the spacers Seal the radiator to the yoke opening top/bottom and sides with adhesive sided foam strip so it stays in place and doesn't get blown/sucked out and get a shroud on it as well that encases at least 50% of the fan blades width, with no more than 75% of the fan buried in the shroud, cooling basics 101
[Re: furious70]
#2318968
06/10/17 03:07 PM
06/10/17 03:07 PM
Posts: 2,260 IL
furious70
IL
ya, I can't find a shroud for the universal cross flow rad with a mech fan. Summit has some very generic metal that they sell as a make your own kit, might have to try that.
[Re: furious70]
#2319186
06/11/17 12:04 AM
06/11/17 12:04 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
1971 Challenger 430ci Hemi stock factory 3 core rad, cores are clean, 7 blade Chrysler fixed fan no clutch, shroud, mated water pump and housing, 160 quick flow thermostat, car runs at 163 degrees all day long no matter what I am doing or were I am driving or how hot it is outside. Timing has a big effect on temp also.
1971 HEMI E BODY REGISTRY
[Re: furious70]
#2328881
06/29/17 11:15 PM
06/29/17 11:15 PM
Posts: 2,260 IL
furious70
IL
In our loft I found a new thermal clutch and 5 blade. I put the 7 blade fan on it and low speed cooling has improved even over the fixed fan. Bought a universal fiberglass shroud but didn't fit. Still will do that eventually but now the car tolerates 90* commutes with the AC on. Still heats up a little bit but cools off quick
